title: "Journey overview | Grafana Labs"
description: "Auto-apply applies new Adaptive Metrics recommendations as they're generated, and the mode you choose decides whether that includes ones that add series. This journey covers whether it fits, what to protect first, how it treats recommendations, and how to turn it on."
# Stop applying every recommendation manually
Adaptive Metrics looks at how you use your metrics and suggests changes to how much detail you keep for each one. Each change is a **recommendation**. Auto-apply applies new recommendations as they’re generated, so you spend less time on the list. The **mode** you choose decides whether it also applies recommendations that add series. This journey covers whether it fits, what to protect first, how it treats recommendations, and how to turn it on.
## What you’ll learn
Here’s what this journey covers:
- **Whether it fits:** Signals that show you’re ready to stop applying recommendations manually
- **What to protect first:** Why to exempt the metrics and labels whose full detail you need before anything applies automatically
- **How it treats recommendations:** The two ways it can handle recommendations that would increase what you store, and when each fits
- **Turning it on in the UI:** Where you turn it on, starting from **Overview**
- **Other ways to turn it on:** When to use the UI, the API, or Terraform
- **What you still control:** Which settings and recommendations stay yours after it’s on
## Journey duration
~20-30 minutes
