title: "Create a test script using the CLI | Grafana k6 documentation"
description: "Learn how to create a test using the k6 CLI and the k6 new command."
# Create a test script using the CLI
Writing a k6 test script from scratch can seem challenging if you’re just getting started with k6, or repetitive if you’re already familiar with the tool. The k6 `new` command can help both new and experienced users quickly generate a test script, which they can use to try out k6, or use as a starting point to test out their applications and services.
## Before you begin
To use the k6 `new` command, you’ll need:
- [k6 v0.57 or higher](/docs/k6/v2.3.x/set-up/install-k6/) installed on your machine.
- Custom templates require k6 v1.0.0-rc1 or higher.
## Use the k6 new command
To create a script with the k6 `new` command, run the following in your terminal:
Bash ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```bash
k6 new
The command creates a k6 test script file named `script.js` in the current directory.
You can customize the script filename by passing the name as an argument. For example, to create a script named `test.js`:
```bash
k6 new test.js
## Options
You can customize the generated script using the following options: `--template` and `--project-id`.
### –template
The `--template` flag allows you to specify a template that best fits your use case.
The options are:
- `minimal`: Creates a minimal test script with a short options configuration, and a single request and check example. This is the default option.
- `protocol`: Creates a script that includes environment variables, stages with different durations and VUs, thresholds, and a setup function. This is ideal for learning, and as a good starting point for real-world scenarios.
- `browser`: Creates a browser script that checks if a websites successfully loaded, looks for elements on the screen, and takes a screenshot. Similar to the `protocol` option, this is ideal for learning, and a good starting point for creating browser tests.
- An absolute or a relative path to a local file, such as `./my-template.js` or `/path/to/my-template.js` to use a custom template. `k6` uses [Go templating syntax](https://pkg.go.dev/text/template#section-documentation) to render the script.
To generate a script using a template, run:
```bash
k6 new --template protocol
### –project-id
The `--project-id` flag allows you to specify a Grafana Cloud k6 project ID. The generated script is then configured to run in that project. To include the project ID in your custom template, use `{{ .ProjectID }}` as a placeholder, for example:
JavaScript ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```javascript
export default function () {
  console.log('Hello from project {{ .ProjectID }}!');
To use the project ID flag, run:
```bash
k6 new --project-id 12345
> Note
> To run your test in a specific Grafana Cloud k6 project, you need a Grafana Cloud account with access to that project.
> To learn more about Grafana Cloud k6, refer to [Grafana Cloud k6 documentation](/docs/grafana-cloud/testing/k6/).
