Searching...
See everything announced at ObservabilityCON 2026: AI that monitors your AI, faster log search, lower telemetry costs, and more.
DownloadsContact Us
Logo
  • Pricing
  • Docs
Sign inSign up
This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/k6/v2.3.x/using-k6-browser/how-to-write-browser-tests.md, or by sending Accept: text/markdown to https://grafana.com/docs/k6/v2.3.x/using-k6-browser/how-to-write-browser-tests/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Menu
Documentationbreadcrumb arrow Grafana k6breadcrumb arrow Using k6 browserbreadcrumb arrow How to write browser tests
Open source RSS
  • Asynchronous operations
  • Interact with elements on your webpage
Was this page helpful?
Suggest an edit in GitHub
Create a GitHub issue
Email docs@grafana.com
Help and support
Community
video icon
Video
Performance testing and observability in Grafana Cloud
Optimize user experiences with Grafana Cloud. Learn real-time insights, performance testing with k6, and continuous validation with Synthetic Monitoring.
video icon
Video
User-centered observability: load testing, real user monitoring, and synthetics
Learn how to use load testing, synthetic monitoring, and real user monitoring (RUM) to understand end users' experience of your apps. Watch on demand.
Technical documentation Plugin catalog
Choose a product
Viewing: v2.3.x (latest) Find another version
  • Grafana k6
  • Release notes
    • v2.3.0
    • v2.2.0
    • v2.1.0
    • v2.0.0
    • v1.8.2
    • v1.8.1
    • v1.8.0
    • v1.7.1
    • v1.7.0
    • v1.6.0
    • v1.5.0
    • v1.4.0
    • v1.3.0
    • v1.2.0
    • v1.1.0
    • v1.0.0
    • v0.57.0
    • v0.56.0
    • v0.55.0
    • v0.54.0
    • v0.53.0
    • v0.52.0
    • v0.51.0
    • v0.50.0
    • v0.49.0
    • v0.48.0
    • v0.47.0
  • Set up
    • Install k6
      • Troubleshooting
    • Configure your code editor
    • Configure your AI assistant
      • Bootstrap your editor with k6 x agent
      • Tools, prompts, and resources
    • Set up distributed k6
      • Install k6 Operator
      • Upgrade the k6 Operator
      • Run browser tests in Kubernetes
      • Usage
        • Run k6 scripts with TestRun CRD
        • Use k6 Operator with k6 extensions
        • Use the k6 Operator with Grafana Cloud k6
        • Configure the TestRun CRD
        • Schedule k6 tests
        • Use the k6 Operator with Istio
      • Troubleshoot
    • Fine-tune OS
    • Usage collection
  • Get started
    • Write your first test
    • Running k6
    • Results output
    • k6 resources
    • Migrate to k6 v2
  • Using k6
    • Analyze script dependencies
    • Run a k6 test script
    • Feature flags
    • HTTP Requests
    • Metrics
      • Built-in metrics
      • Create custom metrics
    • Checks
    • Assertions
    • Thresholds
    • Options
      • How to use options
      • Options reference
    • Test lifecycle
    • Modules
    • Tags and Groups
    • Cookies
    • Protocols
      • HTTP/2
      • WebSockets
      • gRPC
      • SSL/TLS
        • Online Certificate Status Protocol (OCSP)
        • SSL/TLS client certificates
        • SSL/TLS version and ciphers
    • Environment variables
    • Execution context variables
    • Scenarios
      • Concepts
        • Graceful stop
        • Arrival-rate VU allocation
        • Dropped iterations
        • Open and closed models
      • Executors
        • Shared iterations
        • Per VU iterations
        • Constant VUs
        • Ramping VUs
        • Constant arrival rate
        • Ramping arrival rate
      • Advanced Examples
    • Secret source
      • File
      • Mock
      • URL
      • Cloud
    • Test authoring
      • Create a test script using the CLI
      • Create a test script from an OpenAPI definition file
      • Test builder
      • Create tests from recordings
        • Using the browser recorder
        • Using the HAR converter
    • JavaScript and TypeScript mode
  • Using k6 browser
    • Write your first browser test
    • Running browser tests
    • How to write browser tests
    • Migrate a Playwright script to k6
    • Playwright APIs in k6
    • Recommended practices
      • Handle stale or dynamic elements after navigation
      • Hybrid approach to performance
      • Page object model
      • Prevent cookie banners from blocking interactions
      • Prevent too many time series error
      • Select elements
      • Simulate user input delay
      • Use Page.close to clean up test resources
      • When to use sleep() and page.waitForTimeout()
    • Browser metrics
    • Browser options
    • Migrating browser scripts to k6 v0.52
  • Results output
    • End of test
      • Custom summary
    • Real time
      • Amazon CloudWatch
      • Apache Kafka
      • CSV
      • Datadog
      • Dynatrace
      • Elasticsearch
      • Grafana Cloud k6
      • Grafana Cloud Prometheus
      • InfluxDB
      • JSON
      • Netdata
      • New Relic
      • OpenTelemetry
      • Prometheus remote write
      • StatsD
      • TimescaleDB
    • Web dashboard
    • Grafana dashboards
  • Testing guides
    • Load test types
      • Smoke testing
      • Average-load testing
      • Stress testing
      • Soak testing
      • Spike testing
      • Breakpoint testing
    • Automated performance testing
    • API load testing
    • Calculate concurrent users for load tests
    • Load testing websites
    • Performance testing gRPC services
    • Running distributed tests
    • Running large tests
    • Synthetic monitoring
    • Use Chai with k6
    • Injecting faults with xk6-disruptor
      • xk6-disruptor first steps
      • Requirements
      • Installation
      • Expose your application
      • How xk6-disruptor works
      • xk6-disruptor API
        • Faults
          • gRPC
          • HTTP
          • Pod Termination
        • PodDisruptor
          • Constructor
          • injectGrpcFaults()
          • injectHTTPFaults()
          • terminatePods()
        • ServiceDisruptor
          • Constructor
          • injectGrpcFaults
          • injectHTTPFaults
          • terminatePods()
      • xk6-disruptor examples
        • Inject gRPC faults into Service
        • Inject HTTP faults into Pod
        • Interactive demo
  • JavaScript API
    • Init context
      • open( filePath, [mode] )
    • k6
      • check( val, sets, [tags] )
      • fail( [err] )
      • group( name, fn )
      • randomSeed( int )
      • sleep( t )
    • k6/browser
      • BrowserContext
        • addCookies()
        • addInitScript()
        • clearCookies()
        • clearPermissions()
        • close()
        • Cookie
        • cookies([urls])
        • grantPermissions(permissions[, options])
        • newPage()
        • pages()
        • setDefaultNavigationTimeout(timeout)
        • setDefaultTimeout(timeout)
        • setGeolocation(geolocation)
        • setOffline(offline)
        • waitForEvent(event[, optionsOrPredicate])
      • Chromium
        • connectOverCDP(wsEndpoint)
      • ConsoleMessage
      • MetricMessage
      • ElementHandle
        • $(selector)
        • $$(selector)
        • boundingBox()
        • check([options])
        • click([options])
        • contentFrame()
        • dblclick([options])
        • dispatchEvent(type, eventInit)
        • fill(value, [options])
        • focus()
        • getAttribute(name)
        • hover([options])
        • innerHTML()
        • innerText()
        • inputValue([options])
        • isChecked()
        • isDisabled()
        • isEditable()
        • isEnabled()
        • isHidden()
        • isVisible()
        • ownerFrame
        • press(key, [options])
        • screenshot([options])
        • scrollIntoViewIfNeeded([options])
        • selectOption(values, [options])
        • selectText(values, [options])
        • setChecked(checked[, options])
        • setInputFiles(file[, options])
        • tap(options)
        • textContent()
        • type(text, [options])
        • uncheck([options])
        • waitForElementState(state[, options])
        • waitForSelector(selector[, options])
      • Frame
        • $(selector)
        • $$(selector)
        • check(selector[, options])
        • childFrames()
        • click(selector[, options])
        • content()
        • dblclick(selector[, options])
        • dispatchEvent(selector, type, eventInit[, options])
        • evaluate(pageFunction[, arg])
        • evaluateHandle(pageFunction[, arg])
        • fill(selector, value[, options])
        • focus(selector[, options])
        • frameElement()
        • frameLocator(selector)
        • getAttribute(selector, name[, options])
        • getByAltText(altText[, options])
        • getByLabel(text[, options])
        • getByPlaceholder(placeholder[, options])
        • getByRole(role[, options])
        • getByTestId(testId)
        • getByText(text[, options])
        • getByTitle(title[, options])
        • goto(url[, options])
        • hover(selector[, options])
        • innerHTML(selector[, options])
        • innerText(selector[, options])
        • inputValue(selector[, options])
        • isChecked(selector[, options])
        • isDetached()
        • isDisabled(selector[, options])
        • isEditable(selector[, options])
        • isEnabled(selector[, options])
        • isHidden(selector[, options])
        • isVisible(selector[, options])
        • locator(selector[, options])
        • name()
        • page()
        • parentFrame()
        • press(selector, key[, options])
        • selectOption(selector, values[, options])
        • setChecked(selector, checked[, options])
        • setContent(html[, options])
        • setInputFiles(selector, file[, options])
        • tap(selector[, options])
        • textContent(selector[, options])
        • title()
        • type(selector, text[, options])
        • uncheck(selector[, options])
        • url()
        • waitForFunction(pageFunction, options[, arg])
        • waitForLoadState(state[, options])
        • waitForNavigation([options])
        • waitForTimeout(timeout)
        • waitForURL(url[, options])
      • JSHandle
        • asElement()
        • dispose()
        • getProperties()
        • jsonValue()
      • Keyboard
        • down(key)
        • insertText(text)
        • press(key[, options])
        • type(text[, options])
        • up(key)
      • Locator
        • all()
        • boundingBox([options])
        • check([options])
        • clear([options])
        • click([options])
        • contentFrame()
        • count()
        • dispatchEvent(type, eventInit, [options])
        • filter(options)
        • first()
        • focus([options])
        • getAttribute(name, [options])
        • hover([options])
        • innerHTML([options])
        • innerText([options])
        • isChecked([options])
        • isDisabled([options])
        • isEditable([options])
        • isEnabled([options])
        • isHidden()
        • isInViewport([options])
        • isVisible()
        • last()
        • nth(number)
        • pressSequentially(text, [options])
        • tap([options])
        • textContent([options])
        • waitFor([options])
      • FrameLocator
      • Mouse
        • click(x, y[, options])
        • dblclick(x, y[, options])
        • down([options])
        • move(x, y[, options])
        • up([options])
      • Page
        • $(selector)
        • $$(selector)
        • bringToFront()
        • close()
        • content()
        • context()
        • emulateMedia([options])
        • emulateVisionDeficiency(type)
        • frames()
        • goBack([options])
        • goForward([options])
        • isClosed()
        • keyboard
        • mainFrame()
        • mouse
        • on(event, handler)
        • opener()
        • reload([options])
        • route(url, handler)
        • setExtraHTTPHeaders(headers)
        • setViewportSize(viewportSize)
        • throttleCPU(cpuProfile)
        • throttleNetwork(networkProfile)
        • title()
        • touchscreen
        • unroute(url)
        • unrouteAll()
        • url()
        • viewportSize()
        • waitForRequest(urlPattern[, options])
        • waitForResponse(urlPattern[, options])
        • workers()
      • Request
        • allHeaders()
        • frame()
        • headers()
        • headersArray()
        • headerValue(name)
        • isNavigationRequest()
        • method()
        • postData()
        • postDataBuffer()
        • resourceType()
        • response()
        • size()
        • timing()
        • url()
      • Response
        • allHeaders()
        • body()
        • frame()
        • headers()
        • headersArray()
        • headerValue(name)
        • headerValues(name)
        • json()
        • ok()
        • request()
        • securityDetails()
        • serverAddr()
        • size()
        • status()
        • statusText()
        • text()
        • url()
      • Route
        • abort([errorCode])
        • continue([options])
        • fulfill(options)
        • request()
      • Touchscreen
        • tap()
      • Worker
        • url()
      • close()
      • closeContext()
      • context()
      • isConnected()
      • newContext([options])
      • newPage([options])
      • page.on("requestfailed")
      • page.on("requestfinished")
      • version()
    • k6/crypto
      • createHash( algorithm )
      • createHMAC( algorithm, secret )
      • hmac( algorithm, secret, data, outputEncoding )
      • md4( input, outputEncoding )
      • md5( input, outputEncoding )
      • randomBytes( int )
      • ripemd160( input, outputEncoding )
      • sha1( input, outputEncoding )
      • sha256( input, outputEncoding )
      • sha384( input, outputEncoding )
      • sha512( input, outputEncoding )
      • sha512_256( input, outputEncoding )
      • sha512_224( input, outputEncoding )
      • Hasher
    • k6/data
      • SharedArray
    • k6/encoding
      • b64decode( input, [encoding], [format] )
      • b64encode( input, [encoding] )
    • k6/execution
    • k6/experimental
      • csv
        • parse( file, [options] )
        • Parser
        • Options
      • fs
        • File
          • read
          • seek
          • stat
        • open
        • FileInfo
        • SeekMode
      • streams
        • ReadableStream
          • cancel(reason)
          • getReader()
          • CountQueuingStrategy
        • ReadableStreamDefaultReader
          • cancel(reason)
          • read()
          • releaseLock()
        • ReadableStreamDefaultController
          • close()
          • enqueue(chunk)
          • error(reason)
    • k6/html
      • parseHTML( src )
      • Element
        • Element.selection()
      • Selection
        • Selection.attr(name)
        • Selection.children([selector])
        • Selection.closest(selector)
        • Selection.contents()
        • Selection.data([key])
        • Selection.each(fn)
        • Selection.eq(index)
        • Selection.filter(selector)
        • Selection.find(selector)
        • Selection.first()
        • Selection.get(index)
        • Selection.has(selector)
        • Selection.html()
        • Selection.is(selector)
        • Selection.last()
        • Selection.map(fn)
        • Selection.next([selector])
        • Selection.nextAll([selector])
        • Selection.nextUntil([selector], [filter])
        • Selection.not(selector)
        • Selection.parent([selector])
        • Selection.parents([selector])
        • Selection.parentsUntil([selector], [filter])
        • Selection.prev([selector])
        • Selection.prevAll([selector])
        • Selection.prevUntil([selector], [filter])
        • Selection.serialize()
        • Selection.serializeArray()
        • Selection.serializeObject()
        • Selection.single(selector)
        • Selection.size()
        • Selection.slice(start [, end])
        • Selection.text()
        • Selection.toArray()
        • Selection.val()
    • k6/http
      • asyncRequest( method, url, [body], [params] )
      • batch( requests )
      • cookieJar()
      • del( url, [body], [params] )
      • file( data, [filename], [contentType] )
      • get( url, [params] )
      • head( url, [params] )
      • options( url, [body], [params] )
      • patch( url, [body], [params] )
      • post( url, [body], [params] )
      • put( url, [body], [params] )
      • request( method, url, [body], [params] )
      • setResponseCallback( callback )
      • url\`url\`
      • expectedStatuses( statuses )
      • CookieJar
        • CookieJar.clear(url)
        • CookieJar.cookiesForURL(url)
        • CookieJar.delete(url, name)
        • CookieJar.set(url, name, value, [options])
      • FileData
      • Params
      • Response
        • Response.clickLink( [params] )
        • Response.html()
        • Response.json( [selector] )
        • Response.submitForm( [params] )
    • k6/metrics
      • Counter
        • Counter.add(value, [tags])
      • Gauge
        • Gauge.add(value, [tags])
      • Rate
        • Rate.add(value, [tags])
      • Trend
        • Trend.add(value, [tags])
    • k6/net/grpc
      • Client
        • Client.load(importPaths, ...protoFiles)
        • Client.loadProtoset(protosetPath)
        • Client.connect(address [,params])
        • Client.asyncInvoke(url, request [,params])
        • Client.invoke(url, request [,params])
        • Client.close()
        • Client.healthCheck()
      • Params
      • Response
      • Stream
        • Stream.on()
        • Error
        • Stream.end()
        • Stream.write()
        • Event Handler
        • Metadata
      • Constants
    • k6/secrets
    • k6/timers
    • k6/ws
      • connect( url, params, callback )
      • Params
      • Socket
        • Socket.close([code])
        • Socket.on(event, callback)
        • Socket.ping()
        • Socket.send(data)
        • Socket.sendBinary(data)
        • Socket.setInterval(callback, interval)
        • Socket.setTimeout(callback, delay)
    • k6/x/dns
      • resolve( query, recordType, nameserver )
      • lookup( hostname )
    • k6/x/icmp
      • ping( target, [options] )
      • pingAsync( target, [optsOrCallback], [callback] )
      • PingOptions
      • PingDetail
      • IP
    • k6/x/mqtt
      • Client
        • Client.connect( url, [options] )
        • Client.reconnect()
        • Client.subscribe( topic, [options] )
        • Client.subscribeAsync( topic, [options] )
        • Client.unsubscribe( topics, [options] )
        • Client.unsubscribeAsync( topics, [options] )
        • Client.publish( topic, payload, [options] )
        • Client.publishAsync( topic, payload, [options] )
        • Client.on( event, listener )
        • Client.end( [options] )
        • Client.endAsync( [options] )
    • k6/x/tcp
      • Socket
        • Socket.connect( port, [host] )
        • Socket.write( data, [options] )
        • Socket.destroy()
        • Socket.setTimeout( timeout )
        • Socket.on( event, listener )
    • k6/x/tls
    • k6/x/redis
      • Client
        • Client.decr(key)
        • Client.decrBy(key, decrement)
        • Client.del(keys)
        • Client.exists(keys)
        • Client.expire(key, seconds)
        • Client.get(key)
        • Client.getDel(key)
        • Client.getSet(key, value)
        • Client.hdel(key, fields)
        • Client.hget(key, field)
        • Client.hgetall(key)
        • Client.hincrby(key, field, increment)
        • Client.hkeys(key)
        • Client.hlen(key)
        • Client.hset(key, field, value)
        • Client.hsetnx(key, field, value)
        • Client.hvals(key)
        • Client.incr(key)
        • Client.incrBy(key, increment)
        • Client.lindex(key)
        • Client.llen(key)
        • Client.lpop(key)
        • Client.lpush(key, values)
        • Client.lrange(key, start, stop)
        • Client.lrem(key, count, value)
        • Client.lset(key, index, element)
        • Client.mget(keys)
        • Client.persist(key)
        • Client.randomKey()
        • Client.rpop(key)
        • Client.rpush(key, values)
        • Client.sadd(key, members)
        • Client.sendCommand(command, args)
        • Client.set(key, value, expiration)
        • Client.sismember(key, member)
        • Client.smembers(key)
        • Client.spop(key)
        • Client.srandmember(key)
        • Client.srem(key, members)
        • Client.ttl(key)
      • Options
    • Error Codes
    • crypto
      • getRandomValues
      • CryptoKey
      • randomUUID
      • SubtleCrypto
        • decrypt
        • deriveBits
        • digest
        • deriveKey
        • encrypt
        • exportKey
        • generateKey
        • importKey
        • sign
        • verify
      • AesCbcParams
      • AesCtrParams
      • AesGcmParams
      • RsaOaepParams
      • AesKeyGenParams
      • CryptoKeyPair
      • EcKeyGenParams
      • EcdhKeyDeriveParams
      • EcdsaParams
      • Pbkdf2Params
      • RsaPssParams
      • HmacKeyGenParams
      • RsaHashedImportParams
      • RSAHashedKeyGenParams
      • JsonWebKey
    • jslib
      • aws
        • AWSConfig
        • EventBridgeClient
          • putEvents
        • KinesisClient
          • createStream
          • deleteStream
          • getRecords
          • getShardIterator
          • listShards
          • listStreams
          • putRecords
        • KMSClient
          • generateDataKey
          • listKeys
          • KMSDataKey
          • KMSKey
        • LambdaClient
          • invoke
        • S3Client
          • abortMultipartUpload
          • completeMultipartUpload
          • copyObject
          • createMultipartUpload
          • deleteObject
          • getObject
          • listBuckets
          • listObjects
          • putObject
          • uploadPart
          • Bucket
          • Object
          • S3MultipartUpload
          • S3Part
          • S3UploadedObject
        • SecretsManagerClient
          • createSecret
          • deleteSecret
          • getSecret
          • listSecrets
          • putSecretValue
          • Secret
        • SignatureV4
          • presign
          • sign
        • SQSClient
          • deleteMessage
          • listQueues
          • receiveMessages
          • sendMessage
          • sendMessageBatch
        • SystemsManagerClient
          • getParameter
          • SystemsManagerParameter
      • httpx
        • asyncRequest(method, url, [body], [params])
        • request(method, url, [body], [params])
        • get(url, [body], [params])
        • post(url, [body], [params])
        • put(url, [body], [params])
        • patch(url, [body], [params])
        • delete(url, [body], [params])
        • options(url, [body], [params])
        • head(url, [body], [params])
        • trace(url, [body], [params])
        • batch( requests )
        • setBaseUrl( url )
        • addHeader( key, value )
        • addHeaders( object )
        • clearHeader( name )
        • addTag( key, value )
        • addTags( object )
        • clearTag( name )
      • k6chaijs
        • config
        • describe( name, function )
        • expect()
        • Error handling
      • http-instrumentation-pyroscope
        • instrumentHTTP
        • Client
      • http-instrumentation-tempo
        • instrumentHTTP
        • Client
        • Options
      • utils
        • randomIntBetween(min, max)
        • randomItem(array)
        • randomString(length, [charset])
        • uuidv4()
        • findBetween(content, left, right, [repeat])
        • normalDistributionStages(maxVus, durationSeconds, [numberOfStages])
      • totp
        • TOTP(secret, [digits])
        • TOTP.gen([timeStep], [bias])
        • TOTP.verify(code, [timeStep])
      • k6-testing
        • expect()
        • expect.configure()
        • Non-Retrying Assertions
          • toBe()
          • toEqual()
          • toContain()
          • toBeTruthy()
          • toBeFalsy()
          • toBeDefined()
          • toBeGreaterThan()
          • toBeCloseTo()
          • toHaveLength()
          • toHaveProperty()
          • toBeGreaterThanOrEqual()
          • toBeLessThan()
          • toBeNull()
          • toBeUndefined()
          • toContainEqual()
          • toBeLessThanOrEqual()
          • toBeInstanceOf()
          • toBeNaN()
        • Retrying Assertions
          • toBeChecked()
          • toBeDisabled()
          • toBeEditable()
          • toBeEmpty()
          • toBeHidden()
          • toBeVisible()
          • toHaveText()
          • toContainText()
          • toBeEnabled()
          • toHaveAttribute()
          • toHaveValue()
          • toHaveTitle()
          • RetryConfig
    • websockets
      • Blob
      • WebSocket
        • WebSocket.addEventListener(event, handler)
        • WebSocket.send(data)
        • WebSocket.close([code])
        • WebSocket.ping()
        • WebSocket.onclose
        • WebSocket.onerror
        • WebSocket.onmessage
        • WebSocket.onopen
        • WebSocket.onping
        • WebSocket.onpong
      • Params
    • import.meta
      • resolve( path )
  • Extensions
    • Explore extensions
    • Run a test with extensions
      • Build a k6 binary using Go
      • Build a k6 binary using Docker
    • Create an extension
      • Quick start guide
      • Create an extension with a template
      • JavaScript extensions
      • Output extensions
      • Secret source extensions
      • Subcommand extensions
      • About the Extensions Registry
      • About the Go-to-JS bridge
    • Submit an extension
    • Add a new version
    • Decommission an extension
  • Examples
    • Get started with k6
      • Test for functional behavior
      • Test for performance
      • Analyze results
      • Reuse and re-run tests
    • Single request
    • HTTP Authentication
    • OAuth Authentication
    • Correlation and Dynamic Data
    • Data parameterization
    • Parse HTML
    • HTML Forms
    • Cookies Example
    • Data Uploads
    • API CRUD Operations
    • Generating UUIDs
    • HTTP2
    • Use global variables in k6
    • WebSockets
    • SOAP
    • Transport Layer Security (TLS)
    • Generating realistic data
    • Bundling and transpiling
    • Functional testing
    • Track transmitted data per URL
    • URLs with query parameters
    • Instant load increase
    • Get timings for an HTTP metric
    • Distribute workloads across VUs
    • Error handler
    • Tutorials
  • Reference
    • Integrations & Tools
    • Archive Command
    • Cloud commands
    • Glossary
    • Versioning and stability guarantees
  • Grafana k6 Studio
  • Grafana Cloud k6
  • Copyright notice
Scroll for more
Read this in Grafana Cloud
Is this page helpful?
Still have questions?
Ask your questions. Let AI do the heavy lifting.
Ask AI icon
Newsletter icon
Get every update
Subscribe to our newsletter
By submitting, you agree to our Privacy policy
  • Overview
  • Pricing
  • What's in the free tier?
  • AI Assistant
  • Agent Observability
  • Application Observability
  • Kubernetes Monitoring
  • Dashboards & Visualization
  • Database Observability
  • Frontend Observability
  • Synthetic Monitoring
  • Performance & Load Testing
  • Incident Response & Management
  • AI Investigations
  • What’s New
  • Grafana Cloud Status
Solutions
  • AI Observability
  • Full-Stack Observability
  • Infrastructure & Cloud Observability
  • Digital Experience Monitoring
  • Scaled Prometheus
  • Cost Management & Optimization
  • Site Reliability
  • Log Management
  • Migrate to OpenTelemetry
Integrations
  • All Integrations
  • All Plugins
  • AWS
  • Google Cloud
  • Microsoft Azure
  • Kubernetes
  • Datadog
  • New Relic
Open Source
  • Our Projects
  • GitHub
  • Downloads
  • Dashboard Templates
Learn
  • Documentation
  • Blog
  • Community
  • Events
  • Observability Survey & Reports
Company
  • About Grafana Labs
  • Careers
  • Partnerships
  • Newsroom
  • Success Stories
  • Contact Us
  • Getting Help
  • Professional Services
  • Hey AI
Compare
  • Datadog vs. Grafana Cloud
  • Dynatrace vs. Grafana Cloud
  • Elasticsearch vs. Grafana Cloud
  • New Relic vs. Grafana Cloud
  • PagerDuty vs. Grafana Cloud
  • Splunk vs. Grafana Cloud
Grafana Labs x unique logomark
Donut take our word for it. Try Grafana Cloud today.
Grafana Cloud StatusLegal & SecurityTerms of ServicePrivacy PolicyTrademark Policy
Copyright 2026 © Grafana Labs
