Menu
Enterprise Open source
Upgrade to Grafana v8.0
We recommend that you upgrade Grafana often to stay current with the latest fixes and enhancements. Because Grafana upgrades are backward compatible, the upgrade process is straightforward, and dashboards and graphs will not change.
In addition to common tasks you should complete for all versions of Grafana, there might be additional upgrade tasks to complete for a version.
Note
There might be breaking changes in some releases. We outline these changes in the What’s New document for most releases or a separate Breaking changes document for releases with many breaking changes.
For versions of Grafana prior to v9.2, we published additional information in the Release Notes.
When available, we list all changes with links to pull requests or issues in the Changelog.
Note
When possible, we recommend that you test the Grafana upgrade process in a test or development environment.
Back up Grafana
This topic explains how to back up a local Grafana deployment, including configuration, plugin data, and the Grafana database.
Back up the Grafana configuration file
Copy Grafana configuration files that you might have modified in your Grafana deployment to a backup directory.
The Grafana configuration files are located in the following directories:
  • Default configuration: $WORKING_DIR/defaults.ini (Don’t change this file)
  • Custom configuration: $WORKING_DIR/custom.ini
For more information on where to find configuration files, refer to Configuration file location.
Note
If you installed Grafana using the deb or rpm packages, then your configuration file is located at /etc/grafana/grafana.ini. This path is specified in the Grafana init.d script using --config file parameter.
Back up plugin data
Installing plugins in Grafana creates a folder for each plugin with its associated files and data. Copy all files and folders recursively from this location to your backup repository.
The Grafana plugin files are located in the following directories:
  • Default location for plugins in a binary or source installation: $WORKING_DIR/data/plugins
  • Default location for plugins in a deb or rpm package: /var/lib/grafana/plugins. This path is specified in the Grafana init.d script using --config file parameter.
Back up the Grafana database
We recommend that you back up your Grafana database so that you can roll back to a previous version, if required.
SQLite
The default Grafana database is SQLite, which stores its data in a single file on disk. To back up this file, copy it to your backup repository.
Note
To ensure data integrity, shut down your Grafana service before backing up the SQLite database.
The SQLite database file is located in one of the following directories:
  • Default location for SQLite data in a binary or source installation: $WORKING_DIR/data/grafana.db
  • Default location for SQLite data in a deb or rpm package: /var/lib/grafana/grafana.db. This path is specified in the Grafana init.d script using --config file parameter.
MySQL
To back up or restore a MySQL Grafana database, run the following commands:
Bash
backup:
> mysqldump -u root -p[root_password] [grafana] > grafana_backup.sql
restore:
> mysql -u root -p grafana < grafana_backup.sql
Postgres
To back up or restore a Postgres Grafana database, run the following commands:
Bash
backup:
> pg_dump grafana > grafana_backup
restore:
> psql grafana < grafana_backup
Upgrade Grafana
The following sections provide instructions for how to upgrade Grafana based on your installation method. For more information on where to find configuration files, refer to Configuration file location.
Debian
To upgrade Grafana installed from a Debian package (.deb), complete the following steps:
  1. In your current installation of Grafana, save your custom configuration changes to a file named <grafana_install_dir>/grafana.ini.
    This enables you to upgrade Grafana without the risk of losing your configuration changes.
  2. Download the latest version of Grafana.
  3. Run the following dpkg -i command.
    Bash
    wget <debian package url>
    sudo apt-get install -y adduser
    sudo dpkg -i grafana_<version>_amd64.deb
APT repository
To upgrade Grafana installed from the Grafana Labs APT repository, complete the following steps:
  2. Run the following commands:
    Bash
    sudo apt-get update
    sudo apt-get upgrade
Grafana automatically updates when you run apt-get upgrade.
Binary .tar file
To upgrade Grafana installed from the binary .tar.gz package, complete the following steps:
  1. In your current installation of Grafana, save your custom configuration changes to the custom configuration file, custom.ini or grafana.ini.
  2. Download the binary .tar.gz package.
  3. Extract the downloaded package and overwrite the existing files.
RPM or YUM
To upgrade Grafana installed using RPM or YUM complete the following steps:
  2. Perform one of the following steps based on your installation.
Docker
To upgrade Grafana running in a Docker container, complete the following steps:
  1. Use Grafana environment variables to save your custom configurations; this is the recommended method. Alternatively, you can view your configuration files manually by accessing the deployed container.
  2. Run a commands similar to the following commands.
    Note
    This is an example. The parameters you enter depend on how you configured your Grafana container.
    Bash
    docker pull grafana/grafana
    docker stop my-grafana-container
    docker rm my-grafana-container
    docker run -d --name=my-grafana-container --restart=always -v /var/lib/grafana:/var/lib/grafana grafana/grafana
Windows
To upgrade Grafana installed on Windows, complete the following steps:
  1. In your current installation of Grafana, save your custom configuration changes to a file named <grafana_install_dir>/conf/custom.ini.
  2. Download the Windows binary package.
  3. Extract the contents of the package to the location in which you installed Grafana.
    You can overwrite existing files and folders, when prompted.
Mac
To upgrade Grafana installed on Mac, complete the following steps:
  1. In your current installation of Grafana, save your custom configuration changes to the custom configuration file, custom.ini.
  2. Download the Mac binary package.
Update Grafana plugins
After you upgrade Grafana, we recommend that you update all plugins because a new version of Grafana can make older plugins stop working properly.
Run the following command to update plugins:
Bash
grafana cli plugins update-all
Technical notes
This section describes technical changes associated with this release of Grafana.
Plugins
Grafana now requires all plugins to be signed. If a plugin is not signed Grafana will not load/start it. This is an additional security measure to make sure plugin files and binaries haven’t been tampered with. All Grafana Labs authored plugins, including Enterprise plugins, are now signed. It’s possible to allow unsigned plugins using a configuration setting, but is something we strongly advise against doing. For more information about this setting, refer to allow loading unsigned plugins.
Grafana Live
Grafana now maintains persistent WebSocket connections for real-time messaging needs.
When WebSocket connection is established, Grafana checks the request Origin header due to security reasons (for example, to prevent hijacking of WebSocket connection). If you have a properly defined public URL (root_url server option) then the origin check should successfully pass for WebSocket requests originating from public URL pages. In case of an unsuccessful origin check, Grafana returns a 403 error. It’s also possible to add a list of additional origin patterns for the origin check.
To handle many concurrent WebSocket connections you may need to tune your OS settings or infrastructure. Grafana Live is enabled by default and supports 100 concurrent WebSocket connections max to avoid possible problems with the file descriptor OS limit. As soon as your setup meets the requirements to scale the number of persistent connections this limit can be increased. You also have an option to disable Grafana Live.
Refer to Grafana Live configuration documentation for more information.
Postgres, MySQL, Microsoft SQL Server data sources
Grafana v8.0 changes the underlying data structure to data frames for the Postgres, MySQL, Microsoft SQL Server data sources. As a result, a Time series query result gets returned in a wide format. To make the visualizations work as they did before, you might have to do some manual migrations.
For any existing panels/visualizations using a Time series query, where the time column is only needed for filtering the time range, for example, using the bar gauge or pie chart panel, we recommend that you use a Table query instead and exclude the time column as a field in the response. Refer to this issue comment for detailed instructions and workarounds.
Prefix added to series names
When you have a query where there’s a time value and a numeric value selected together with a string value that’s not named metric, the graph panel renders series names as value <hostname> rather than just <hostname> which was the case before Grafana 8.
SQL
SELECT
  $__timeGroup("createdAt",'10m'),
  avg(value) as "value",
  hostname
FROM grafana_metric
WHERE $__timeFilter("createdAt")
GROUP BY time, hostname
ORDER BY time
There are two possible workarounds to resolve this problem:
  1. In Grafana v8.0.3, use an alias of the string column selected as metric. for example, hostname as metric.
  2. Use the Standard field definitions’ display name to format the alias. For the preceding example query, you would use ${__field.labels.hostname} option.
For more information, refer to the our relational databases documentation of Postgres, MySQL, Microsoft SQL Server.
