Dashboard JSON schema v2
Caution
Dashboard JSON schema v2 is an experimental feature. Engineering and on-call support is not available. Documentation is either limited or not provided outside of code comments. No SLA is provided. To get early access to this feature, request it through this form.
Do not enable this feature in production environments as it may result in the irreversible loss of data.
Grafana dashboards are represented as JSON objects that store metadata, panels, variables, and settings.
Observability as Code works with all versions of the JSON model, and it’s fully compatible with version 2.
Before you begin
Schema v2 is automatically enabled with the Dynamic Dashboards feature toggle.
It also requires the new dashboards API feature toggle, kubernetesDashboards
, to be enabled as well.
For more information on how dashboards behave depending on your feature flag configuration, refer to Notes and limitations.
Accessing the JSON Model
To view the JSON representation of a dashboard:
- Toggle on the edit mode switch in the top-right corner of the dashboard.
- Click the gear icon in the top navigation bar to go to Settings.
- Select the JSON Model tab.
- Copy or edit the JSON structure as needed.
JSON fields
The dashboard JSON sample shown uses the default GridLayoutKind
The JSON in a new dashboard for the other three layout options, AutoGridLayout
, RowsLayout
, and TabsLayout
, are as follows:
AutoGridLayout
"layout": {
"kind": "AutoGridLayout",
"spec": {
"columnWidthMode": "standard",
"items": [],
"fillScreen": false,
"maxColumnCount": 3,
"rowHeightMode": "standard"
RowsLayout
"layout": {
"kind": "RowsLayout",
"spec": {
"rows": []
TabsLayout
"layout": {
"kind": "TabsLayout",
"spec": {
"tabs": []
DashboardSpec
The following table explains the usage of the dashboard JSON fields. The table includes default and other fields:
annotations
The configuration for the list of annotations that are associated with the dashboard. For the JSON and field usage notes, refer to the annotations schema documentation.
elements
Dashboards can contain the following elements:
layout
Dashboards can have four layout options:
For the JSON and field usage notes about each of these, refer to the layout schema documentation.
links
The configuration for links with references to other dashboards or external websites.
For the JSON and field usage notes, refer to the links schema documentation.
tags
The tags associated with the dashboard:
[...string]
timesettings
The TimeSettingsSpec
defines the default time configuration for the time picker and the refresh picker for the specific dashboard.
For the JSON and field usage notes about the TimeSettingsSpec
, refer to the
timesettings schema documentation.
variables
The variables
schema defines which variables are used in the dashboard.
There are eight variables types:
- QueryVariableKind
- TextVariableKind
- ConstantVariableKind
- DatasourceVariableKind
- IntervalVariableKind
- CustomVariableKind
- GroupByVariableKind
- AdhocVariableKind
For the JSON and field usage notes about the variables
spec, refer to the
variables schema documentation.
Existing dashboards
With schema v2 enabled, you can still open and view your pre-existing dashboards. Upon saving, they’ll be updated to the new schema where you can take advantage of the new features and functionalities.
Dashboard behavior with disabled feature flags
If you disable the Dynamic dashboards or kubernetesDashboards
feature flags, you should be aware of how dashboards will behave.
Disable Dynamic dashboards
If the Dynamic dashboards feature toggle is disabled, depending on how the dashboard was built, it will behave differently:
- Dashboards built on the new schema through the UI - View only
- Dashboards built on Schema v1 - View and edit
- Dashboards built on the new schema by way of Terraform or the CLI - View and edit
- Provisioned dashboards built on the new schema - View and edit, but the edit experience will be the old experience
Disable Dynamic dashboards and kubernetesDashboards
You’ll be unable to view or edit dashboards created or updated in the new schema.
Import and export
From the UI, dashboards created on schema v2 can be exported and imported like other dashboards. When you export them to use in another instance, references of data sources are not persisted but data source types are. You’ll have the option to select the data source of your choice in the import UI.
