Section 1 · Intro
Match your situation to the signals that show auto-apply fits, and to the ones that show it doesn't fit yet.
Estimated time: 1 min
Is auto-apply right for you?
Check where you are with Adaptive Metrics before you enable auto-apply.
A good fit
SignalWhy it matters
You’re comfortable with the recommendations you’ve applied manuallyAuto-apply then applies the new recommendations your mode allows, without manual review.
Exemptions protect your critical metricsExemptions keep the metrics or labels you choose out of recommendations, so auto-apply leaves them out too.
Your usage keeps changingAdaptive Metrics updates its recommendations as your usage changes, and auto-apply applies the new ones your mode allows so you don’t review each one yourself.
Some of your segments are ready and others aren’tAuto-apply is set for each segment, including Default, so you can turn it on for the ones that are ready and leave the rest as they are.
Not yet
SignalWhere it’s covered
You haven’t used Adaptive Metrics yetIntroduction to Adaptive Metrics
Your critical metrics don’t have exemptions yetUse exemptions
You’re still deciding which recommendations to applyReview and apply recommendations
