title: "Deploy a dashboard with Git Sync | Grafana Labs"
description: "Hands-on steps to sync Foundation SDK JSON into Grafana"
## Hands-on: sync your dashboard JSON with Git Sync
Use the dashboard JSON you exported with the Foundation SDK. Connect Git Sync to a GitHub repository, commit that JSON into the synced path, and verify the dashboard appears as a provisioned dashboard in Grafana.
| Step                            | What you’ll do        | Outcome                                  |
| **1. Open Provisioning**        | Sign in as Grafana Admin and go to **Administration &gt; General &gt; Provisioning** | Git Sync setup screen                    |
| **2. Connect GitHub**           | Choose **GitHub** and authenticate (personal access token or another method you use) | Grafana can access your repository       |
| **3. Configure the repository** | Set repository, branch, and path for folder sync                                     | A repository resource watching that path |
| **4. Commit your JSON**         | Add the Foundation SDK dashboard JSON file under the synced path and push            | JSON available for sync                  |
| **5. Pull and verify**          | Use **Pull** if needed, then open **Dashboards** and find the provisioned dashboard  | Live dashboard from Git                  |
## Before you start
Make sure you have the following:
- Grafana Admin access on your instance
- A GitHub repository you can commit to
- Dashboard JSON exported from the Foundation SDK (with a stable UID)
- Authentication for GitHub (for example a personal access token)
## Set up, then practice
Complete steps 1–3 with the [Git Sync setup docs](/docs/grafana/latest/as-code/observability-as-code/git-sync/git-sync-setup/) (this journey’s connection path). Then commit your SDK JSON (steps 4–5) and verify the provisioned dashboard.
After Git Sync is connected, these learning paths help you navigate Provisioning and work with provisioned dashboards in the UI. They assume a repository is already configured; they do not replace the setup docs or the SDK JSON commit in the table above.
Learning path
#### Use Git Sync to manage resources
Welcome to the learning path that shows you how to use Git Sync to manage your Grafana resources with version control.
10 min
Beginner
Docs &amp; blog posts
#### Open in Grafana Cloud
Complete this learning path directly in your Grafana Cloud stack with an interactive learning experience.
[Open in Grafana Cloud]()
[View on website](/docs/learning-paths/git-sync-use/)
Learning path
#### Work with dashboards using Git Sync
Welcome to the learning path that shows you how to create, edit, and manage dashboards using Git Sync workflows with version control.
16 min
Beginner
[View on website](/docs/learning-paths/git-sync-dashboards/)
