No-data and error handling
Each time an alert rule runs, it evaluates its query and decides whether to fire or stay quiet. Sometimes the rule runs but can’t decide whether to fire for two reasons:
- The query returns no data. In this case, Grafana assigns a state of No Data. This happens when:
- No series match the query due to an incorrect metric or label filter
- The data source stops reporting
- The time window has no samples, often because the evaluation window or query range is too short for how often the data arrives
- The query fails to run. If this occurs, Grafana assigns a state of Error. This can happen with:
- Evaluation timeouts
- Repeated query failures from a data source that’s down
- An authentication problem
Those auto-generated alerts use names like DatasourceNoData and DatasourceError, so your team may not recognize them or connect them back to your rule.
How to handle evaluation issues
You can choose other options to keep your rule out of the No Data and Error states. This means no separate alert is created, and the response stays tied to your rule’s own name and routing.Common mistake
The Configure no data and error handling options in Grafana are powerful, but they require close attention. Don’t set the Alert state if no data or all values are null option to Normal unless you’re certain that data gaps are safe. Otherwise your rule stays silent during a real outage, and you hear nothing when the underlying data source stops reporting.
