Modify dashboard settings
The dashboard settings page allows you to:
  • Edit general dashboard properties, including time settings
  • Add links
  • View the dashboard JSON model
To access the dashboard setting page:
  1. Select Editing in the dashboard mode drop-down list.
  2. In the toolbar, click the Dashboard options icon.
  3. In the sidebar, click View all settings.
Modify dashboard time settings
Adjust dashboard time settings when you want to change the dashboard timezone, the local browser time, and specify auto-refresh time intervals.
  1. On the the General tab of the Settings page, scroll down to the Time options section.
  2. Specify time settings as follows.
    • Time zone: Specify the local time zone of the service or system that you are monitoring. This can be helpful when monitoring a system or service that operates across several time zones.
      • Default: Grafana uses the default selected time zone for the user profile, team, or organization. If no time zone is specified for the user profile, a team the user is a member of, or the organization, then Grafana uses the local browser time.
      • Browser time: The time zone configured for the viewing user browser is used. This is usually the same time zone as set on the computer.
      • Standard ISO 8601 time zones, including UTC.
    • Auto refresh: Customize the options displayed for relative time and the auto-refresh options Entries are comma separated and accept any valid time unit.
    • Now delay: Override the now time by entering a time delay. Use this option to accommodate known delays in data aggregation to avoid null values.
    • Week start: Choose the day the week starts on.
    • Hide time picker: Select this option if you do not want Grafana to display the time picker.
    • Refresh live dashboards: Select this option to continuously update panels when the time range includes the current time.
  3. Click Save.
  4. (Optional) Enter a description of the changes you’ve made.
  5. Click Save.
  6. Select Viewing in the dashboard mode drop-down list.
Modify graph tooltip behavior
Use this option to control tooltip and hover highlight behavior across graph panels (for example, time series).
  1. On the the General tab of the Settings page, scroll down to the Panel options section.
  2. Choose from the following options to control the tooltip and hover highlight behavior across graph panels:
    • Default - Tooltip and hover highlight behavior isn’t shared across panels.
    • Shared crosshair - When you hover the cursor over one graph panel in the dashboard, the crosshair is also displayed on all other graph panels in the dashboard.
    • Shared tooltip - When you hover the cursor over one graph panel in the dashboard, the crosshair and tooltips are also displayed on all other graph panels in the dashboard.
  3. Click Save.
  5. Click Save.
Add tags
You can add metadata to your dashboards using tags. Tags also give you the ability to filter the list of dashboards.
Tags can be up to 50 characters long, including spaces.
To add tags to a dashboard, follow these steps:
  1. On the the General tab of the Settings page, scroll down to the Tags section.
  2. In the field, enter a new or existing tag.
    If you’re entering an existing tag, make sure that you spell it the same way or a new tag is created.
  3. Click Add or press the Enter key.
  4. Click Save.
  5. (Optional) Enter a description of the changes you’ve made.
  6. Click Save.
  7. Select Viewing in the dashboard mode drop-down list.
When you’re on the Dashboards page, any tags you’ve entered show up under the Tags column.
Add an annotation query
Annotations setup has been removed from dashboard settings. You can now add and manage annotation queries in the dashboard sidebar. For more information, refer to Add annotation queries.
Add a variable
Variables setup has been removed from dashboard settings. You can now add and manage variables in the dashboard sidebar. For more information, refer to Add variables.
Dashboard links enable you to place links to other dashboards and web sites directly below the dashboard header. Links provide for quick navigation to other, related dashboards and content.
  1. On the Settings page, click the Links tab.
  2. Click New link.
  3. Enter title for the link.
  4. In the Type drop-down, select Dashboards or Link.
  5. Set the rest of the link options.
    For more detailed directions on creating links, refer to Dashboard links
  6. Click Save.
  7. (Optional) Enter a description of the changes you’ve made.
  8. Click Save.
  9. Select Viewing in the dashboard mode drop-down list.
View dashboard JSON model
A dashboard in Grafana is represented by a JSON object, which stores metadata of its dashboard. Dashboard metadata includes dashboard properties, metadata from panels, template variables, panel queries, and so on.
To view a dashboard JSON model, on the Settings page, click the JSON Model tab.
For more information about the JSON fields, refer to JSON fields.
