title: "Migrating browser scripts to k6 v0.52 | Grafana k6 documentation"
description: "A migration guide to ease the process of transitioning to the new k6 browser module version bundled with k6 v0.52"
# Migrating browser scripts to k6 v0.52
This guide outlines the key changes you will need to make when moving your existing k6 experimental browser test scripts to the *latest* [k6 browser module](/docs/k6/next/javascript-api/k6-browser/) version bundled with [k6 0.52](https://github.com/grafana/k6/releases/tag/v0.52.0).
## Key changes
In the latest release of k6, we have graduated k6 browser module out of experimental and is now under the import `k6/browser`. Migrating to this is a breaking change that will affect *all scripts* that use the experimental k6 browser module. The breaking changes are:
1. Converted most of the k6 browser module APIs to asynchronous (async) APIs. That means they will return a `promise` that will `resolve` to a value when the API call succeeds or `reject` when an error occurs.
2. A side effect of making this async changes is that you will need to use [the `check` utility function from jslib.k6.io](/docs/k6/next/javascript-api/jslib/utils/check/) instead of working with the k6 [check](/docs/k6/next/javascript-api/k6/check/) API.
3. Finally, it’s also worth reiterating that the [group](/docs/k6/next/javascript-api/k6/group/) API still doesn’t work with async APIs.
If you are interested in the rationale behind this change, refer to the [v0.51 release notes](https://github.com/grafana/k6/releases/tag/v0.51.0).
> Note
> The experimental import (`k6/experimental/browser`) and the corresponding synchronous APIs will be supported up until the 23rd of September 2024.
## Migrating to async
To ensure your scripts work with the latest release of the k6 browser module, you must:
1. Change the import from `k6/experimental/browser` to `k6/browser`.
2. Ensure that all the synchronous (sync) APIs that have been migrated over to async are handled appropriately. In most cases, you will only need to add `await` in front of the API call.
For example, before:
JavaScript ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```javascript
import { browser } from 'k6/experimental/browser';
export default async function () {
    const page = browser.newPage();
And now:
```javascript
import { browser } from 'k6/browser';
    const page = await browser.newPage();
You might have already encountered async APIs when working with the browser module, such as [page.click](/docs/k6/next/javascript-api/k6-browser/page/click/), so the use of `async` and `await` keywords might be familiar to you.
Below is a screenshot of a comparison between a generic browser test in `v0.51` and `v0.52` to help visualize the change:
### The affected APIs
List of APIs to be migrated to async
Expand table
| Class          | Method                       |
| Browser        | closeContext                 |
| Browser        | context                      |
| Browser        | newContext                   |
| Browser        | newPage                      |
| Browser        | userAgent                    |
| BrowserContext | addCookies                   |
| BrowserContext | addInitScript                |
| BrowserContext | browser                      |
| BrowserContext | clearCookies                 |
| BrowserContext | clearPermissions             |
| BrowserContext | close                        |
| BrowserContext | cookies                      |
| BrowserContext | grantPermissions             |
| BrowserContext | newPage                      |
| BrowserContext | setGeolocation               |
| BrowserContext | setOffline                   |
| ElementHandle  | $                            |
| ElementHandle  | $$                           |
| ElementHandle  | boundingBox                  |
| ElementHandle  | check                        |
| ElementHandle  | contentFrame                 |
| ElementHandle  | dblclick                     |
| ElementHandle  | dispatchEvent                |
| ElementHandle  | fill                         |
| ElementHandle  | focus                        |
| ElementHandle  | getAttribute                 |
| ElementHandle  | hover                        |
| ElementHandle  | innerHTML                    |
| ElementHandle  | innerText                    |
| ElementHandle  | inputValue                   |
| ElementHandle  | isChecked                    |
| ElementHandle  | isDisabled                   |
| ElementHandle  | isEditable                   |
| ElementHandle  | isEnabled                    |
| ElementHandle  | isHidden                     |
| ElementHandle  | isVisible                    |
| ElementHandle  | ownerFrame                   |
| ElementHandle  | press                        |
| ElementHandle  | screenshot                   |
| ElementHandle  | scrollIntoViewIfNeeded       |
| ElementHandle  | selectOption                 |
| ElementHandle  | selectText                   |
| ElementHandle  | setInputFiles                |
| ElementHandle  | tap                          |
| ElementHandle  | textContent                  |
| ElementHandle  | type                         |
| ElementHandle  | uncheck                      |
| ElementHandle  | waitForElementState          |
| ElementHandle  | waitForSelector              |
| Frame          | $                            |
| Frame          | $$                           |
| Frame          | check                        |
| Frame          | content                      |
| Frame          | dblclick                     |
| Frame          | dispatchEvent                |
| Frame          | evaluate&lt;R, Arg&gt;       |
| Frame          | evaluateHandle&lt;R, Arg&gt; |
| Frame          | fill                         |
| Frame          | focus                        |
| Frame          | frameElement                 |
| Frame          | getAttribute                 |
| Frame          | hover                        |
| Frame          | innerHTML                    |
| Frame          | innerText                    |
| Frame          | inputValue                   |
| Frame          | isChecked                    |
| Frame          | isDisabled                   |
| Frame          | isEditable                   |
| Frame          | isEnabled                    |
| Frame          | isHidden                     |
| Frame          | isVisible                    |
| Frame          | press                        |
| Frame          | selectOption                 |
| Frame          | setContent                   |
| Frame          | setInputFiles                |
| Frame          | tap                          |
| Frame          | textContent                  |
| Frame          | title                        |
| Frame          | type                         |
| Frame          | uncheck                      |
| Frame          | waitForLoadState             |
| Frame          | waitForSelector              |
| Frame          | waitForTimeout               |
| JSHandle       | asElement                    |
| JSHandle       | dispose                      |
| JSHandle       | evaluate&lt;R, Arg&gt;       |
| JSHandle       | evaluateHandle&lt;R, Arg&gt; |
| JSHandle       | getProperties                |
| JSHandle       | jsonValue                    |
| Keyboard       | down                         |
| Keyboard       | insertText                   |
| Keyboard       | press                        |
| Keyboard       | type                         |
| Keyboard       | up                           |
| Locator        | check                        |
| Locator        | clear                        |
| Locator        | dblclick                     |
| Locator        | dispatchEvent                |
| Locator        | fill                         |
| Locator        | focus                        |
| Locator        | getAttribute                 |
| Locator        | hover                        |
| Locator        | innerHTML                    |
| Locator        | innerText                    |
| Locator        | inputValue                   |
| Locator        | isChecked                    |
| Locator        | isDisabled                   |
| Locator        | isEditable                   |
| Locator        | isEnabled                    |
| Locator        | isHidden                     |
| Locator        | isVisible                    |
| Locator        | press                        |
| Locator        | selectOption                 |
| Locator        | tap                          |
| Locator        | textContent                  |
| Locator        | type                         |
| Locator        | uncheck                      |
| Locator        | waitFor                      |
| Mouse          | click                        |
| Mouse          | dblclick                     |
| Mouse          | down                         |
| Mouse          | move                         |
| Mouse          | up                           |
| Page           | $                            |
| Page           | $$                           |
| Page           | bringToFront                 |
| Page           | check                        |
| Page           | close                        |
| Page           | content                      |
| Page           | dblclick                     |
| Page           | dispatchEvent                |
| Page           | emulateMedia                 |
| Page           | emulateVisionDeficiency      |
| Page           | evaluate&lt;R, Arg&gt;       |
| Page           | evaluateHandle&lt;R, Arg&gt; |
| Page           | fill                         |
| Page           | focus                        |
| Page           | getAttribute                 |
| Page           | hover                        |
| Page           | innerHTML                    |
| Page           | innerText                    |
| Page           | inputValue                   |
| Page           | isChecked                    |
| Page           | isDisabled                   |
| Page           | isEditable                   |
| Page           | isEnabled                    |
| Page           | isHidden                     |
| Page           | isVisible                    |
| Page           | on                           |
| Page           | opener                       |
| Page           | press                        |
| Page           | reload                       |
| Page           | screenshot                   |
| Page           | selectOption                 |
| Page           | setContent                   |
| Page           | setExtraHTTPHeaders          |
| Page           | setInputFiles                |
| Page           | setViewportSize              |
| Page           | tap                          |
| Page           | textContent                  |
| Page           | throttleCPU                  |
| Page           | throttleNetwork              |
| Page           | title                        |
| Page           | type                         |
| Page           | uncheck                      |
| Page           | viewportSize                 |
| Page           | waitForLoadState             |
| Page           | waitForSelector              |
| Page           | waitForTimeout               |
| Request        | allHeaders                   |
| Request        | headerValue                  |
| Request        | headersArray                 |
| Request        | postData                     |
| Request        | resourceType                 |
| Request        | response                     |
| Request        | size                         |
| Request        | timing                       |
| Response       | allHeaders                   |
| Response       | body                         |
| Response       | headerValue                  |
| Response       | headerValues                 |
| Response       | headersArray                 |
| Response       | json                         |
| Response       | securityDetails              |
| Response       | serverAddr                   |
| Response       | size                         |
| Touchscreen    | tap                          |
## Working with k6 check
The k6 `check` API will not `await` promises, so calling a function that returns a `Promise`, for example `locator.textContent()`, inside one of the predicates will not work. Instead, you can work with [the jslib.k6.io’s `check` utility function](/docs/k6/latest/javascript-api/jslib/utils/check/).
```javascript
check(page.locator('h2'), {
  header: (lo) => lo.textContent() == 'Welcome, admin!',
And now:
```javascript
import { check } from 'https://jslib.k6.io/k6-utils/1.5.0/index.js';
await check(page.locator('h2'), {
  header: async (lo) => (await lo.textContent()) === 'Welcome, admin!',
## Groups
A note on [groups](/docs/k6/next/using-k6/tags-and-groups/#groups), they don’t work with async APIs either, there is no workaround as of yet. Here’s the [GitHub issue](https://github.com/grafana/k6/issues/2728) that you can follow to keep up-to-date with relevant news on a group API that works with async APIs.
## Migrating from k6 v0.45 or below
If you use k6 v0.45 or below, first review [how to migrate to v0.46](/docs/k6/v0.51.x/migrating-to-k6-v0-46/). This guide details the breaking changes introduced in v0.46 for the `browser` APIs and provides instructions on how to migrate to them.
# Where to get extra help
With the release of k6 `v0.52`, you’ll also be able to find the latest type definitions and updates to the [k6 browser documentation](/docs/k6/next/javascript-api/k6-browser/). Refer to [Configure k6 IntelliSense](/docs/k6/next/set-up/configure-k6-intellisense/) for details on how to work with the type definition file in your project.
For all the details, review the CHANGELOG for [k6 version 0.52](https://github.com/grafana/k6/releases/tag/v0.52.0). You can also ask questions in [the community forum](https://community.grafana.com/c/grafana-k6/k6-browser/79) if you need help.
