Menu
DocumentationGrafana documentationPanelsCreate reusable Grafana panelsDelete a Grafana library panel
Enterprise
Delete a library panel when you no longer need it.
Before you begin
- Verify that the panel does not appear on a dashboard.
To delete a library panel:
Hover over Dashboard on the left menu, and select Library panels from the drop-down options.
Select a library panel that is being used in different dashboards.
You will see a list of all the dashboards.
Select the panel you want to delete.
Click the delete icon next to the library panel name.
Was this page helpful?
Video
Getting started with the Grafana LGTM Stack
In this webinar, we’ll demo how to get started using the LGTM Stack: Loki for logs, Grafana for visualization, Tempo for traces, and Mimir for metrics.
Video
Getting started with Grafana dashboard design
In this webinar, you'll learn how to design stylish and easily accessible Grafana dashboards that tell a story.
Video
Building advanced Grafana dashboards
In this webinar, we’ll demo how to build and format Grafana dashboards.
