This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/platform/knowledge-graph/configure/custom-red-metrics-mapping.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/platform/knowledge-graph/configure/custom-red-metrics-mapping/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Map Prometheus metrics to RED KPIs
Prometheus provides a variety of metric types that can be used to track different aspects of your service’s performance. You can map custom or non-standard Prometheus metrics to RED KPIs to leverage the features of the knowledge graph. These KPIs include request rate, error rate, latency average, and latency quantile.
Prerequisite
The knowledge graph doesn’t consider all metrics by default. To ensure that the knowledge graph includes your metrics of interest, contact Support with the list of metrics that you want to map, so that they can be enabled.
Common inputs required for all KPI mappings
When you add a new mapping, you must provide the following information:
| Field | Description |
| Source metric | Name of the Prometheus metric to be used as input |
| Metric source | Identifier for the source of the metric, for example, grpc, springboot, loopback, and so on |
| Service name | Label from the metric that identifies the service |
| Request context labels | One or more labels that together uniquely identify each request. When there are multiple labels, you must specify a separator character to join the label values. |
| Request type | Type of request being tracked. Common values include inbound and outbound. You can also specify a custom value. |
Note
When defining the KPIs individually, maintain consistency in the Request context labels and Request type field definitions. After you have provided all the required inputs, the mapped KPI displays as a metric chart. You can review the KPI metric for any selected service, request, and time window. This enables a feedback loop to validate if the KPI is providing expected results.
KPI-specific inputs
The following sections provide an overview of specific inputs that you enter depending on the KPI you are mapping.
Request rate
| Metric type | counter or gauge |
Error rate
| Error type | Label in the metric containing the error code, for example, status_code |
| Error type mapping rules | Specify how error codes are grouped into error types using:
Latency average
| Latency average type |
| Latency unit | seconds, milliseconds, or microseconds |
Latency Quantile
| Latency unit | seconds, milliseconds, or microseconds. |
| Quantiles | One or more quantiles to extract: 50%, 75%, 90%, and 99%. |
Map all KPIs using a histogram
Instead of mapping each KPI individually, you can derive the request rate, latency average, latency quantile, and error rate from a single histogram.
| Histogram metric base name | Prefix of the histogram metric before _sum, _count, _bucket. Example: for http_request_duration_seconds_sum, use http_request_duration_seconds. |
| Quantiles | Supported quantiles to extract from the histogram: 50%, 75%, 90%, and 99%. |
| Error type | Label in the histogram metric containing the error code. |
| Error type mapping rules | Specify how to group error codes into error categories using exact or pattern match. Examples:
Before you begin
Before you begin, ensure that you are familiar with Prometheus metrics and RED KPIs.
Steps
- Sign in to Grafana Cloud and click Observability > Configuration.
- Click RED mapping.
- Determine which KPI you want to map and click Add new mapping.
- Define the mapping as described in the above sections.
- Click Submit.
Was this page helpful?
