title: "The Foundation SDK builder pattern | Grafana Labs"
description: "How the Foundation SDK uses composable builders to construct dashboards"
## How builders work in the Foundation SDK
With the Foundation SDK you define dashboards one step at a time with chained method calls instead of one giant config object.
## Follow the builder sequence
Most dashboard code follows this flow:
- Start with **DashboardBuilder** for dashboard-level settings.
- Add each panel with **PanelBuilder**.
- Add panel queries with **DataqueryBuilder**.
- Export the final dashboard JSON from the completed builder chain.
## Why this matters
The builder pattern has practical advantages when defining dashboards in code.
| Benefit          | What it means for you                                  |
| **Composable**   | Build complex dashboards from simple, reusable pieces  |
| **Readable**     | Chained calls read like a description of what you want |
| **IDE-friendly** | Autocomplete shows valid options at every step         |
