What is an alert rule
An alert rule tells Grafana what data to watch. It defines a threshold for when something becomes a problem, and it defines what to do when something goes wrong and an alert is triggered. You create an alert by completing the New alert rule page in the UI, where you fill out the following sections:
Why the name matters
The alert rule name shows up in every notification your team receives. A vague name like “Alert 1” tells the responder nothing about what’s wrong. Your alert rule name is the first piece of critical information a responder will see, so a clear naming structure for your alerts helps responders act faster.
Choose names that describe what you’re monitoring and where, for example:
- “QuickPizza server errors”
- “Payment service error rate above 5%”
- “Database connection pool exhausted”
