Upgrade to Grafana v8.3
Enterprise Open source
We recommend that you upgrade Grafana often to stay current with the latest fixes and enhancements. Because Grafana upgrades are backward compatible, the upgrade process is straightforward, and dashboards and graphs will not change.
In addition to common tasks you should complete for all versions of Grafana, there might be additional upgrade tasks to complete for a version.
Note: There might be minor breaking changes in some releases. We outline these changes in the What’s New document for each release.
For versions of Grafana prior to v9.2, we published additional information in the Release Notes.
When available, we list all changes with links to pull requests or issues in the Changelog.
Note: When possible, we recommend that you test the Grafana upgrade process in a test or development environment.
Back up the Grafana database
Although Grafana automatically upgrades the database on startup, we recommend that you back up your Grafana database so that you can roll back to a previous version, if required.
SQLite
If you use SQLite, you only need to back up the grafana.db file. On Unix systems, the database file is usually located in /var/lib/grafana/.
If you are unsure which database you use and where it is stored, check the Grafana configuration file. If you installed Grafana to a custom location using a binary tar/zip, the database is usually located in <grafana_install_dir>/data.
MySQL
To back up or restore a MySQL Grafana database, run the following commands:
bash
backup:
> mysqldump -u root -p[root_password] [grafana] > grafana_backup.sql
restore:
> mysql -u root -p grafana < grafana_backup.sql
Postgres
To back up or restore a Postgres Grafana database, run the following commands:
bash
backup:
> pg_dump grafana > grafana_backup
restore:
> psql grafana < grafana_backup
Backup plugins
We recommend that you back up installed plugins before you upgrade Grafana so that you can roll back to a previous version of Grafana, if necessary.
Upgrade Grafana
The following sections provide instructions for how to upgrade Grafana based on your installation method.
Debian
To upgrade Grafana installed from a Debian package (.deb), complete the following steps:
  1. In your current installation of Grafana, save your custom configuration changes to a file named <grafana_install_dir>/conf/custom.ini.
    This enables you to upgrade Grafana without the risk of losing your configuration changes.
  2. Download the latest version of Grafana.
  3. Run the following dpkg -i command.
    bash
    wget <debian package url>
    sudo apt-get install -y adduser
    sudo dpkg -i grafana_<version>_amd64.deb
APT repository
To upgrade Grafana installed from the Grafana Labs APT repository, complete the following steps:
  2. Run the following commands:
    bash
    sudo apt-get update
    sudo apt-get upgrade
Grafana automatically updates when you run apt-get upgrade.
Binary .tar file
To upgrade Grafana installed from the binary .tar.gz package, complete the following steps:
  2. Download the binary .tar.gz package.
  3. Extract the downloaded package and overwrite the existing files.
RPM or YUM
To upgrade Grafana installed using RPM or YUM complete the following steps:
  2. Perform one of the following steps based on your installation.
Docker
To upgrade Grafana running in a Docker container, complete the following steps:
  2. Run a commands similar to the following commands.
    Note: This is an example. The parameters you enter depend on how you configured your Grafana container.
    bash
    docker pull grafana/grafana
    docker stop my-grafana-container
    docker rm my-grafana-container
    docker run -d --name=my-grafana-container --restart=always -v /var/lib/grafana:/var/lib/grafana grafana/grafana
Windows
To upgrade Grafana installed on Windows, complete the following steps:
  2. Download the Windows binary package.
  3. Extract the contents of the package to the location in which you installed Grafana.
    You can overwrite existing files and folders, when prompted.
Mac
To upgrade Grafana installed on Mac, complete the following steps:
  2. Download the Mac binary package.
Update Grafana plugins
After you upgrade Grafana, we recommend that you update all plugins because a new version of Grafana can make older plugins stop working properly.
Run the following command to update plugins:
bash
grafana-cli plugins update-all
Technical notes
This section describes technical changes associated with this release of Grafana.
Dashboard references
In 8.3, Grafana dashboards now reference data sources using an object with uid and type properties instead of the data source name property. A schema migration is applied when existing dashboards open. If you provision dashboards to multiple Grafana instances, then we recommend that you also provision data sources. You can specify the uid to be the same for data sources across your instances. If you need to find the uid for a data source created in the UI, check the URL of the data source settings page. The URL follows the pattern /data source/edit/${uid}, meaning the last part is the uid.
