This is documentation for the next version of Grafana. For the latest stable release, go to the latest version.
How label matching works
Use labels and label matchers to link alert rules to notification policies and silences. This allows for a very flexible way to manage your alert instances, specify which policy should handle them, and which alerts to silence.
A label matchers consists of 3 distinct parts, the label, the value and the operator.
The Label field is the name of the label to match. It must exactly match the label name.
The Value field matches against the corresponding value for the specified Label name. How it matches depends on the Operator value.
The Operator field is the operator to match against the label value. The available operators are:
Operator | Description |
= | Select labels that are exactly equal to the value. |
!= | Select labels that are not equal to the value. |
=~ | Select labels that regex-match the value. |
!~ | Select labels that do not regex-match the value. |
Example of a label matcher
Imagine we’ve defined the following set of labels for our alert.
{ foo=bar, baz=qux, id=12 }
In this situation,
- A label matcher defined as
foo=bar
will match this alert rule. - A label matcher defined as
foo!=bar
will not match this alert rule. - A label matcher defined as
id=~[0-9]+
baz!~[0-9]+
Related Grafana resources
Opening keynote: What's new in Grafana 9?
Raj Dutt, Myrle Krantz, and Torkel Ödegaard unveil what's new in Grafana 9. Watch the opening keynote presentation from GrafanaCONline 2022. On-demand.
Unify your data with Grafana plugins: Splunk, MongoDB, Datadog, and more
Show how Grafana can be used to take data from multiple different sources and unify it, without disrupting the investments that are working today.
Getting started with Grafana Enterprise and observability
Join the Grafana Labs team for a 30-minute demo of how to get started with the Grafana Stack, so you can go from zero to observability in just a few minutes.
