title: "Alert condition | Grafana Labs"
description: "How an operator and a threshold define when an alert moves from normal toward firing."
## Alert condition
The **alert condition** defines when an alert moves toward firing. A **threshold** is the value the condition compares against.
The condition watches a value over time. If the value stays at or below the threshold, the alert stays normal. When it rises above the threshold and stays there through the pending period you configure later, the alert fires.
For this journey’s QuickPizza server-errors example, the value is how many new 5xx responses arrived in the last five minutes. Alert when that count **is above 0** so any server errors in the window can trigger the rule. The alert condition has two parts:
- **Is above** is the operator.
- **0** is the threshold.
[Line chart of QuickPizza 5xx responses over five-minute windows — near zero when healthy, spiking when errors appear — with a dashed threshold line at 0; the alert is normal at zero and moves toward firing while the value is above it](condition-flow.svg "Line chart of QuickPizza 5xx responses over five-minute windows — near zero when healthy, spiking when errors appear — with a dashed threshold line at 0; the alert is normal at zero and moves toward firing while the value is above it")
## Important: verify after setting
Always click **Preview alert rule condition** to verify which instances would fire. If you change the operator from **Is above** to **Is below**, double-check that the threshold value still makes sense.
