title: "Web dashboard | Grafana k6 documentation"
description: "Track test results in real-time with the web-dashboard and generate HTML test reports directly from your web browser."
# Web dashboard
k6 provides a built-in web dashboard that you can enable to visualize and monitor your tests results in real-time.
The dashboard provides a real-time overview of the performance observed by k6 while a test is running, and can help you identify potential reliability issues as they occur.
## How to use
The web dashboard is a built-in feature of k6. You can enable it by setting the `K6_WEB_DASHBOARD` environment variable to `true` when running your test script, for example:
shell ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```shell
K6_WEB_DASHBOARD=true k6 run script.js
```shell
K6_WEB_DASHBOARD=true ./k6 run script.js
         /\      Grafana   /‾‾/
    /\  /  \     |\  __   /  /
 / __________ \  |_|\_\  \_____/
     execution: local
        script: ../extensions/xk6-dashboard/script.js
 web dashboard: http://127.0.0.1:5665
        output: -
By default, the web dashboard is available on localhost port `5665`. You can change the host and port by using the [dashboard options](#dashboard-options).
> Note
> The k6 process waits to exit as long as there’s at least one open browser window for the dashboard extension.
> In certain environments, such as a CI/CD pipeline, the k6 process has to exit after the test run completes. In that case, it’s advisable to disable the HTTP port by setting it to `-1`.
## Generate HTML test reports
You can generate detailed, downloadable HTML reports directly from the web dashboard or the command line. These reports are self-contained, making them ideal for sharing with your team.
### Generate report from web dashboard
To generate a report from the web dashboard, click **Report** on the dashboard’s menu.
### Generate report from the command line
To automatically generate a report from the command line once the test finishes running, use the `K6_WEB_DASHBOARD_EXPORT` option. For example:
```shell
K6_WEB_DASHBOARD=true K6_WEB_DASHBOARD_EXPORT=html-report.html k6 run script.js
> Note
> The report only includes graphs if the test duration is greater than three times the aggregation period value, set by the `K6_WEB_DASHBOARD_PERIOD` variable.
## Dashboard options
The web dashboard can be configured using environment variables:
Expand table
| Environment variable      | Description        | Default value |
| `K6_WEB_DASHBOARD`        | Enable the web dashboard        | `false`       |
| `K6_WEB_DASHBOARD_HOST`   | Host to bind the web dashboard to        | `localhost`   |
| `K6_WEB_DASHBOARD_PORT`   | Port to bind the web dashboard to        | `5665`        |
| `K6_WEB_DASHBOARD_PERIOD` | Period in seconds to update the web dashboard        | `10s`         |
| `K6_WEB_DASHBOARD_OPEN`   | Open the web dashboard in the default browser        | `false`       |
| `K6_WEB_DASHBOARD_EXPORT` | Filename to automatically export the HTML test report to at the end of the test run. By default, the value is empty and the report isn’t exported. | \`\`          |
