title: "Build an alert with code | Grafana Labs"
description: "When to choose Code mode over Builder, plus a hands-on Path for writing PromQL and creating a silence."
## Build an alert with the Code mode
You just built an alert in **Builder** mode. **Code** mode follows the same rule flow. The difference is how you write the query: you type PromQL instead of picking the metric and operations from menus in the UI.
| Use case                                           | Recommended mode |
| Standard metric, labels, and common operations     | Builder          |
| Complex nested expressions or exact syntax control | Code             |
| Team members new to PromQL                         | Builder          |
Start in Builder when you’re learning. Switch to Code when you need more control than Builder can express clearly.
## Path
This Path walks you through writing the alert query in PromQL, then creating a silence to suppress notifications during maintenance.
Learning path
#### First alert rule with query language
Build a Grafana alert rule in Code mode — write a PromQL error-rate query, set a condition, add labels, configure evaluation and notifications, and save.
14 min
Intermediate
Docs &amp; blog posts
#### Open in Grafana Cloud
Complete this learning path directly in your Grafana Cloud stack with an interactive learning experience.
[Open in Grafana Cloud]()
[View on website](/docs/learning-paths/alerting-query-language/)
