title: "Improve alert rule quality with Alert Advisor | Grafana documentation"
description: "Use Alert Advisor to define required labels and annotations, review findings, and optionally enforce annotation and label requirements for Grafana-managed alert rules."
# Improve alert rule quality with Alert Advisor
Alerts are easier to act on when they carry the right context. A runbook URL helps you investigate an issue, and a team label helps you route your notifications.
Alert Advisor checks your Grafana-managed alert rules against a quality policy of required labels and annotations, so you can find and fix rules that are missing that context. With Alert Advisor, you can:
- Define which labels and annotations your Grafana-managed alert rules must have.
- Find rules that are missing required labels or annotations and update them.
- Optionally block supported provisioning writes that don’t meet selected requirements.
## Before you begin
Before you begin, check that you have the following permissions in your Grafana organization:
- **Rule access:** Have permission to view the Grafana-managed alert rules you want to assess.
- **Policy permissions:** To configure the quality policy, have the Admin role in your organization or a role with `alert.rules.quality:write` and `alert.rules:read`.
- **Rule updates:** To fix findings, have permission to update the affected rules. For provisioned rules, you also need access to their source configuration and permission to reapply it.
For more information about alerting permissions and folder access, refer to [Configure RBAC](/docs/grafana/next/alerting/set-up/configure-rbac/).
## Understand policy scope
A single quality policy applies to Grafana-managed alert rules across folders in your organization. Data source-managed alert rules and recording rules are excluded.
Alert Advisor reports a finding when a required label or annotation is missing, empty, or contains only whitespace. The checks do not validate the content itself, they only check for the presence of a particular field. For example, requiring a runbook URL doesn’t check whether the link works.
### Detection and enforcement
You choose a mode for each requirement:
Expand table
| Mode        | Behavior        |
| Detect-only | Missing values appear as findings but don’t block rule creation or updates.                                |
| Enforced    | Missing values appear as findings and block rule creation or updates through supported provisioning paths. |
Both modes contribute to the quality score. Enabling enforcement doesn’t stop existing rules from evaluating or sending notifications.
### Supported enforcement paths
Enforcement applies to provisioned rules created or updated through Terraform and the Alerting provisioning HTTP API, with the following exceptions:
- Provisioning API requests that set the `X-Disable-Provenance` header, including Terraform `grafana_rule_group` resources with `disable_provenance = true`, aren’t enforced.
- `kubectl` writes are enforced only when the manifest sets `grafana.app/managedBy` to `kubectl` or `terraform` together with a non-empty `grafana.app/managerId`, or sets `grafana.com/provenance` to `api`.
Writes from the Grafana rule editor aren’t enforced, but the resulting rules can still have quality findings.
## Configure a quality policy
Start with detect-only requirements to identify missing information before enabling enforcement. The following example requires a runbook URL and a `team` label.
The **Quality policy settings** button is visible only if you have the policy permissions listed in [Before you begin](#before-you-begin).
To configure a quality policy, follow these steps:
1. Go to **Alerting** &gt; **Alert rules** and select **Alert quality**.
2. Click **Quality policy settings** (the cog icon) to open the **Quality policy** drawer.
3. Under **Required annotations**, turn on **Runbook URL**.
   You can also require **Summary** and **Description**.
4. Under **Required labels**, enter `team` in **Label keys** and select the matching option.
   You can select keys already used by your rules or add a new key.
5. Keep **Enforce** off for the requirements you add.
   New requirements start in detect-only mode.
6. Click **Save**.
   Grafana displays **Policy saved** to confirm the change.
The saved policy identifies rules with missing or empty `runbook_url` annotations or `team` labels.
A policy with no required annotations or labels checks nothing.
## Review alert quality
In Alert Advisor, the **Alert quality** tab lists rules that don’t meet your policy and shows an overall quality score.
To review the findings, follow these steps:
2. Review the **Alert quality score** and the number of rules that need attention.
3. Inspect the missing annotations and labels in the **Findings** list.
Each missing field appears as a badge. To check whether a requirement is enforced or detect-only, hover over its badge.
### Understand the score
The score represents the proportion of assessed rules that meet every configured requirement, on a scale of 0 to 10. For example, if 8 of 10 rules meet the policy, the score is 8.0. Grafana rounds the score to one decimal place.
The score measures compliance with your policy, not alert accuracy, severity, or noise. Both detect-only and enforced requirements count toward the score.
Your permissions determine which rules you can view and assess. Search filters change the findings’ list, not the score or the total rule count. Grafana also displays 10.0 when there are no rules to assess, so check the rule count alongside the score.
## Resolve quality findings
Add meaningful values for the missing fields in each rule. For the example policy, set `runbook_url` to the rule’s runbook URL and `team` to the owning team’s name.
Changing label values can affect notification routing. Choose values that match your team’s [notification policies](/docs/grafana/next/alerting/fundamentals/notifications/notification-policies/).
### Update provisioned rules
For provisioned rules, make changes in the source configuration so they remain part of your provisioning workflow.
To resolve a finding on a provisioned rule, follow these steps:
1. Locate the rule in its source configuration, using the rule name, folder, and group shown in **Alert quality**.
2. Add values for the missing annotations and labels.
3. Reapply the configuration through your usual provisioning workflow.
4. Reload the **Alert quality** page and check the rule’s findings.
A rule disappears from the findings list when it meets every configured requirement. If other required fields are still missing, the rule remains in the list with those findings.
### Update rules in Grafana
For rules that you can edit in Grafana, use the **Edit** action on the quality page.
To resolve a finding in the rule editor, follow these steps:
1. Click **Edit** for the affected rule.
2. Fill in the missing annotations and labels in the rule editor.
3. Click **Save**.
4. Return to **Alert quality** and reload the page to check the findings.
## Optional: Enforce quality requirements
After reviewing and resolving findings, enable enforcement for the requirements you want to apply to supported provisioning writes. You can enforce selected requirements while keeping others detect-only.
To enable enforcement, follow these steps:
1. On the **Alert quality** page, click **Quality policy settings** (the cog icon) to open the **Quality policy** drawer.
2. Turn on **Enforce** beside each requirement you want to enforce.
   For example, enforce `team` while keeping **Runbook URL** detect-only. To enforce all currently configured requirements, turn on **Enforce all requirements** instead.
3. Click **Save**.
### Disable enforcement or remove a requirement
To return a requirement to detect-only, turn off its **Enforce** control (or **Enforce all requirements**, if every requirement is enforced) and click **Save**. The requirement remains in the policy and continues to affect the quality score.
To stop checking a field altogether, remove its requirement instead: turn off its switch under **Required annotations**, or remove its key from **Label keys**. Then click **Save**.
## Troubleshoot quality findings and rejected writes
Use the following guidance when you can’t access the feature, resolve a finding, or apply a rule change.
Expand table
| Symptom        | Action        |
| **Alert quality** or the **Quality policy settings** button isn’t visible. | Ask your stack administrator to check your [permissions](#before-you-begin) and the feature’s availability in your stack.        |
| A rule has no **Edit** action.                                             | If it has a **Provisioned** badge, update its source configuration. Otherwise, check your permission to update rules in that folder.                                                      |
| Grafana reports that no quality policy is configured.                      | Add at least one requirement in the **Quality policy** drawer and click **Save**. An empty policy doesn’t assess any fields.                                                              |
| No findings match your search, but the score is below 10.0.                | Clear **Search** to view all findings. Search filters don’t change the score.        |
| A finding remains after enforcement is disabled.                           | Detect-only requirements still produce findings. Fill in the missing value or remove the requirement from the policy.        |
| A provisioning write is rejected by the quality policy.                    | Use the rule and field details in the error to update the source configuration, then reapply it.        |
| A write succeeds despite a quality finding.                                | Check that the requirement is enforced and the policy is saved. Confirm that the write uses a [supported enforcement path](#supported-enforcement-paths) and isn’t one of its exceptions. |
## Next steps
Use these guides to improve rule context, manage rules as code, and configure access:
- **Rule context:** [Labels and annotations](/docs/grafana/next/alerting/fundamentals/alert-rules/annotation-label/).
- **Provisioning:** [Use Terraform to provision alerting resources](/docs/grafana/next/alerting/set-up/provision-alerting-resources/terraform-provisioning/).
- **API management:** [Use the HTTP API to manage alerting resources](/docs/grafana/next/alerting/set-up/provision-alerting-resources/http-api-provisioning/).
- **Permissions:** [Configure RBAC](/docs/grafana/next/alerting/set-up/configure-rbac/).
