Menu
Enterprise Open source
Upgrade to Grafana v9.5
We recommend that you upgrade Grafana often to stay current with the latest fixes and enhancements. Because Grafana upgrades are backward compatible, the upgrade process is straightforward, and dashboards and graphs will not change.
In addition to common tasks you should complete for all versions of Grafana, there might be additional upgrade tasks to complete for a version.
Note: There might be breaking changes in some releases. We outline these changes in the What’s New document for most releases or a separate Breaking changes document for releases with many breaking changes.
For versions of Grafana prior to v9.2, we published additional information in the Release Notes.
When available, we list all changes with links to pull requests or issues in the Changelog.
Note: When possible, we recommend that you test the Grafana upgrade process in a test or development environment.
Back up Grafana
This topic explains how to back up a local Grafana deployment, including configuration, plugin data, and the Grafana database.
Back up the Grafana configuration file
Copy Grafana configuration files that you might have modified in your Grafana deployment to a backup directory.
The Grafana configuration files are located in the following directories:
  • Default configuration: $WORKING_DIR/conf/defaults.ini
  • Custom configuration: $WORKING_DIR/conf/custom.ini
Note: If you installed Grafana using the deb or rpm packages, then your configuration file is located at /etc/grafana/grafana.ini. This path is specified in the Grafana init.d script using --config file parameter.
Back up plugin data
Installing plugins in Grafana creates a folder for each plugin with its associated files and data. Copy all files and folders recursively from this location to your backup repository.
The Grafana plugin files are located in the following directories:
  • Default location for plugins in a binary or source installation: $WORKING_DIR/data/plugins
  • Default location for plugins in a deb or rpm package: /var/lib/grafana/plugins. This path is specified in the Grafana init.d script using --config file parameter.
Back up the Grafana database
We recommend that you back up your Grafana database so that you can roll back to a previous version, if required.
SQLite
The default Grafana database is SQLite, which stores its data in a single file on disk. To back up this file, copy it to your backup repository.
Note: To ensure data integrity, shut down your Grafana service before backing up the SQLite database.
The SQLite database file is located in one of the following directories:
  • Default location for SQLite data in a binary or source installation: $WORKING_DIR/data/grafana.db
  • Default location for SQLite data in a deb or rpm package: /var/lib/grafana/grafana.db. This path is specified in the Grafana init.d script using --config file parameter.
MySQL
To back up or restore a MySQL Grafana database, run the following commands:
bash
backup:
> mysqldump -u root -p[root_password] [grafana] > grafana_backup.sql
restore:
> mysql -u root -p grafana < grafana_backup.sql
Postgres
To back up or restore a Postgres Grafana database, run the following commands:
bash
backup:
> pg_dump grafana > grafana_backup
restore:
> psql grafana < grafana_backup
Upgrade Grafana
The following sections provide instructions for how to upgrade Grafana based on your installation method.
Debian
To upgrade Grafana installed from a Debian package (.deb), complete the following steps:
  1. In your current installation of Grafana, save your custom configuration changes to a file named <grafana_install_dir>/conf/custom.ini.
    This enables you to upgrade Grafana without the risk of losing your configuration changes.
  2. Download the latest version of Grafana.
  3. Run the following dpkg -i command.
    bash
    wget <debian package url>
    sudo apt-get install -y adduser
    sudo dpkg -i grafana_<version>_amd64.deb
APT repository
To upgrade Grafana installed from the Grafana Labs APT repository, complete the following steps:
  2. Run the following commands:
    bash
    sudo apt-get update
    sudo apt-get upgrade
Grafana automatically updates when you run apt-get upgrade.
Binary .tar file
To upgrade Grafana installed from the binary .tar.gz package, complete the following steps:
  2. Download the binary .tar.gz package.
  3. Extract the downloaded package and overwrite the existing files.
RPM or YUM
To upgrade Grafana installed using RPM or YUM complete the following steps:
  2. Perform one of the following steps based on your installation.
Docker
To upgrade Grafana running in a Docker container, complete the following steps:
  2. Run a commands similar to the following commands.
    Note: This is an example. The parameters you enter depend on how you configured your Grafana container.
    bash
    docker pull grafana/grafana
    docker stop my-grafana-container
    docker rm my-grafana-container
    docker run -d --name=my-grafana-container --restart=always -v /var/lib/grafana:/var/lib/grafana grafana/grafana
Windows
To upgrade Grafana installed on Windows, complete the following steps:
  2. Download the Windows binary package.
  3. Extract the contents of the package to the location in which you installed Grafana.
    You can overwrite existing files and folders, when prompted.
Mac
To upgrade Grafana installed on Mac, complete the following steps:
  2. Download the Mac binary package.
Update Grafana plugins
After you upgrade Grafana, we recommend that you update all plugins because a new version of Grafana can make older plugins stop working properly.
Run the following command to update plugins:
bash
grafana cli plugins update-all
Technical notes
InfluxDB provisioning change
Beginning in v9.5, the InfluxDB data source deprecates the database field in provisioning files. The dbName field under jsonData must be used to store the database information. For more information and examples, please refer to InfluxDB Provisioning.
Dashboard previews deprecation notice
We are deprecating the dashboard previews feature and will remove it in Grafana v10. We’ve started exploring alternative ways of adding visual previews using the Scenes framework, and we’ll share more information about it in the future.
Migrate your API keys to service accounts
We are upgrading Grafana API keys to service accounts. Service accounts are a superset of API keys that include token rotation and compatibility with Role-based access control. In a future release, we’ll automatically migrate all existing API keys to service accounts. All of your existing tokens will continue to work; they will simply be migrated to service accounts. You can preempt this change by migrating your existing API keys to service accounts using Grafana’s UI or API. Learn how to do this in the API keys documentation.
