title: "HTTP Requests | Grafana k6 documentation"
description: "Define the HTTP requests and methods you want to use. k6 adds tags to the requests, making it easier to filter results. You can customize tags as you wish."
# HTTP Requests
When you create a new load test, one of the first steps is to define the HTTP requests that you would like to test.
## Make HTTP Requests
A GET request looks like this:
JavaScript ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```javascript
import http from 'k6/http';
export default function () {
  http.get('http://test.k6.io');
For something slightly more complex, this example shows a POST request with an email/password authentication payload:
```javascript
  const url = 'http://test.k6.io/login';
  const payload = JSON.stringify({
    email: 'aaa',
    password: 'bbb',
  const params = {
    headers: {
      'Content-Type': 'application/json',
  http.post(url, payload, params);
## Available methods
The [http module](/docs/k6/v2.3.x/javascript-api/k6-http/) handles all kinds of HTTP requests and methods.
Expand table
| Name                                                         | Value        |
| [batch()](/docs/k6/v2.3.x/javascript-api/k6-http/batch/)     | Issue multiple HTTP requests in parallel (like e.g. browsers tend to do). |
| [del()](/docs/k6/v2.3.x/javascript-api/k6-http/del/)         | Issue an HTTP DELETE request.                                             |
| [get()](/docs/k6/v2.3.x/javascript-api/k6-http/get/)         | Issue an HTTP GET request.                                                |
| [head()](/docs/k6/v2.3.x/javascript-api/k6-http/head/)       | Issue an HTTP HEAD request.                                               |
| [options()](/docs/k6/v2.3.x/javascript-api/k6-http/options/) | Issue an HTTP OPTIONS request.                                            |
| [patch()](/docs/k6/v2.3.x/javascript-api/k6-http/patch/)     | Issue an HTTP PATCH request.                                              |
| [post()](/docs/k6/v2.3.x/javascript-api/k6-http/post/)       | Issue an HTTP POST request.                                               |
| [put()](/docs/k6/v2.3.x/javascript-api/k6-http/put/)         | Issue an HTTP PUT request.                                                |
| [request()](/docs/k6/v2.3.x/javascript-api/k6-http/request/) | Issue any type of HTTP request.                                           |
## Follow redirects
By default, k6 automatically follows a set number of redirects before stopping and returning the last response. You can customize this by using:
- The `maxRedirects` option to customize the number of redirects globally. Refer to [Max redirects](/docs/k6/v2.3.x/using-k6/k6-options/reference/#max-redirects) for more details.
- The `Params.redirects` property to customize the number of redirects for a specific request, which overrides the `maxRedirects` option. Refer to [Params](/docs/k6/v2.3.x/javascript-api/k6-http/params/) for more details.
## HTTP Request Tags
k6 automatically applies [tags](/docs/k6/v2.3.x/using-k6/tags-and-groups/#section-tags) to your HTTP requests. You can use these tags to filter your results and organize your analysis.
Expand table
| Name               | Description        |
| expected\_response | By default, response statuses between 200 and 399 are `true`. Change the default behavior with [setResponseCallback](/docs/k6/v2.3.x/javascript-api/k6-http/set-response-callback/). |
| group              | When the request runs inside a [group](/docs/k6/v2.3.x/javascript-api/k6/group/), the tag value is the group name. Default is empty.                                                 |
| name               | Defaults to URL requested        |
| method             | Request method (`GET`, `POST`, `PUT` etc.)        |
| scenario           | When the request runs inside a [scenario](/docs/k6/v2.3.x/using-k6/scenarios/), the tag value is the scenario name. Default is `default`.                                            |
| status             | response status        |
| url                | defaults to URL requested        |
The following snippet shows a JSON example of how a test-result data point is logged. In this example, the metric is the duration of an HTTP request.
Note how the `tags` object groups data.
JSON ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```json
  "type": "Point",
  "metric": "http_req_duration",
  "data": {
    "time": "2017-06-02T23:10:29.52444541+02:00",
    "value": 586.831127,
    "tags": {
      "expected_response": "true",
      "group": "",
      "method": "GET",
      "name": "http://test.k6.io",
      "scenario": "default",
      "status": "200",
      "url": "http://test.k6.io"
## Group URLs under one tag
By default, tags have a `name` field that holds the value of the request URL. If your test has dynamic URL paths, you might not want this behavior, which could bring a large number of unique URLs into the metrics stream. For example, the following code accesses 100 different URLs:
```javascript
  for (let id = 1; id <= 100; id++) {
    http.get(`http://example.com/posts/${id}`);
// tags.name=\"http://example.com/posts/1\",
// tags.name=\"http://example.com/posts/2\",
You might prefer to report this data in a single metric: To aggregate data from dynamic URLs, explicitly set a `name` tag:
```javascript
    http.get(`http://example.com/posts/${id}`, {
      tags: { name: 'PostsItemURL' },
// tags.name=\"PostsItemURL\",
That code would produce JSON output like this:
```json
// For http://example.com/1, note that the url is not present in the JSON.
    "type":"Point",
    "metric":"http_req_duration",
    "data": {
        "time":"2017-06-02T23:10:29.52444541+02:00",
        "value":586.831127,
        "tags": {
            "method":"GET",
            "name":"PostsItemURL",
            "status":"200",
            "url":"PostsItemURL"
// and for http://example.com/2
    "type":"Point",
    "data": {
        "time":"2017-06-02T23:10:29.58582529+02:00",
        "value":580.839273,
        "tags": {
            "method":"GET",
            "status":"200",
Note how these two objects have the same `name`, despite having different URLs. If you filter the results for the tag `name: PostsItemURL`, the results include all data points from all 100 URLs.
As an alternative, you can also use the `http.url` wrapper to set the `name` tag with a string template value:
```javascript
    http.get(http.url`http://example.com/posts/${id}`);
// tags.name="http://example.com/posts/${}",
