title: "Constant arrival rate | Grafana k6 documentation"
description: "A fixed number of iterations are started in a specified period of time."
# Constant arrival rate
With the `constant-arrival-rate` executor, k6 starts a fixed number of iterations over a specified period of time. It is an open-model executor, meaning iterations start independently of system response (for details, read [Open and Closed models](/docs/k6/v2.3.x/using-k6/scenarios/concepts/open-vs-closed/)).
This executor continues to start iterations at the given rate as long as VUs are available. The time to execute an iteration can vary with test logic or the system-under-test response time. To compensate for this, the executor starts a varied number of VUs to meet the configured iteration rate. For explanations of how allocation works, read [Arrival-rate VU allocation](/docs/k6/v2.3.x/using-k6/scenarios/concepts/arrival-rate-vu-allocation/).
> Note
> **Iteration starts are spaced fractionally.** Iterations **do not** start at exactly the same time. At a `rate` of `10` with a `timeUnit` of `1s`, each iteration starts about every tenth of a second (that is, each 100ms).
## Options
Besides the [common configuration options](/docs/k6/v2.3.x/using-k6/scenarios/#options), this executor has the following options:
Expand table
| Option                    | Type    | Description        | Default                             |
| duration(required)        | string  | Total scenario duration (excluding `gracefulStop`).                            | \-                                  |
| rate(required)            | integer | Number of iterations to start during each `timeUnit` period.                   | \-                                  |
| preAllocatedVUs(required) | integer | Number of VUs to pre-allocate before test start to preserve runtime resources. | \-                                  |
| timeUnit                  | string  | Period of time to apply the `rate` value.                                      | `"1s"`                              |
| maxVUs                    | integer | Maximum number of VUs to allow during the test run.                            | If unset, same as `preAllocatedVUs` |
## When to use
When you want iterations to remain constant, independent of the performance of the system under test. This approach is useful for a more accurate representation of RPS, for example.
> Note
> **Don’t put sleep at the end of an iteration.**
> The arrival-rate executors already pace the iteration rate through the `rate` and `timeUnit` properties. So it’s unnecessary to use a `sleep()` function at the end of the VU code.
## Example
This example schedules a constant rate of 30 iterations per second for 30 seconds. It pre-allocates 2 VUs, and allows k6 to dynamically schedule up to 50 VUs as needed.
JavaScript ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```javascript
import http from 'k6/http';
export const options = {
  discardResponseBodies: true,
  scenarios: {
    contacts: {
      executor: 'constant-arrival-rate',
      // How long the test lasts
      duration: '30s',
      // How many iterations per timeUnit
      rate: 30,
      // Start `rate` iterations per second
      timeUnit: '1s',
      // Pre-allocate 2 VUs before starting the test
      preAllocatedVUs: 2,
      // Spin up a maximum of 50 VUs to sustain the defined
      // constant arrival rate.
      maxVUs: 50,
export default function () {
  http.get('https://test.k6.io/contacts.php');
## Observations
The following graph depicts the performance of the [example](#example) script:
Based upon our test scenario inputs and results:
- The desired rate of 30 iterations started every 1 second is achieved and maintained for the majority of the test.
- The test scenario runs for the specified 30 second duration.
- Having started with 2 VUs (as specified by the `preAllocatedVUs` option), k6 automatically adjusts the number of VUs to achieve the desired rate, up to the `maxVUs`. For this test, this ended up as 17 VUs.
- The number of VUs to achieve the desired rate varies depending on how long each iteration takes to execute. For this test definition, if it would take exactly 1 second, then 30 VUs would be needed. However, as it takes less than 1 second, then less VUs are needed.
> Using too low of a `preAllocatedVUs` setting will reduce the test duration at the desired rate, as resources need to continually be allocated to achieve the rate.
