title: "Test builder | Grafana k6 documentation"
description: "Use a graphical interface to create a k6 test."
# Test builder
The k6 Test Builder provides a graphical interface to generate a k6 test script based on your input. Then, you can copy the test script and [run the test from the CLI](/docs/k6/v2.3.x/get-started/running-k6/).
Though we strongly believe that scriptable, code-based tools will help you get the most out of your performance-testing efforts, a GUI-based tool like the test builder could help you:
- Speed up the test creation.
- Learn the [k6 API](/docs/k6/v2.3.x/javascript-api/) quickly.
- Collaborate with non-coders to build tests.
The k6 Test Builder is **free to use** and is available in:
- [Grafana Cloud k6](/docs/grafana-cloud/testing/k6/author-run/test-builder/)
