title: "First components and the standard library in Grafana Alloy | Grafana Cloud documentation"
description: "Learn the basics of the Grafana Alloy configuration syntax"
# First components and the standard library in Grafana Alloy
This tutorial covers the basics of the Alloy configuration syntax and the standard library. It introduces a basic pipeline that collects metrics from the host and sends them to Prometheus.
## Before you begin
To complete this tutorial:
- You must set up a [local Grafana instance](/docs/grafana-cloud/send-data/alloy/tutorials/send-logs-to-loki/#set-up-a-local-grafana-instance).
### Recommended reading
- [Alloy configuration syntax](/docs/alloy/latest/get-started/configuration-syntax)
## Alloy configuration syntax basics
An Alloy configuration file contains three elements:
1. **Attributes**
   `key = value` pairs used to configure individual settings.
   Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
   ```alloy
   url = "http://localhost:9090"
2. **Expressions**
   Expressions are used to compute values. They can be constant values, for example `"localhost:9090"`. They can be more complex, for example, referencing a component’s export: `prometheus.exporter.unix.targets`. They can also be a mathematical expression: `(1 + 2) * 3`, or a standard library function call: `sys.env("HOME")`. If you are curious, you can find a list of available standard library functions in the [Standard library documentation](/docs/grafana-cloud/send-data/alloy/reference/stdlib).
3. **Blocks**
   Blocks are used to configure components with groups of attributes or nested blocks. The following example block can be used to configure the logging output of Alloy:
   ```alloy
   logging {
       level  = "debug"
       format = "json"
   > Note
   > The default log level is `info` and the default log format is `logfmt`.
   Try pasting this into `config.alloy` and running `<BINARY_FILE_PATH> run config.alloy` to see what happens. Replace *`<BINARY_FILE_PATH>`* with the path to the Alloy binary.
   Congratulations, you’ve just written your first Alloy configuration file. This configuration won’t do anything. In the next step, you add some functionality to this configuration.
   > Note
   > Comments in Alloy syntax are prefixed with `//` and are single-line only. For example: `// This is a comment`.
## Components
Components are the building blocks of an Alloy configuration. They’re configured and linked to create pipelines that collect, process, and output your telemetry data. Components are configured with `Arguments` and have `Exports` that may be referenced by other components.
- [Components](/docs/grafana-cloud/send-data/alloy/get-started/components)
- [Components configuration language](/docs/alloy/latest/get-started/configuration-syntax/components)
- [Component controller](/docs/alloy/latest/get-started/component_controller)
### An example pipeline
Look at the following simple pipeline:
```alloy
local.file "example" {
    filename = sys.env("HOME") + "/file.txt"
prometheus.remote_write "local_prom" {
    endpoint {
        url = "http://localhost:9090/api/v1/write"
        basic_auth {
            username = "admin"
            password = local.file.example.content
> Note
> A list of all available components can be found in the [Component reference](/docs/grafana-cloud/send-data/alloy/reference/components). Each component has a link to its documentation, which contains a description of what the component does, its arguments, its exports, and examples.
This pipeline has two components: `local.file` and `prometheus.remote_write`. The `local.file` component is configured with a single argument, `filename`, which is set by calling the [sys.env](/docs/grafana-cloud/send-data/alloy/reference/stdlib/sys) standard library function to retrieve the value of the `HOME` environment variable and concatenating it with the string `"file.txt"`. The `local.file` component has a single export, `content`, which contains the contents of the file.
The `prometheus.remote_write` component is configured with an `endpoint` block, containing the `url` attribute and a `basic_auth` block. The `url` attribute is set to the URL of the Prometheus remote write endpoint. The `basic_auth` block contains the `username` and `password` attributes, which are set to the string `"admin"` and the `content` export of the `local.file` component, respectively. The `content` export is referenced by using the syntax `local.file.example.content`, where `local.file.example` is the fully qualified name of the component (the component’s type + its label) and `content` is the name of the export.
[](/media/docs/alloy/diagram-example-basic-alloy.png)
> Note
> The `local.file` component’s label is set to `"example"`, so the fully qualified name of the component is `local.file.example`. The `prometheus.remote_write` component’s label is set to `"local_prom"`, so the fully qualified name of the component is `prometheus.remote_write.local_prom`.
This example pipeline still doesn’t do anything, so its time to add some more components to it.
## Send your first metrics
Now that you have a simple pipeline, you can send your first metrics.
- Optional: [`prometheus.exporter.unix`](/docs/grafana-cloud/send-data/alloy/reference/components/prometheus/prometheus.exporter.unix)
- Optional: [`prometheus.scrape`](/docs/grafana-cloud/send-data/alloy/reference/components/prometheus/prometheus.scrape)
- Optional: [`prometheus.remote_write`](/docs/grafana-cloud/send-data/alloy/reference/components/prometheus/prometheus.remote_write)
### Modify your pipeline and scrape the metrics
Make a simple pipeline with a `prometheus.exporter.unix` component, a `prometheus.scrape` component to scrape it, and a `prometheus.remote_write` component to send the scraped metrics to Prometheus.
```alloy
prometheus.exporter.unix "localhost" {
    // This component exposes a lot of metrics by default, so we will keep all of the default arguments.
prometheus.scrape "default" {
    // Setting the scrape interval lower to make it faster to be able to see the metrics
    scrape_interval = "10s"
    targets    = prometheus.exporter.unix.localhost.targets
    forward_to = [
        prometheus.remote_write.local_prom.receiver,
    endpoint {
Run Alloy with the following command:
Bash ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```bash
Replace the following:
- *`<BINARY_FILE_PATH>`* : The path to the Alloy binary.
Navigate to [http://localhost:3000/explore](http://localhost:3000/explore) in your browser. After ~15-20 seconds, you should be able to see the metrics from the `prometheus.exporter.unix` component. Try querying for `node_memory_Active_bytes` to see the active memory of your host.
[](/media/docs/alloy/screenshot-memory-usage.png)
## Visualize the relationship between components
The following diagram is an example pipeline:
[](/media/docs/alloy/diagram-example-pipeline-prometheus.scrape-alloy.png)
Your pipeline configuration defines three components:
- `prometheus.scrape` - A component that scrapes metrics from components that export targets.
- `prometheus.exporter.unix` - A component that exports metrics from the host, built around [node\_exporter](https://github.com/prometheus/node_exporter).
- `prometheus.remote_write` - A component that sends metrics to a Prometheus remote-write compatible endpoint.
The `prometheus.scrape` component references the `prometheus.exporter.unix` component’s targets export, which is a list of scrape targets. The `prometheus.scrape` component forwards the scraped metrics to the `prometheus.remote_write` component.
One rule is that components can’t form a cycle. This means that a component can’t reference itself directly or indirectly. This is to prevent infinite loops from forming in the pipeline.
## Exercise
The following exercise guides you through modifying your pipeline to scrape metrics from Redis.
### Recommended Reading
- Optional: [`prometheus.exporter.redis`](/docs/grafana-cloud/send-data/alloy/reference/components/prometheus/prometheus.exporter.redis)
Start a container running Redis and configure Alloy to scrape the metrics.
```bash
docker container run -d --name alloy-redis -p 6379:6379 --rm redis
Try modifying the pipeline to scrape metrics from the Redis exporter. You can refer to the [`prometheus.exporter.redis`](/docs/grafana-cloud/send-data/alloy/reference/components/prometheus/prometheus.exporter.redis) component documentation for more information on how to configure it.
To give a visual hint, you want to create a pipeline that looks like this:
[](/media/docs/alloy/diagram-example-pipeline-exercise-alloy.png)
> Tip
> Refer to the [`array.concat`](/docs/grafana-cloud/send-data/alloy/reference/stdlib/array) standard library function for information about combining lists of values into a single list.
You can run Alloy with the new configuration file with the following command:
```bash
Navigate to [http://localhost:3000/explore](http://localhost:3000/explore) in your browser. After the first scrape, you should be able to query for `redis` metrics as well as `node` metrics.
To shut down the Redis container, run:
```bash
docker container stop alloy-redis
If you get stuck, you can always view a solution here:
Solution
```alloy
// Configure your first components, learn about the standard library, and learn how to run Grafana Alloy
// prometheus.exporter.redis collects information about Redis and exposes
// targets for other components to use
prometheus.exporter.redis "local_redis" {
    redis_addr = "localhost:6379"
prometheus.exporter.unix "localhost" { }
// prometheus.scrape scrapes the targets that it is configured with and forwards
// the metrics to other components (typically prometheus.relabel or prometheus.remote_write)
    // This is scraping too often for typical use-cases, but is easier for testing and demo-ing!
    // Here, prometheus.exporter.redis.local_redis.targets refers to the 'targets' export
    // of the prometheus.exporter.redis component with the label "local_redis".
    // If you have more than one set of targets that you would like to scrape, you can use
    // the 'array.concat' function from the standard library to combine them.
    targets    = array.concat(prometheus.exporter.redis.local_redis.targets, prometheus.exporter.unix.localhost.targets)
    forward_to = [prometheus.remote_write.local_prom.receiver]
// prometheus.remote_write exports a 'receiver', which other components can forward
// metrics to and it will remote_write them to the configured endpoint(s)
    endpoint {
## Finish up and next steps
You might have noticed that running Alloy with the configurations created a directory called `data-alloy` in the directory you ran Alloy from. This directory is where components can store data, such as the `prometheus.exporter.unix` component storing its Write Ahead Log (WAL). If you look in the directory, do you notice anything interesting? The directory for each component is the fully qualified name.
If you’d like to store the data elsewhere, you can specify a different directory by supplying the `--storage.path` flag to Alloy’s run command, for example, `<BINARY_FILE_PATH> run config.alloy --storage.path /etc/alloy`. Replace *`<BINARY_FILE_PATH>`* with the path to the Alloy binary. Generally, you can use a persistent directory for this, as some components may use the data stored in this directory to perform their function.
In the next tutorial, you learn how to configure Alloy to collect logs from a file and send them to Loki. You also learn how to use different components to process metrics and logs.
