title: "Running distributed tests | Grafana k6 documentation"
description: "How to run distributed tests in Kubernetes"
# Running distributed tests
It has already been established that k6 can [run large load tests](/docs/k6/next/testing-guides/running-large-tests/) from a single instance, but what about *multiple instances running a single test*?
Several reasons why you may wish to run a distributed test include:
- Your [system under test](/docs/k6/next/reference/glossary/#system-under-test) (SUT) should be accessed from multiple IP addresses.
- A fully optimized node cannot produce the load required by your extremely large test.
- Kubernetes is already your preferred operations environment.
For scenarios such as these, we’ve created the [k6-operator](https://github.com/grafana/k6-operator).
> Note
> Refer to [Use the k6 Operator with Grafana Cloud k6](/docs/k6/latest/set-up/set-up-distributed-k6/usage/k6-operator-to-gck6/) on how to integrate the k6 Operator with Grafana Cloud, including creating [Private Load Zones](/docs/grafana-cloud/testing/k6/author-run/private-load-zone-v2/).
## Introducing k6-operator
[k6-operator](https://github.com/grafana/k6-operator) is an implementation of the [operator pattern](/docs/k6/next/reference/glossary/#operator-pattern) in Kubernetes, defining [custom resources](/docs/k6/next/reference/glossary/#custom-resource) in Kubernetes. The intent is to automate tasks that a *human operator* would normally do; tasks like provisioning new application components, changing configurations, or resolving run-time issues.
The k6-operator defines the custom `TestRun` resource type and listens for changes to, or creation of, `TestRun` objects. Each `TestRun` object references a k6 test script, configures the environment, and specifies the number of instances, as `parallelism`, for a test run. Once a change is detected, the operator will react by modifying the cluster state, spinning up k6 test jobs as needed.
## Get started with k6-operator
Let’s walk through the process for getting started with the k6-operator. The only requirement being access to a Kubernetes cluster and having the appropriate access and tooling.
> Note
> This process can be performed on a local Kubernetes cluster running within [Docker](https://docs.docker.com/get-docker/)! Using [kind](https://kind.sigs.k8s.io/) or [k3d](https://k3d.io/) are awesome options to experiment with the process.
- [Introducing k6-operator](#introducing-k6-operator)
- [Get started with k6-operator](#get-started-with-k6-operator)
- [1. Install the operator](#1-install-the-operator)
- [2. Create a test script](#2-create-a-test-script)
- [3. Add test scripts](#3-add-test-scripts)
  - [Add as a ConfigMap](#add-as-a-configmap)
  - [Add inside a PersistentVolume](#add-inside-a-persistentvolume)
- [4. Create a custom resource](#4-create-a-custom-resource)
  - [Script in a ConfigMap](#script-in-a-configmap)
  - [Script in a PersistentVolume](#script-in-a-persistentvolume)
  - [Configure the environment](#configure-the-environment)
  - [Change command-line arguments](#change-command-line-arguments)
- [5. Run your test](#5-run-your-test)
- [6. When things go wrong](#6-when-things-go-wrong)
- [See also](#see-also)
## 1. Install the operator
The first step to running distributed tests in Kubernetes is to install the operator if not already installed in the cluster.
> Note
> Besides privileged access to a Kubernetes cluster, installation will require that the system performing the installation has the following tools installed:
> - [Kubectl](https://kubernetes.io/docs/tasks/tools/#kubectl)
Ensure that your `kubectl` tool is set for the appropriate Kubernetes cluster.
Then, from your command-line, execute the following:
shell ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```shell
curl https://raw.githubusercontent.com/grafana/k6-operator/main/bundle.yaml | kubectl apply -f -
Refer to [Install k6 Operator](/docs/k6/latest/set-up/set-up-distributed-k6/install-k6-operator/) for other installation methods.
By default, the operator will be installed into a new namespace, `k6-operator-system`. You can verify the successful installation by listing available resources within the namespace:
```shell
kubectl get pod -n k6-operator-system
After a few moments, your resulting status should become `Running` as shown below:
Bash ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```bash
NAME                                              READY   STATUS    RESTARTS   AGE
k6-operator-controller-manager-7664957cf7-llw54   2/2     Running   0          160m
You are now ready to start create and execute test scripts!
## 2. Create a test script
Creating k6 test scripts for Kubernetes is no different from creating the script for the command-line. If you haven’t already created test cases for your system, then we suggest having a read through one of our guides for creating tests for websites and APIs/microservices:
- [Website testing guide](/docs/k6/next/testing-guides/load-testing-websites/)
- [API testing guide](/docs/k6/next/testing-guides/api-load-testing/)
In general, it is advised to start small and expand on your scripts over iterations. So let’s start simple and create a `test.js` with the following content:
JavaScript ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```javascript
import http from 'k6/http';
import { sleep } from 'k6';
export const options = {
  vus: 10,
  duration: '10s',
export default function () {
  http.get('https://test.k6.io/');
  sleep(1);
> Note
> While creating scripts, [run them locally](/docs/k6/next/get-started/running-k6/#running-local-tests) before publishing to your cluster. This can give you immediate feedback if you have errors in your script.
Let’s go ahead and verify our script is valid by performing a brief test:
```shell
k6 run test.js
We should see a successful execution and resulting output summary.
## 3. Add test scripts
In order for your test scripts to be run, they must be published into your cluster. Two main methods for this are using [ConfigMap](https://kubernetes.io/docs/concepts/configuration/configmap/) or [PersistentVolume](https://kubernetes.io/docs/concepts/storage/persistent-volumes/) resources.
### Add as a ConfigMap
Using a `ConfigMap` is a quick and straightforward mechanism for adding your test scripts to Kubernetes. The `kubectl` tool provides a convenient method to create a new `ConfigMap` from a local script.
Let’s create our ConfigMap as `my-test` with the content of our `test.js` script we created in the previous step:
```shell
kubectl create configmap my-test --from-file test.js
> Caution
> Limitations exist on how large your test script can be when deployed within a `ConfigMap`. Kubernetes imposes a size limit of 1,048,576 bytes (1 MiB) for the data, therefore if your test scripts exceed this limit, you’ll need to mount a `PersistentVolume`.
> Check the [motivations](https://kubernetes.io/docs/concepts/configuration/configmap/#motivation) for when you should use a `ConfigMap` versus a `PersistentVolume`.
You should see confirmation with `configmap/my-test created`.
### Add inside a PersistentVolume
Setting up a `PersistentVolume` is beyond the scope of this guide, but enables access to a shared filesystem from your Kubernetes cluster via `PersistentVolumeClaim`.
When using this option, organize your test scripts in the applicable filesystem just as you would locally. This mechanism is ideal when breaking up monolithic scripts into reusable [modules](/docs/k6/next/using-k6/modules/).
> Note
> Organizing your test scripts was part of the discussion during [episode #76](https://www.youtube.com/watch?v=zDtEzp_JUOE&utm=k6-guides) of k6 Office Hours.
> Caution
> When using a `PersistentVolume`, the operator will expect all test scripts to be contained within a directory named `/test/`.
To learn more about creating `PersistentVolume` and `PersistentVolumeClaim` resources, review the [Kubernetes documentation](https://kubernetes.io/docs/concepts/storage/persistent-volumes/).
## 4. Create a custom resource
During [installation](#1-install-the-operator), the `TestRun` [Custom Resource definition](https://kubernetes.io/docs/concepts/extend-kubernetes/api-extension/custom-resources/) was added to the Kubernetes API. The data we provide in the custom resource `TestRun` object should contain all the information necessary for the k6-operator to start a distributed load test.
Specifically, the main elements defined within the `TestRun` object relate to the name and location of the test script to run, and the amount of [parallelism](/docs/k6/next/reference/glossary/#parallelism) to utilize.
> Note
> The `TestRun` custom resource provides many configuration options to control the initialization and execution of tests. For the full listing of possible options, please refer to the project [source](https://github.com/grafana/k6-operator/blob/main/config/crd/bases/k6.io_testruns.yaml) and [README](https://github.com/grafana/k6-operator/blob/main/README.md).
The following examples will show some common variations for the custom resource:
### Script in a ConfigMap
When the test script to be executed is contained within a `ConfigMap` resource, we specify the script details within the `configMap` block of [YAML](/docs/k6/next/reference/glossary/#yaml). The `name` is the name of the ConfigMap and the `file` is the key-value for the entry.
Let’s create the file `run-k6-from-configmap.yaml` with the following content:
YAML ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```yaml
apiVersion: k6.io/v1alpha1
kind: TestRun
metadata:
spec:
  parallelism: 4
  script:
    configMap:
      file: test.js
Recall when the script was [added as a ConfigMap](#add-as-a-configmap) for our configuration values. We created the ConfigMap named `my-test`. The test script content was added to the map using the filename as the key-value, therefore the `file` value is `test.js`.
The amount of `parallelism` is up to you; how many pods do you want to split the test amongst? The operator will split the workload between the pods using [execution segments](/docs/k6/next/reference/glossary/#execution-segment).
> Caution
> It is important that the `ConfigMap` and `CustomResource` are created in the same [Namespace](https://kubernetes.io/docs/concepts/overview/working-with-objects/namespaces/).
### Script in a PersistentVolume
If the test script to be executed is contained within a `PersistentVolume`, creation of a [PersistentVolumeClaim](https://kubernetes.io/docs/concepts/storage/persistent-volumes/#persistentvolumeclaims) will be required. We won’t go into the details of PersistentVolumes and PersistentVolumeClaims, but to learn more, you should review the [Kubernetes documentation](https://kubernetes.io/docs/concepts/storage/persistent-volumes/).
Assume we’ve created a `PersistentVolumeClaim` named `my-volume-claim` against a `PersistentVolume` containing the test script `/test/test.js`, we can create the file `run-k6-from-volume.yaml` with the following content:
```yaml
kind: TestRun
metadata:
spec:
  parallelism: 4
  script:
    volumeClaim:
      # File is relative to /test/ directory within volume
      file: test.js
> Caution
> It is important that the `PersistentVolumeClaim` and `CustomResource` are created in the same [Namespace](https://kubernetes.io/docs/concepts/overview/working-with-objects/namespaces/).
### Configure the environment
Not everything should be included directly in your scripts. Well written scripts will allow for variability to support multiple scenarios and to avoid hard-coding values that tend to change. These could be anything from passwords to target urls, in addition to system options.
We can pass this data as [environment variables](/docs/k6/next/reference/glossary/#environment-variables) for use with each pod executing your script. This can be defined explicitly within the `TestRun` resource, or by referencing a `ConfigMap` or `Secret`.
```yaml
kind: TestRun
metadata:
spec:
  parallelism: 4
  script:
    configMap:
      file: test.js
  runner:
    env:
      - name: MY_CUSTOM_VARIABLE
        value: 'this is my variable value'
    envFrom:
      - configMapRef:
      - secretRef:
> Note
> The above YAML introduces the `runner` section. This section applies to each pod that will be running a portion of your test, based upon the desired `parallelism`.
Now, with the referenced resources, our test scripts can [use environment variables](/docs/k6/next/using-k6/environment-variables/) as in the following:
```javascript
export function setup() {
  console.log(`Variable is set as: ${__ENV.MY_CUSTOM_VARIABLE}`);
### Change command-line arguments
[k6 options](/docs/k6/next/using-k6/k6-options/) can be specified in many ways, one being the command-line. Specifying options via command-line can still be accomplished when using the operator as shown with the following example:
```yaml
kind: TestRun
metadata:
spec:
  parallelism: 4
  script:
    configMap:
      file: test.js
  arguments: --tag testid=run-k6-with-args --log-format json
With the above arguments, we’re adding a [test-wide custom tag](/docs/k6/next/using-k6/tags-and-groups/#test-wide-tags) to metrics and changing the output format of logs to [JSON](/docs/k6/next/reference/glossary/#json).
> Note
> Be sure to visit the [options reference](/docs/k6/next/using-k6/k6-options/reference/) for a listing of available options.
## 5. Run your test
Tests are executed by applying the custom resource `TestRun` to a cluster where the operator is running. The test configuration is applied as in the following:
```shell
kubectl apply -f /path/to/your/k6-resource.yaml
After completing a test run, you need to clean up the test jobs created. This is done by running the following command:
```shell
kubectl delete -f /path/to/your/k6-resource.yaml
> Note
> If you make use of [real-time results output](/docs/k6/next/results-output/real-time/), e.g. [Prometheus Remote Write](/docs/k6/next/results-output/real-time/prometheus-remote-write/), use the `cleanup` option to automatically remove resources upon test completion as with the following example:
> ```yaml
kind: TestRun
metadata:
spec:
  parallelism: 4
  # Removes all resources upon completion
  cleanup: post
  script:
    configMap:
      file: test.js
  arguments: -o experimental-prometheus-rw
## 6. When things go wrong
Sadly nothing works perfectly all the time, so knowing where you can go for help is important.
Be sure to check the [troubleshooting guide](/docs/k6/latest/set-up/set-up-distributed-k6/troubleshooting/) as it contains many common pitfalls.
You can also search the [k6-operator category in the community forum](https://community.grafana.com/c/grafana-k6/k6-operator/73). k6 has a growing and helpful community of engineers working with k6-operator, so there’s a good chance your issue has already been discussed and overcome. It’s also in these forums where you’ll be able to get help from members of the k6 development team.
## See also
Here are some additional resources to help on your learning journey:
- [Distributed load testing using Kubernetes with k6 (k6 Office Hours #72)](https://www.youtube.com/watch?v=5d5zxsGz8L4)
- [Demo for k6-operator](https://github.com/javaducky/demo-k6-operator)
- [Blog: Running distributed k6 tests on Kubernetes](https://k6.io/blog/running-distributed-tests-on-k8s/)
