title: "Prevent cookie banners from blocking interactions | Grafana k6 documentation"
description: "How to reveal and dismiss cookie banners in k6 browser tests to prevent blocked interactions and improve test reliability."
# Prevent cookie banners from blocking interactions
Cookie banners often appear shortly after a page loads or remain hidden until you interact with the page. Leaving a banner open can block page elements and cause interaction failures. For example, a button might not be clickable because the banner overlaps it. If you find yourself using *force click* frequently, the element is likely hidden or overlapped by a cookie banner.
To avoid these failures, trigger and dismiss the cookie banner early in the test flow.
- **Trigger the banner**: simulate a small user action, such as clicking or scrolling, immediately after navigation to reveal banners that appear only after interaction.
- **Dismiss the banner**: once the banner is visible, close or accept it before continuing with the rest of the test.
## Example
The example below navigates to a page and clicks a button. Replace the placeholder steps with a click to an element on your website, or scrolling a page, that reveals and dismisses your site’s cookie banner.
JavaScript ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```javascript
import { browser } from 'k6/browser';
import { expect } from 'https://jslib.k6.io/k6-testing/0.6.1/index.js';
export const options = {
  scenarios: {
    ui: {
      executor: 'shared-iterations',
      options: {
        browser: {
          type: 'chromium',
  thresholds: {
    checks: ['rate==1.0'],
export default async function () {
  const page = await browser.newPage();
  try {
    await page.goto('https://quickpizza.grafana.com/');
    // Click an element to trigger a cookie banner.
    // Clicking an element also scrolls the page if the
    // element is outside the frame.
    const button = page.locator('button[name="pizza-please"]')
    await expect(button).toBeEnabled();
    await button.click();
    // Dismiss the cookie banner
    const cookieBannerButton = page.locator('button[name="dismiss-cookie"]')
  } finally {
    await page.close();
