title: "Test authoring | Grafana k6 documentation"
description: "Test authoring Create a test script using the CLI Create a test script from an OpenAPI definition file Test builder Create tests from recordings"
# Test authoring
- [Create a test script using the CLI](/docs/k6/next/using-k6/test-authoring/create-test-script-using-the-cli/)
- [Create a test script from an OpenAPI definition file](/docs/k6/next/using-k6/test-authoring/create-test-script-using-openapi/)
- [Test builder](/docs/k6/next/using-k6/test-authoring/test-builder/)
- [Create tests from recordings](/docs/k6/next/using-k6/test-authoring/create-tests-from-recordings/)
