Where the Foundation SDK and Git Sync fit among Grafana's as-code tools
Estimated time: 1 min
Grafana’s Observability as Code tools
Grafana offers several as-code tools. Each solves a different part of the problem, and they can work together. This diagram shows how they relate in a generate-and-sync workflow.
This journey focuses on the Foundation SDK (generate) + Git Sync (sync) + GitHub Actions (automate) workflow. While the SDK alone only creates dashboards as code but doesn’t update Grafana, Git Sync is what keeps Grafana aligned with the JSON in Git.
Tool overview
Tool
What it does
Use it for
Part of this journey?
Foundation SDK
Defines dashboards in typed code (Go, TypeScript, Python, Java, PHP)
Generating dashboard JSON programmatically
Yes
Git Sync
Syncs dashboard and folder JSON in a Git repo with Grafana
Git-native workflows where the repository is the source of truth
Yes
Terraform provider
Manages Grafana resources with Terraform plan and apply
