title: "Ramping VUs | Grafana k6 documentation"
description: "A variable number of VUs execute as many iterations as possible for a specified amount of time."
# Ramping VUs
With the `ramping-vus` executor, a variable number of VUs executes as many iterations as possible for a specified amount of time.
For a shortcut to this executor, use the [stages](/docs/k6/v2.3.x/using-k6/k6-options/#stages) option.
## Options
Besides the [common configuration options](/docs/k6/v2.3.x/using-k6/scenarios/#options), this executor has the following options:
Expand table
| Option           | Type    | Description        | Default |
| stages(required) | array   | Array of objects that specify the target number of VUs to ramp up or down to.                  | `[]`    |
| startVUs         | integer | Number of VUs to run at test start.                                                            | `1`     |
| gracefulRampDown | string  | Time to wait for an already started iteration to finish before stopping it during a ramp down. | `"30s"` |
## When to use
This executor is a good fit if you need VUs to ramp up or down during specific periods of time.
## Example
This example schedules a two-stage test, ramping up from 0 to 10 VUs over 20 seconds, then down to 0 VUs over 10 seconds.
JavaScript ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```javascript
import http from 'k6/http';
import { sleep } from 'k6';
export const options = {
  discardResponseBodies: true,
  scenarios: {
    contacts: {
      executor: 'ramping-vus',
      startVUs: 0,
      stages: [
        { duration: '20s', target: 10 },
        { duration: '10s', target: 0 },
      gracefulRampDown: '0s',
export default function () {
  http.get('https://test.k6.io/contacts.php');
  // Injecting sleep
  // Sleep time is 500ms. Total iteration time is sleep + time to finish request.
  sleep(0.5);
> Note
> With [`gracefulRampDown`](/docs/k6/v2.3.x/using-k6/scenarios/concepts/graceful-stop/#the-gracefulrampdown) set to 0 seconds, some iterations might be interrupted during the ramp down stage.
## Observations
The following graph depicts the performance of the [example](#example) script:
Based upon our test scenario inputs and results:
- The configuration defines 2 stages for a total test duration of 30 seconds;
- Stage 1 ramps *up* VUs linearly from the `startVUs` of 0 to the target of 10 over a 20 second duration;
- From the 10 VUs at the end of stage 1, stage 2 then ramps *down* VUs linearly to the target of 0 over a 10 second duration;
- Each *iteration* of the `default` function is expected to be roughly 515ms, or ~2/s;
- As the number of VUs changes, the iteration rate directly correlates; each addition of a VU increases the rate by about 2 iters/s, whereas each subtraction of a VU reduces by about 2 iters/s;
- The example performed ~300 iterations over the course of the test.
## Get the stage index
To get the current running stage index, use the `getCurrentStageIndex` helper function from the [k6-jslib-utils](/docs/k6/v2.3.x/javascript-api/jslib/utils/) library. It returns a zero-based number equal to the position in the shortcut `stages` array or in the executor’s `stages` array.
```javascript
import { getCurrentStageIndex } from 'https://jslib.k6.io/k6-utils/1.3.0/index.js';
  stages: [
    { target: 10, duration: '30s' },
    { target: 50, duration: '1m' },
  if (getCurrentStageIndex() === 1) {
    console.log('Running the second stage where the expected target is 50');
Using this feature, it is possible to automatically tag using the current running stage. Check the [Tagging stages](/docs/k6/v2.3.x/using-k6/tags-and-groups/#tagging-stages) section for more details.
