title: "Is auto-apply right for you? | Grafana Labs"
description: "Match your situation to the signals that show auto-apply fits, and to the ones that show it doesn't fit yet."
# Is auto-apply right for you?
Check where you are with Adaptive Metrics before you enable auto-apply.
## A good fit
| Signal                                                              | Why it matters        |
| You’re comfortable with the recommendations you’ve applied manually | Auto-apply then applies the new recommendations your mode allows, without manual review.        |
| Exemptions protect your critical metrics                            | Exemptions keep the metrics or labels you choose out of recommendations, so auto-apply leaves them out too.                                                     |
| Your usage keeps changing                                           | Adaptive Metrics updates its recommendations as your usage changes, and auto-apply applies the new ones your mode allows so you don’t review each one yourself. |
| Some of your segments are ready and others aren’t                   | Auto-apply is set for each segment, including Default, so you can turn it on for the ones that are ready and leave the rest as they are.                        |
## Not yet
| Signal                                               | Where it’s covered        |
| You haven’t used Adaptive Metrics yet                | [Introduction to Adaptive Metrics](/docs/grafana-cloud/observe-and-act/adaptive-telemetry/adaptive-metrics/introduction/)           |
| Your critical metrics don’t have exemptions yet      | [Use exemptions](/docs/grafana-cloud/observe-and-act/adaptive-telemetry/adaptive-metrics/create-exemptions/)                        |
| You’re still deciding which recommendations to apply | [Review and apply recommendations](/docs/grafana-cloud/observe-and-act/adaptive-telemetry/adaptive-metrics/manage-recommendations/) |
