title: "Interact with elements on your webpage | Grafana k6 documentation"
description: "Learn how to interact with elements on a webpage using the k6 browser module."
# Interact with elements on your webpage
You can use `page.locator()` and pass in the element’s selector you want to find on the page. `page.locator()` will create and return a [Locator](/docs/k6/v2.3.x/javascript-api/k6-browser/locator/) object, which you can later use to interact with the element.
To find out which selectors the browser module supports, check out [Selecting Elements](/docs/k6/v2.3.x/using-k6-browser/recommended-practices/selecting-elements/).
> Note
> You can also use `page.$()` instead of `page.locator()`. You can find the differences between `page.locator()` and `page.$` in the [Locator API documentation](/docs/k6/v2.3.x/javascript-api/k6-browser/locator/).
JavaScript ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```javascript
import { browser } from 'k6/browser';
export const options = {
  scenarios: {
    ui: {
      executor: 'shared-iterations',
      options: {
        browser: {
          type: 'chromium',
  thresholds: {
    checks: ['rate==1.0'],
export default async function () {
  const page = await browser.newPage();
  try {
    await page.goto('https://test.k6.io/my_messages.php');
    // Enter login credentials
    await page.locator('input[name="login"]').type('admin');
    await page.locator('input[name="password"]').type('123');
    await page.screenshot({ path: 'screenshots/screenshot.png' });
  } finally {
    await page.close();
The preceding code creates and returns a Locator object with the selectors for both login and password passed as arguments.
Within the Locator API, various methods such as `type()` can be used to interact with the elements. The `type()` method types a text to an input field.
