This is documentation for the next version of Grafana k6 documentation. For the latest stable release, go to the latest version.
Workaround to calculate iteration_duration
A common requested case is to track the iteration_duration metric without including time spent for setup and teardown functions.
This feature is not yet available but a threshold on iteration_duration or any pre-existing metrics can be used as a workaround.
It’s based on the concept of creating thresholds for sub-metrics created by tags for the required scope and setting the criteria that always pass. It works with any enabled tags that already works with threshold, for example:
iteration_duration{scenario:default}generates a sub-metric collecting samples only for the default scenario’s iteration.scenario:defaultis used because that’s the internal k6 scenario name when we haven’t specifiedoptions.scenarios` explicitly and are just using the execution shortcuts instead.iteration_duration{group:::setup}oriteration_duration{group:::teardown}create sub-metrics collecting the duration only forsetupandteardown.k6implicitly creates groups forsetupandteardown, and::is the group separator.http_req_duration{scenario:default}can be useful as well for isolating executed long-running requests.
import { sleep } from 'k6';
import http from 'k6/http';
export const options = {
vus: 1,
iterations: 1,
thresholds: {
'iteration_duration{scenario:default}': [`max>=0`],
'iteration_duration{group:::setup}': [`max>=0`],
'iteration_duration{group:::teardown}': [`max>=0`],
'http_req_duration{scenario:default}': [`max>=0`],
export function setup() {
http.get('https://quickpizza.grafana.com/api/delay/5');
export default function () {
http.get('http://test.k6.io/?where=default');
sleep(0.5);
export function teardown() {
http.get('https://quickpizza.grafana.com/api/delay/3');
sleep(5);
}Dedicated sub-metrics have been generated collecting samples only for the scope defined by thresholds:
█ THRESHOLDS
✓ 'max>=0' max=117.34ms
✓ 'max>=0' max=0s
✓ 'max>=0' max=0s
✓ 'max>=0' max=1.13s
