title: "Secret source | Grafana k6 documentation"
description: "Secret sources let k6 retrieve and use secrets securely"
# Secret source
Secret sources provide a secure way for k6 to retrieve and use secrets. Unlike values from environment variables or files, values from secret sources are automatically redacted from k6 logs before propagation through the system.
Access secrets through the [`k6/secrets`](/docs/k6/next/javascript-api/k6-secrets/) JavaScript API. All secrets are redacted from logs.
## Configure secret sources
Configure secret sources using the `--secret-source` CLI flag. You can configure multiple secret sources simultaneously.
## Built-in secret sources
The following built-in secret sources are available for local testing:
- [`file`](/docs/k6/next/using-k6/secret-source/file/): Reads secrets from a `key=value` file.
- [`mock`](/docs/k6/next/using-k6/secret-source/mock/): Reads secrets from CLI arguments.
- [`url`](/docs/k6/next/using-k6/secret-source/url/): Fetches secrets from HTTP endpoints.
The following built-in secret source is available for `k6 cloud run --local-execution`:
- [`cloud`](/docs/k6/next/using-k6/secret-source/cloud/): Fetches secrets from [Grafana Cloud k6](/docs/k6/next/grafana-cloud-k6/).
## Secret source extensions
You can implement a secret source as an [extension](/docs/k6/next/extensions/) for k6.
## Example script
JavaScript ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```javascript
import http from 'k6/http';
import secrets from 'k6/secrets';
export default async () => {
  const my_secret = await secrets.get('cool'); // Retrieves secret by identifier
  console.log(my_secret);
  const response = await http.asyncRequest('GET', 'https://httpbin.org/get', null, {
    headers: {
      'Custom-Authentication': `Bearer ${await secrets.get('else')}`,
  console.log(response.body);
Run the script with the following secrets file:
text ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```text
cool=some
else=source
The following output shows how secrets are redacted in logs, shown as `***SECRET_REDACTED***`, while remaining accessible to the script.
Bash ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```bash
$ k6 run --secret-source=file=file.secret secrets.test.js
INFO[0000] ***SECRET_REDACTED***                         source=console
INFO[0001] {
  "args": {},
  "headers": {
    "Custom-Authentication": "Bearer ***SECRET_REDACTED***",
    "Host": "httpbin.org",
    "User-Agent": "k6/0.57.0 (https://k6.io/)",
    "X-Amzn-Trace-Id": "Root=1-67dd638b-4243896a2fa1b1b45bc63eaa"
  "origin": "<my actual IP>",
  "url": "https://httpbin.org/get"
}  ***SECRET_REDACTED***=console
