Menu
DocumentationGrafana documentationPanelsCreate reusable Grafana panelsUnlink a Grafana library panel
Enterprise
Unlink a library panel when you want to make a change to the panel and not affect other instances of the library panel.
Before you begin
- Identify the panel you want to unlink.
To unlink a library panel from a dashboard:
- Hover over Dashboard on the left menu, and then click Library panels.
- Select a library panel that is being used in different dashboards.
- Select the panel you want to unlink.
- Click the title of the panel and then click Edit. The panel opens in edit mode.
- Click the Unlink option on the top right corner of the page.
Was this page helpful?
Video
Getting started with the Grafana LGTM Stack
In this webinar, we’ll demo how to get started using the LGTM Stack: Loki for logs, Grafana for visualization, Tempo for traces, and Mimir for metrics.
Video
Getting started with Grafana dashboard design
In this webinar, you'll learn how to design stylish and easily accessible Grafana dashboards that tell a story.
Video
Building advanced Grafana dashboards
In this webinar, we’ll demo how to build and format Grafana dashboards.
