title: "Analyze script dependencies | Grafana k6 documentation"
description: "Use the k6 deps command to analyze dependencies for your k6 test scripts."
# k6 deps command
The `k6 deps` command analyzes your k6 test script and outputs information about the dependencies your script uses.
## Usage
Bash ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```bash
k6 deps [options] <script>
## Description
When you run `k6 deps`, k6 analyzes your test script and its imports to identify k6 extensions (such as `k6/x/faker`, `k6/x/redis`) and k6 itself that your script uses.
The command outputs dependency information in human-readable format by default, or JSON format with the `--json` flag. You can use this information to:
- Understand what k6 extensions your script uses
- Share dependency information with your team
- Use it to know if you need a custom binary or if the current one can run the script
The command, like [automatic extension resolution](/docs/k6/next/extensions/run/#use-automatic-extension-resolution), is only able to find dependencies using import/export syntax and “use” directives in already found files. It doesn’t follow potential `require` calls.
The command also takes into account any provided [dependency manifest](/docs/k6/next/using-k6/k6-options/reference/#dependency-manifest) and applies it during `k6 run`.
## Options
Expand table
| Option   | Description        |
| `--json` | Output dependency information in JSON format. Without this flag, the output is human-readable. |
## Examples
### Generate dependency information
Analyze your test script and output dependency information:
```bash
k6 deps script.js
This outputs dependency information in human-readable format to stdout.
### Generate JSON output
Output the dependency information in JSON format:
```bash
k6 deps --json script.js
## Output format
The `k6 deps` command outputs dependency information in human-readable format by default. When using the `--json` flag, the output is a JSON object.
### Human-readable output
The default human-readable output shows:
- **Build Dependencies:** Lists k6 extensions and k6 itself with version constraints (or `(none)` if there are no build dependencies)
- **Imports:** Lists all imports including file paths and module names
- **Custom Build Required:** Indicates `yes` or `no` whether a custom build is required
Example:
```none
Build Dependencies:
  k6: >1.2.0
  k6/x/faker: *
Imports:
  file:///path/to/script.js
  k6/execution
  k6/x/faker
Custom Build Required: yes
### JSON output
When using the `--json` flag, the output is a JSON object with three fields:
- `buildDependencies`: An object mapping k6 extension names (or `k6` itself) to version constraints
- `imports`: An array of strings listing all imports
- `customBuildRequired`: A boolean indicating whether a custom build is required
Example:
JSON ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```json
  "buildDependencies": {
    "k6": ">1.2.0",
    "k6/x/faker": "*"
  "imports": [
    "file:///path/to/script.js",
    "k6/execution",
    "k6/x/faker"
  "customBuildRequired": true
