Set up private probes
A private probe is a probe that you install in your environment or another location you choose. It runs tests against your targets by sending requests and recording the responses.
Unlike public probes operated by Grafana Labs, private probes are only accessible to you and only write data to your Grafana Cloud account. Private probes are instances of the open source Grafana Synthetic Monitoring Agent.
Before you begin
Note
By default, private probes collect and report anonymous, non-personally identifiable information (PII) about the running probe to a remote statistics server operated by Grafana Labs. Synthetic Monitoring maintainers use that data to understand how the open source community operates private probes.
To opt out, use the CLI flag
-disable-usage-reports=true. Refer to Anonymous usage statistics reporting for more information on what’s collected.
- You must have the Admin role in Grafana to access the Synthetic Monitoring config page.
- Install and configure Synthetic Monitoring before adding a private probe.
- Installing from the Grafana APT repository on amd64-based Debian and Ubuntu systems is the only packaging option provided. On other systems, you need to build the agent from source.
- You can install multiple private probes. Each private probe has its own unique Probe Authentication Token.
Add a new probe in your Grafana instance
- Navigate to Testing & synthetics > Synthetics > Probes.
- Click Add Private Probe.
- Enter a Probe Name.
- Enter a Latitude and Longitude to see an accurate location on the map panel.
- Enter a Region. Defaults are
AMER,EMEA, andAPAC, but you may define your own. - Optionally enter up to three custom labels to identify your probe. Probe labels can’t use reserved system label names. Refer to System labels.
- Click Save.
- Copy the Probe Authentication Token and save it for the next step.
Probe API Server URL
Based on the region of your stack, you need to use a different API server URL
when setting up a private probe. If you are unsure about the region of your
stack, go to your Grafana instance and the Config page under
Synthetic Monitoring and search for backend address.
Note
The config expects API server URLs without
https://. If you receive an error, verify that you have omittedhttps://.
Firewall configuration
Private probes initiate connections to Synthetic Monitoring services and monitored targets. Configure the probe host’s firewall to allow the outbound connections in the following sections. If a monitored target has its own firewall, configure that firewall separately to allow inbound connections from the probe host.
- Allow outbound connections from the probe host to the “API server URL” specified in the preceding table.
- Allow outbound connections from the probe host to the “Secrets proxy” specified in the preceding table.
Prometheus and Loki instances
Allow outbound connections from the probe host to the Prometheus server URL and the Loki URL:
- Log in to Grafana Cloud and open your stack.
- Navigate to Home > Testing & synthetics > Synthetics > Config.
- Under the General tab, scroll down to Data sources.
- For the Prometheus server URL:
- Click the Prometheus data source. For example:
grafanacloud-STACK_NAME-prom. - Copy the Prometheus server URL under the Settings tab -> Connection.
- For the Loki URL:
- Click the Loki data source. For example:
grafanacloud-STACK_NAME-logs. - Copy the URL under the Settings tab -> Connection.
- Update the probe host’s firewall rules with both URLs.
External script imports
- If you use k6 scripts that import external modules, for example, k6 modules from
jslib.k6.io, allow outbound connections from the probe host to the module hosts.
Note
MultiHTTP test executions make outbound connections to
jslib.k6.iowhen run. If you run MultiHTTP checks on private probes behind a firewall, allow outbound connections from the probe host tojslib.k6.io.
Monitored targets
Allow outbound connections from the probe host to each monitored target. The required protocol depends on the check type. For example:
- ICMP: for ping and traceroute checks.
- UDP or TCP: for DNS checks.
- TCP: for HTTP and MultiHTTP checks.
If a target’s firewall blocks these connections, configure the target’s firewall, not the probe host’s firewall, to allow inbound connections from the probe host over the required protocol.
Install the agent on Ubuntu/Debian
You can install the agent using the Grafana official APT repository.
Add the required packages and the repository GPG key.
sudo apt install -y wget gnupg sudo mkdir -p /etc/apt/keyrings/ wget -q -O - https://apt.grafana.com/gpg.key | gpg --dearmor | sudo tee /etc/apt/keyrings/grafana.gpgAdd the repository for stable releases.
echo "deb [signed-by=/etc/apt/keyrings/grafana.gpg] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.listRun the following commands.
sudo apt update sudo apt install synthetic-monitoring-agentConfigure the probe.
- Open
/etc/synthetic-monitoring/synthetic-monitoring-agent.conf. - Replace
<YOUR TOKEN HERE>with the probe authentication token. - Replace
API_SERVERwith Probe API Server URL based on your stack region. (defaults to US region) - Save the file.
- Open
Restart the agent.
sudo service synthetic-monitoring-agent restart
The new probe appears on your Synthetics > Probes page.
Install the agent on distributions using yum
You can install the agent using the official YUM repository.
Add the repository and the GPG key to the configuration.
sudo yum-config-manager --add-repo https://rpm.grafana.com wget https://rpm.grafana.com/gpg.key sudo rpm --import gpg.keyInstall the agent.
sudo yum install synthetic-monitoring-agent sudo systemctl status synthetic-monitoring-agent.serviceThis last command will tell you that the service is loaded but disabled. Before enabling, you need to add the probe to your Synthetic Monitoring configuration.
Configure the agent.
Edit the file
/etc/synthetic-monitoring/synthetic-monitoring-agent.confand make the following changes:- Replace
API_SERVERwith the API Server URL corresponding to your stack’s region. Defaults to the US region.
- Replace
Enable the service and start it.
sudo systemctl enable synthetic-monitoring-agent.service sudo systemctl start synthetic-monitoring-agent.service
Deploy the agent using Docker
You can find the Synthetic Monitoring Agent Docker image on Docker Hub
Pull image from Docker Hub.
docker pull grafana/synthetic-monitoring-agent:latestExport required configuration as environment variables.
Update the placeholders with your probe authentication token and the Probe API Server URL for your stack region.
export API_TOKEN=@@@SM_PROBE_TOKEN@@@ export API_SERVER="@@@SM_PROBE_API_SERVER_URL@@@"Start the agent.
docker run grafana/synthetic-monitoring-agent --api-server-address=${API_SERVER} --api-token=${API_TOKEN} --verbose=true
Deployment with Kubernetes
You can deploy the Synthetic Monitoring Agent to Kubernetes using the Synthetic Monitoring Agent Docker image.
In the agent GitHub repository, you can also find a Kubernetes Deployment example. The following section uses the example files to deploy a Synthetic Monitoring agent in a Kubernetes namespace.
Get the deployment files.
wget https://raw.githubusercontent.com/grafana/synthetic-monitoring-agent/main/examples/kubernetes/namespace.yaml wget https://raw.githubusercontent.com/grafana/synthetic-monitoring-agent/main/examples/kubernetes/secret.yaml wget https://raw.githubusercontent.com/grafana/synthetic-monitoring-agent/main/examples/kubernetes/deployment.yamlCreate the
synthetic-monitoringnamespace.kubectl apply -f namespace.yamlCreate a secret with the Probe Authentication Token.
Replace
YOUR_TOKEN_HEREinsecret.yamlwith your Probe Authentication Token.kubectl apply -f secret.yaml # verify secret kubectl get secrets -n synthetic-monitoringDeploy the Synthetic Monitoring Agent.
Replace
PROBE_API_SERVER_URLindeployment.yamlwith Probe API Server URL based on your stack region.kubectl apply -f deployment.yaml
Calculate resource requirements
Resources used by private probes may vary based on the targets being monitored, so it can be hard to predict them in advance. Below, we provide a rough estimate to get you started.
The baseline CPU and memory resources, if you want to run:
- API endpoint checks:
50m/64Mi. - The above, plus multi-step and/or scripted checks:
200m/256Mi. - The above, plus browser checks:
1000m/1024Mi.
Then, for each check per minute of the following types, add:
- API endpoint (HTTP, Ping, DNS, TCP, Traceroute):
5m/2Mi. - Multi-step and/or scripted:
20m/32Mi - Browser checks:
100m/256Mi.
As mentioned above, keep in mind that these are ballpark estimates. Monitor the resource usage of your probe, and stay on the lookout for CPU throttling and OOM events to see if you need to adjust any resources.
Configure feature flags
You can use feature flags to enable features in the private probe.
There are two ways to enable features:
Edit the file
/etc/synthetic-monitoring/synthetic-monitoring-agent.confand make the following changes:FEATURES = <list of features comma separated>Export the list of features as an environment variable.
export FEATURES=<list of features comma separated>
Available feature flags
These features are disabled by default.
Run k6 checks targeting private IP addresses
By default, private probes block k6 request targets in the 10.0.0.0/8 CIDR range. You can override this behavior by setting the CLI flag --blocked-nets="".
- When running Docker, append
--blocked-nets=""to yourdocker runcommand. - On Linux installations, run
systemctl edit synthetic-monitoring-agentand append--blocked-nets=""toExecStart=.
Running k6 browser checks on a private probe
To be able to run k6 browser checks on private probes, you will need to have a Chromium-compatible web browser available on the system where the probe is running. Additionally, you need to make sure that in the probe settings page in your Grafana stack (Testing & synthetics > Synthetics > Probes), both “Disable scripted checks” and “Disable browser checks” are unchecked.
k6 browser checks on Ubuntu, Debian, and RPM-based distributions
If you installed the Synthetic Monitoring Agent on your distribution via your package manager, your distribution needs to have Chromium installed, and a chromium binary available in $PATH. Alternatively, if you do not want to make chromium widely available, or you need to use a specific installation, you can add set K6_BROWSER_EXECUTABLE_PATH in the synthetic monitoring agent’s environment to the full path of a chromium binary. For advanced use cases, you can also define K6_BROWSER_ARGS with additional arguments that the agent will use when launching Chromium.
k6 browser checks on Docker, Kubernetes, and other container-based environments
For container-based environments, we provide a special image that already includes an installation of Chromium. These images are tagged with the -browser suffix, for example grafana/synthetic-monitoring-agent:vX.Y.Z-browser, as opposed to grafana/synthetic-monitoring-agent:vX.Y.Z.
Agent images tagged with the -browser suffix can run all types of checks, while those tagged without the -browser suffix can run every check type except k6 browser checks. If you do not plan to use browser checks, we recommend using the standard image, as it is lighter and more minimal. Swapping to a -browser image can be done at any time without any manual intervention, other than changing the tag.
Note
The anonymous usage statistics is enabled by default. You can opt out by setting the CLI flag
The statistics server
When usage statistics reporting is enabled, information is collected by a server that Grafana Labs operates.
Statistics are sent to https://stats.grafana.org.
Which information is collected
When the usage statistics reporting is enabled, probes collect the following information:
- Information about the probe, including:
- A unique hash representation of the probe
- The probe version, such as
0.39.0 - The installation source, such as
docker - The probe id, such as
1100 - The tenant id, such as
1100 - The features enabled, such as
k6
- Information about the environment, including:
- The operating system, such as
linux - The architecture, such as
amd64 - The os details, such as
Ubuntu 24.04.2 LTS
Keep the agent up to date
New Synthetic Monitoring features are delivered through Synthetic Monitoring Agent releases, so probes running older agent versions don’t support them. Upgrade your private probes regularly to stay on a supported version.
Keeping the agent up to date is especially important for the label migration: the un-prefixed label behavior is delivered by the agent. Upgrade all your private probes to the latest agent version before enabling dual-write.
Warning
If some of your probes run an older agent version when you migrate, those probes keep emitting custom labels with the
label_prefix while upgraded probes emit the new format. This leaves the same check with inconsistent labels across probes.This includes probes that are offline or that you no longer use: upgrade them or delete them before you migrate.
Troubleshooting private probes
If you are facing problems with your private probes, check the following:
- Check the probe version using the
-versionflag and make sure you are running a supported version. - Make sure the probe has a valid probe access token.
- Make sure the probe can connect to the Synthetic Monitoring API server.
- Run the Synthetic Monitoring Agent in debug mode with the
-debugand-verboseflags and check for errors in the logs. - Check the Synthetic Monitoring Agent metrics. The default address for Synthetic Monitoring Agent Prometheus metrics is
localhost:4050/metrics.
If you are still facing issues with Private Probes, ask for help in the community forum. Refer to Account types and support available for Grafana Cloud users for more information.
Production deployments
The agent process exposes Prometheus-style metrics on an HTTP server running on port 4050 with the “/metrics” endpoint.
You can scrape and monitor your private probe using Prometheus or Grafana Alloy.
Next steps
You must reconfigure any checks to use your new probe even if you selected all probes when initially creating the check.
The Synthetic Monitoring Agent is open source and available on GitHub.
