This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/k6/v2.3.x/using-k6-browser/how-to-write-browser-tests/interact-with-elements.md, or by sending Accept: text/markdown to https://grafana.com/docs/k6/v2.3.x/using-k6-browser/how-to-write-browser-tests/interact-with-elements/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Interact with elements on your webpage
You can use page.locator() and pass in the element’s selector you want to find on the page. page.locator() will create and return a
Locator object, which you can later use to interact with the element.
To find out which selectors the browser module supports, check out Selecting Elements.
Note
You can also use
page.$()instead ofpage.locator(). You can find the differences betweenpage.locator()andpage.$in the Locator API documentation.
import { browser } from 'k6/browser';
export const options = {
scenarios: {
ui: {
executor: 'shared-iterations',
options: {
browser: {
type: 'chromium',
thresholds: {
checks: ['rate==1.0'],
export default async function () {
const page = await browser.newPage();
try {
await page.goto('https://test.k6.io/my_messages.php');
// Enter login credentials
await page.locator('input[name="login"]').type('admin');
await page.locator('input[name="password"]').type('123');
await page.screenshot({ path: 'screenshots/screenshot.png' });
} finally {
await page.close();
}The preceding code creates and returns a Locator object with the selectors for both login and password passed as arguments.
Within the Locator API, various methods such as type() can be used to interact with the elements. The type() method types a text to an input field.
Was this page helpful?
