title: "Running k6 | Grafana k6 documentation"
description: "Follow along to learn how to run a test, add virtual users, increase the test duration, and ramp the number of requests up and down as the test runs."
# Running k6
Follow along to learn how to:
1. Run a test.
2. Add virtual users.
3. Increase the test duration.
4. Ramp the number of requests up and down as the test runs.
With these example snippets, you’ll run the test with your machine’s resources. But, if you have a k6 Cloud account, you can also use the `k6 cloud run` command to outsource the test to k6 servers.
## Before you begin
- [Install k6](/docs/k6/next/set-up/install-k6/) on your machine.
## Run local tests
To run a simple local script:
1. Create and initialize a new script by running the following command:
   linux docker windows
   ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
   linux ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
   ```linux
   k6 new
   docker ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
   ```docker
   docker run --rm -u $(id -u) -v $PWD:/app -w /app grafana/k6 new
   windows ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
   ```windows
   docker run --rm -i -v ${PWD}:/app -w /app grafana/k6 new
   This command creates a new script file named `script.js` in the current directory. You can also specify a different file name as an argument to the `k6 new` command, for example `k6 new my-test.js`.
2. Run k6 with the following command:
   ```linux
   k6 run script.js
   ```docker
   # When using the `k6` docker image, you can't just give the script name since
   # the script file will not be available to the container as it runs. Instead
   # you must tell k6 to read `stdin` by passing the file name as `-`. Then you
   # pipe the actual file into the container with `<` or equivalent. This will
   # cause the file to be redirected into the container and be read by k6.
   docker run --rm -i grafana/k6 run - <script.js
   ```windows
   cat script.js | docker run --rm -i grafana/k6 run -
## Add VUs
Now run a load test with more than one virtual user and a longer duration:
```linux
k6 run --vus 10 --duration 30s script.js
```docker
docker run --rm -i grafana/k6 run --vus 10 --duration 30s - <script.js
```windows
cat script.js | docker run --rm -i grafana/k6 run --vus 10 --duration 30s -
*Running a 30-second, 10-VU load test*
> Note
> k6 runs multiple iterations in parallel with *virtual users* (VUs). In general terms, more virtual users means more simulated traffic.
> VUs are essentially parallel `while(true)` loops. Scripts are written in JavaScript, as ES6 modules, so you can break larger tests into smaller pieces or make reusable pieces as you like.
### The init context and the default function
For a test to run, you need to have *init code*, which prepares the test, and *VU code,* which makes requests.
Code in the init context defines functions and configures the test options (like `duration`).
Every test also has a `default` function, which defines the VU logic.
JavaScript ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```javascript
// init
export default function () {
  // vu code: do things here...
Init code runs first and is called only once per VU. The `default` code runs as many times or as long as is configured in the test options.
To learn more about how k6 executes, read about the [Test lifecycle](/docs/k6/next/using-k6/test-lifecycle/).
## Set options
Instead of typing `--vus 10` and `--duration 30s` each time you run the script, you can set the options in your JavaScript file:
```javascript
import http from 'k6/http';
import { sleep } from 'k6';
export const options = {
  vus: 10,
  duration: '30s',
  http.get('http://test.k6.io');
  sleep(1);
If you run the script without flags, k6 uses the options defined in the script:
```linux
k6 run script.js
```docker
```windows
## Ramp VUs up and down in stages
You can ramp the number of VUs up and down during the test. To configure ramping, use the `options.stages` property.
```javascript
import { check, sleep } from 'k6';
  stages: [
    { duration: '30s', target: 20 },
    { duration: '1m30s', target: 10 },
    { duration: '20s', target: 0 },
  const res = http.get('https://quickpizza.grafana.com/');
  check(res, { 'status was 200': (r) => r.status == 200 });
  sleep(1);
For more granular ramp configuration, you can use [scenarios](/docs/k6/next/using-k6/scenarios/) and the `ramping-vus` executor.
## Execution modes
> Note
> Portability is a major design goal of k6.
> You can run the same test in different modes with minimal changes.
k6 supports three execution modes to run a k6 test: local, distributed, and cloud.
- **Local**: the test execution happens entirely on a single machine, container, or CI server.
  Bash ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
  ```bash
  k6 run script.js
- **Distributed**: the test execution is [distributed across a Kubernetes cluster](/docs/k6/next/set-up/set-up-distributed-k6/).
  Save the following YAML as `k6-testrun-resource.yaml`:
  YAML ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
  ```yaml
  apiVersion: k6.io/v1alpha1
  kind: TestRun
  metadata:
  spec:
    parallelism: 4
    script:
      configMap:
        file: 'script.js'
  Apply the resource with the following command:
  ```bash
  kubectl apply -f /path/to/k6-testrun-resource.yaml
- **Cloud**: the test runs on [Grafana Cloud k6](/docs/grafana-cloud/testing/k6/get-started/run-cloud-tests-from-the-cli/).
  ```bash
  k6 cloud run script.js
  Additionally, cloud-based solutions can run cloud tests on your [own cloud infrastructure](/docs/grafana-cloud/testing/k6/author-run/private-load-zone-v2/), and accept the test results from a [local](/docs/k6/next/results-output/real-time/cloud/) or [distributed test](https://github.com/grafana/k6-operator#k6-cloud-output).
