title: "Tags and Groups | Grafana k6 documentation"
description: "k6 provides the Tags and Groups APIs to help you during the analysis and easily visualize, sort and filter your test results."
# Tags and Groups
A load test usually targets a service with different subsystems and resources. This can make it hard to pinpoint the issues that are degrading performance.
To help you visualize, sort, and filter your test results, k6 adds the following to your results.
- *Tags* categorize your checks, thresholds, custom metrics, and requests for in-depth filtering.
- *Groups* apply tags to the script’s functions.
Besides these granular tags, you can also use options to set test-wide tags. You can use these tags to compare results from multiple tests.
In addition to filtering results, you can also [use tags to limit the operations that your thresholds analyze](/docs/k6/latest/using-k6/thresholds/#thresholds-on-tags).
## Tags
Tags are a powerful way to categorize your k6 entities and filter test results.
k6 provides two types of tags:
- **System tags.** Tags that k6 automatically assigns.
- **User-defined tags.** Tags that you add when you write your script.
### System tags
Currently, k6 automatically creates the following tags by default:
Expand table
| Tag                 | Description        |
| `proto`             | the name of the protocol used (e.g. `HTTP/1.1`)        |
| `subproto`          | the subprotocol name (used by websockets)        |
| `status`            | the HTTP status code (e.g. `200`, `404`, etc.)        |
| `method`            | the HTTP method name (e.g. `GET`, `POST`, etc.) or the RPC method name for gRPC        |
| `url`               | the HTTP request URL        |
| `name`              | the HTTP [request name](/docs/k6/latest/using-k6/http-requests/#url-grouping)        |
| `group`             | the full [group](#groups) path, see the preceding explanation for details about its value        |
| `check`             | the [Check](/docs/k6/latest/using-k6/checks/) name        |
| `error`             | a string with a non-HTTP error message (e.g. network or DNS error)        |
| `error_code`        | A number specifying an error types; a list of current error codes can be found at the [Error Codes](/docs/k6/latest/javascript-api/error-codes/) page                |
| `tls_version`       | the [TLS](/docs/k6/latest/using-k6/protocols/ssl-tls/) version        |
| `scenario`          | the name of the scenario where the metric was emitted        |
| `service`           | the RPC service name for gRPC        |
| `expected_response` | `true` or `false` based on the [responseCallback](/docs/k6/latest/javascript-api/k6-http/set-response-callback/); by default checks whether the status is 2xx or 3xx |
To disable some of the preceding tags, use the [`systemTags` option](/docs/k6/latest/using-k6/k6-options/reference/#system-tags). Note that some data collectors, for example `cloud` runs, may require certain tags.
The following system tags are optional. Enable them as needed:
Expand table
| Tag           | Description        |
| `vu`          | the ID of the virtual user that executed the request        |
| `iter`        | the iteration number        |
| `ip`          | The IP address of the remote server        |
| `ocsp_status` | the [Online Certificate Status Protocol (OCSP)](/docs/k6/latest/using-k6/protocols/ssl-tls/online-certificate-status-protocol--ocsp/) HTTPS status |
## User-defined tags
Define your own tags to categorize k6 entities based on your test logic. You can tag the following entities:
- requests
- checks
- thresholds
- custom metrics
JavaScript ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```javascript
import http from 'k6/http';
import { Trend } from 'k6/metrics';
import { check } from 'k6';
const myTrend = new Trend('my_trend');
export default function () {
  // Add tag to request metric data
  const res = http.get('https://quickpizza.grafana.com/', {
    tags: {
      my_tag: "I'm a tag",
  // Add tag to check
  check(res, { 'status is 200': (r) => r.status === 200 }, { my_tag: "I'm a tag" });
  // Add tag to custom metric
  myTrend.add(res.timings.connecting, { my_tag: "I'm a tag" });
## Test-wide tags
Besides attaching tags to requests, checks, and custom metrics, you can set test-wide tags across all metrics. You can set these tags in two ways:
- In the CLI, using one or more `--tag NAME=VALUE` flags
- In the script itself:
  ```javascript
  export const options = {
    tags: {
## Code-defined tags
In the case, a user-defined tag with advanced logic for handling which tag to set is required then it’s possible doing it by defining the tag from the code.
To support advanced tagging workflows, it is also possible to directly set and get them from scripts’ code.
[k6/execution.vu.tags](/docs/k6/latest/javascript-api/k6-execution/#vu) object’s properties can indeed be directly assigned new key/value pairs to define new tags dynamically. This can prove useful, as demonstrated in the following example, to track a container’s group from nested groups, and aggregating nested group’s sub-metrics.
```javascript
import exec from 'k6/execution';
import { group } from 'k6';
  thresholds: {
    'http_reqs{container_group:main}': ['count==3'],
    'http_req_duration{container_group:main}': ['max<1000'],
  exec.vu.tags.containerGroup = 'main';
  group('main', function () {
    http.get('https://test.k6.io');
    group('sub', function () {
      http.get('https://quickpizza.grafana.com/');
    http.get('https://quickpizza.grafana.com/api/headers');
  delete exec.vu.tags.containerGroup;
  http.get('https://quickpizza.grafana.com/api/delay/3');
Using the same API, you can also retrieve any already set user-defined or system-defined tag:
```javascript
  const tag = exec.vu.tags['scenario'];
  console.log(tag); // default
## Tagging stages
Thanks to some helper functions in the [k6-jslib-utils](/docs/k6/latest/javascript-api/jslib/utils/) project, if an executor supports the `stages` option, you can add tags with the current ongoing stage. Similar to other tags tag, the tag is added to all samples collected during the iteration.
One way to tag the executed operations is to invoke the `tagWithCurrentStageIndex` function for setting a `stage` tag for identifying the stage that has executed them:
```javascript
import { tagWithCurrentStageIndex } from 'https://jslib.k6.io/k6-utils/1.3.0/index.js';
  stages: [
    { target: 5, duration: '2s' },
    { target: 10, duration: '5s' },
  tagWithCurrentStageIndex();
  // all the requests will have a `stage` tag
  // with its value equal to the index of the stage
  http.get('https://test.k6.io'); // e.g. {stage: "1"}
Additionally, a profiling function `tagWithCurrentStageProfile` can add a tag with a computed profile of the current running stage:
```javascript
import { tagWithCurrentStageProfile } from 'https://jslib.k6.io/k6-utils/1.3.0/index.js';
  stages: [{ target: 2, duration: '5s' }],
  tagWithCurrentStageProfile();
  // all the requests are tagged with a `stage` tag
  // with the index of the stage as value
  http.get('https://test.k6.io'); // {stage_profile: ramp-up}
The profile value based on the current stage can be one of the following options:
Expand table
| Profile     | Description                                                             |
| `ramp-up`   | The current stage has a target greater than the previous stage’s target |
| `steady`    | The current stage has a target equal to the previous stage’s target     |
| `ramp-down` | The current stage has a target less than the previous stage’s target    |
## Tags in results output
JSON JSON
JSON ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```json
  "type ": "Point ",
  "data ": {
    "time ": "2017-05-09T14:34:45.239531499+02:00 ",
    "value ": 459.865729,
    "tags ": {
      "group ": "::my group::json ",
      "method ": "GET ",
      "status ": "200 ",
      "url ": "http://quickpizza.grafana.com"
  "metric ": "http_req_duration "
```json
  "type ": "Point ",
  "data ": {
    "time ": "2017-05-09T14:34:45.625742514+02:00 ",
    "value ": 5,
    "tags ": null
  "metric ": "vus "
To see how tags affect your test-result output, refer to the [k6 results output syntax](/docs/k6/latest/results-output/real-time/json/).
## Groups
For extra organization, use *groups* to organize a load script by functions. You can also nest groups for BDD-style testing.
All metrics emitted in a [group](/docs/k6/latest/javascript-api/k6/group/) have the tag `group` with a value of all wrapping group names separated by `::` (two colons). The root group uses the name ’’ (empty string). If you have a single group named `cool requests`, the actual value of the `group` is `::cool requests`.
For example, you could use groups to organize multiple requests by page loads or user actions.
```javascript
  group('visit product listing page', function () {
  group('add several products to the shopping cart', function () {
  group('visit login page', function () {
  group('authenticate', function () {
  group('checkout process', function () {
Groups do the following tasks internally:
- For each `group()` function, k6 emits a [group\_duration metric](/docs/k6/latest/using-k6/metrics/), which contains the total time to execute the group function.
- When a taggable resource—a check, request, or custom metric—runs within a group, k6 sets the tag `group` with the current group name. For more info, refer to the [Tags section](/docs/k6/latest/using-k6/tags-and-groups/#tags).
Both options, the `group_duration` metric and `group tagging`, could help you analyze and visualize complex test results. Check out how they work in your [k6 result output](/docs/k6/latest/reference/integrations/#result-store-and-visualization).
### Discouraged: one group per request
Wrapping each request within a group might add unnecessary boilerplate.
```javascript
import { group, check } from 'k6';
const id = 5;
  // reconsider this type of code
  group('get post', function () {
    http.get(`http://example.com/posts/${id}`);
  group('list posts', function () {
    const res = http.get(`http://example.com/posts`);
    check(res, {
      'is status 200': (r) => r.status === 200,
If your code looks like the preceding snippet, consider the following strategies to write cleaner code:
- For dynamic URLs, use the [URL grouping feature](/docs/k6/latest/using-k6/http-requests/#url-grouping).
- To provide a meaningful name to your request, set the value of [tags.name](/docs/k6/latest/using-k6/http-requests/#http-request-tags).
- To reuse common logic or organize your code better, group logic in functions, or create a [local JavaScript module](/docs/k6/latest/using-k6/modules/#local-filesystem-modules) and import it into the test script.
- To model advanced user patterns, check out [Scenarios](/docs/k6/latest/using-k6/scenarios/).
