title: "Page object model | Grafana k6 documentation"
description: "An example on how to implement page object model design pattern with k6 browser"
# Page object model
When working with large test suites, a popular design pattern to improve your code’s maintainability and readability is the [page object model](https://martinfowler.com/bliki/PageObject.html).
A page object commonly represents an HTML page or significant elements/components within a page, such as a header or a footer. It’s a form of encapsulation that hides the details of the UI structure from other places, such as your test files. Through page object models, any changes you need to make on a specific page or element within a page are constrained into a single place, resulting in ease of maintenance and avoiding code duplication.
Since k6 browser is inspired by Playwright, you can leverage any existing page objects you have and re-use them with your k6 browser tests.
## Implementation
Let’s take an example of a website with a booking form added to the homepage. Imagine you want to write a test that checks that a user can fill out the booking form successfully.
To model a page object for the homepage, we’ve created a page object class called `homepage.js`. Different locators are created inside the constructor so that when the homepage class is instantiated, the page locator elements are ready to be used.
The `homepage.js` class also contains different methods for:
- Navigating to the homepage
- Submitting the form
- Getting the verification message
When locators need to be updated or other specific changes related to the homepage are made, you only need to update the `homepage.js` class.
JavaScript ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```javascript
import { bookingData } from '../data/booking-data.js';
export class Homepage {
  constructor(page) {
    this.page = page;
    this.nameField = page.locator('[data-testid="ContactName"]');
    this.emailField = page.locator('[data-testid="ContactEmail"]');
    this.phoneField = page.locator('[data-testid="ContactPhone"]');
    this.subjectField = page.locator('[data-testid="ContactSubject"]');
    this.descField = page.locator('[data-testid="ContactDescription"]');
    this.submitButton = page.locator('#submitContact');
    this.verificationMessage = page.locator('.row.contact h2');
  async goto() {
    await this.page.goto('https://myexamplewebsite/');
  async submitForm() {
    const { name, email, phone, subject, description } = bookingData;
    this.nameField.type(name);
    this.emailField.type(email);
    this.phoneField.type(phone);
    this.subjectField.type(subject);
    this.descField.type(description);
    await this.submitButton.click();
  async getVerificationMessage() {
    return this.verificationMessage.innerText();
You can import the `Homepage` class within your test class and invoke the methods you need. This makes the code easier to understand and enforces the separation between your test and business logic.
```javascript
import { browser } from 'k6/browser';
import { expect } from 'https://jslib.k6.io/k6chaijs/4.3.4.0/index.js';
import { Homepage } from '../pages/homepage.js';
export default async function () {
  const page = await browser.newPage();
  const { name } = bookingData;
  const homepage = new Homepage(page);
  await homepage.goto();
  await homepage.submitForm();
  expect(await homepage.getVerificationMessage()).to.contain(name);
  await page.close();
