title: "Add a custom metric to the knowledge graph | Grafana Cloud documentation"
description: "Make a metric that the built-in rules don't recognize part of the knowledge graph, with a custom entity, relationship, KPI, and insight"
# Add a custom metric to the knowledge graph
The knowledge graph recognizes standard OpenTelemetry and Prometheus metrics and many common frameworks. When you send a metric that no built-in rule recognizes, the knowledge graph still stores it and you can query it, but it doesn’t create entities, relationships, KPIs, or insights from it.
This topic shows how to make such a metric part of the graph. You add:
- A new entity type
- A relationship between the new entity type and an existing one
- A KPI mapping that feeds the metric into the standard KPIs
- An alert rule that produces a new insight
You add the entity, relationship, and alert rule as YAML files that you apply with [gcx](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/), and the KPI mapping on the **RED mapping** page in Grafana Cloud. To understand the stages these files extend, refer to [How the knowledge graph processes data](https://grafana.com/docs/grafana-cloud/knowledge-graph/reference/how-knowledge-graph-processes-data/).
## Before you begin
Before you begin, ensure that:
- You have installed gcx and connected it to your Grafana Cloud stack.
- You have the Editor or Admin basic role, or the `plugins:grafana-asserts-app:knowledge-graph-writer` permission. For more information, refer to [Roles and permissions](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/permissions/#knowledge-graph).
- You are familiar with PromQL and YAML.
- Your metric carries the labels that identify the environment and site. The rules in this topic select series where `asserts_env` isn’t empty. The knowledge graph sets `asserts_env` and `asserts_site` during label normalization, before these rules run. For more information, refer to [Environment and region](https://grafana.com/docs/grafana-cloud/knowledge-graph/reference/about-environment-region/).
## Example metrics
The examples in this topic use a fictional order dispatch system that emits two metrics:
![Copy code to clipboard](https://grafana.com/media/images/icons/icon-copy-small-2.svg) Copy
```none
fulfillment_dispatch_requests_total{service, namespace, city, dispatch_zone, outcome="matched|failed|timeout"}
fulfillment_dispatch_duration_seconds_bucket{service, namespace, city, dispatch_zone, outcome, le}
The second metric is a histogram, so it also has `_sum` and `_count` series.
Operators of this system think in dispatch zones, so the goal is to make each zone an entity, connect it to the services that serve it, and raise an insight when too many dispatches fail.
## Define a new entity type
An entity rule turns each value of a label into an entity. The following rule creates a `DispatchZone` entity for each `dispatch_zone` value.
1. Create a file called `dispatch-model-rules.yaml` with the following contents:
   YAML ![Copy code to clipboard](https://grafana.com/media/images/icons/icon-copy-small-2.svg) Copy
   ```yaml
   entities:
     - type: DispatchZone
       scope:
         namespace: namespace
         env: asserts_env
         site: asserts_site
       definedBy:
         - query: |-
             group by (asserts_env, asserts_site, namespace, dispatch_zone, city) (
               fulfillment_dispatch_requests_total{asserts_env!="", dispatch_zone!=""}
           labelValues:
             dispatch_zone: dispatch_zone
             city: city
           literals:
             domain: dispatch
   The `name` and `scope` fields together identify one entity. Each value in `labelValues` becomes a property of the entity, and each value in `literals` becomes a property with fixed text. For a description of every field, refer to [Manage entities and relations](https://grafana.com/docs/grafana-cloud/knowledge-graph/configure/manage-entities-relations/#define-custom-entities-and-relations).
   Entity discovery uses only the labels in `name`, so the match is strict. An entity rule can also have a `lookup` field, which lists extra labels that the knowledge graph uses to find an existing entity when it enriches the entity or attaches an alert to it. If an alert’s labels don’t match the entity’s name, the knowledge graph tries the `lookup` labels instead. For example, it can match an alert’s `instance` label against the entity’s `ip` property. Keeping the two separate keeps discovery precise and alert correlation flexible. This example doesn’t use `lookup`.
## Define a relationship
The same metric carries both `service` and `dispatch_zone`, so one query can define a relationship between them.
1. Add the following `relations` section to `dispatch-model-rules.yaml`:
   ```yaml
   relations:
     - type: SERVES
       startEntityType: Service
       endEntityType: DispatchZone
       definedBy:
         source: METRICS
         pattern: |-
           group by (asserts_env, asserts_site, namespace, service, dispatch_zone) (
             fulfillment_dispatch_requests_total{asserts_env!="", service!="", dispatch_zone!=""}
         startEntityMatchers:
           env: asserts_env
           site: asserts_site
         endEntityMatchers:
           env: asserts_env
           site: asserts_site
   The knowledge graph draws one `SERVES` relationship for each result series. It only draws the relationship when both the Service and the DispatchZone exist in the same environment, site, and namespace.
2. Validate the file. The `--dry-run` flag checks the file against your stack and shows a diff without changing anything:
   Bash ![Copy code to clipboard](https://grafana.com/media/images/icons/icon-copy-small-2.svg) Copy
   ```bash
   gcx kg model-rules upsert -f dispatch-model-rules.yaml --dry-run
3. Apply the file:
   ```bash
You can also add entity and relationship rules on the **Entity &amp; Relation** rules page in Grafana Cloud, or with Terraform. For more information, refer to [Manage entities and relations](https://grafana.com/docs/grafana-cloud/knowledge-graph/configure/manage-entities-relations/).
## Map the dispatch histogram to KPIs
Map the dispatch duration histogram to the standard KPIs. From one histogram, the knowledge graph derives the request rate, error ratio, average latency, and latency quantiles. The built-in KPI insights and the KPI charts in the knowledge graph then use them.
1. Sign in to Grafana Cloud and click **Observability &gt; Configuration**.
2. Click **RED mapping**.
3. Click **Add new mapping** and choose to map all KPIs using a histogram.
4. Enter the following values:
   Expand table
   | Field                          | Value                                   |
   | **Histogram metric base name** | `fulfillment_dispatch_duration_seconds` |
   | **Metric source**              | `fulfillment_dispatch`                  |
   | **Service name**               | `service`                               |
   | **Request context labels**     | `dispatch_zone`                         |
   | **Request type**               | `inbound`                               |
   | **Latency unit**               | `seconds`                               |
   | **Quantiles**                  | `99%`                                   |
   | **Error type**                 | `outcome`                               |
   | **Error type mapping rules**   | Regex: `outcome =~ "failed|timeout"`    |
5. Review the chart of a mapped KPI for one service, then click **Submit**.
The base name is the histogram name without the `_sum`, `_count`, or `_bucket` suffix. You can also map each KPI on its own. For a description of every field, refer to [Map Prometheus metrics to RED KPIs](https://grafana.com/docs/grafana-cloud/knowledge-graph/configure/custom-red-metrics-mapping/). If the page doesn’t support your metric, contact Support. You can’t map KPIs with gcx.
## Add an insight
An alert rule defines a new insight, `DispatchFailureRatioHigh`, for failed dispatches.
1. Create a file called `dispatch-prom-rules.yaml` with the following contents:
   ```yaml
   groups:
     - name: dispatch.insights
       rules:
         - alert: DispatchFailureRatioHigh
           for: 5m
           expr: |-
             sum by (namespace, job, service, asserts_env, asserts_site) (
               rate(fulfillment_dispatch_requests_total{asserts_env!="", outcome=~"failed|timeout"}[5m])
               rate(fulfillment_dispatch_requests_total{asserts_env!=""}[5m])
             ) > 0.05
           labels:
             asserts_severity: critical
             asserts_alert_category: error
             asserts_entity_type: Service
             asserts_source: fulfillment_dispatch
2. Validate the file:
   ```bash
   gcx kg prom-rules upsert -f dispatch-prom-rules.yaml --dry-run
3. Apply the file:
   ```bash
Within a few minutes, when the failure ratio stays greater than 5% for five minutes, a `DispatchFailureRatioHigh` insight appears on the Service entity that owns the metric, next to the built-in insights.
You can also add alert rules on the **Bring your own** rules page in Grafana Cloud. That page and `gcx kg prom-rules` manage the same rules. For more information, refer to [Define a health threshold](https://grafana.com/docs/grafana-cloud/knowledge-graph/configure/manage-thresholds/#define-a-health-threshold).
### Labels on the alert rule
The labels on an alert rule determine which entity the insight belongs to and how it appears.
Expand table
| Label or field                                  | Purpose        |
| `asserts_entity_type` and the `by (...)` labels | Together, these must identify exactly one entity. In the example, that’s a Service in one environment, site, and namespace. If you group by fewer labels, the knowledge graph can’t attach the insight to an entity. |
| `asserts_severity`                              | The impact level: `info`, `warning`, or `critical`.        |
| `asserts_alert_category`                        | Groups the insight in the knowledge graph: `saturation`, `amend`, `anomaly`, `failure`, or `error`.        |
| `for`                                           | How long the condition must hold before the insight fires.        |
## Check the result
1. Confirm that the new entities exist:
   ```bash
   gcx kg entities list --type DispatchZone --env prod
2. Find the services that serve a zone, and the services they call:
   ```bash
   gcx kg graph query "MATCH (s:Service)-[:SERVES]->(z:DispatchZone {name:'midtown'}) OPTIONAL MATCH (s)-[:CALLS]->(d:Service) RETURN s, z, d LIMIT 50"
3. Look for the new insight on a service:
   ```bash
   gcx kg entities inspect --type Service --name <service> --env prod --namespace <namespace> --since 1h
If an entity, relationship, or insight is missing, refer to [Troubleshoot entity discovery by stage](https://grafana.com/docs/grafana-cloud/knowledge-graph/get-started/troubleshooting/#troubleshoot-entity-discovery-by-stage).
## Best practices
- **Put the identity in the labels.** Emit consistent `service`, `namespace`, and environment labels. The rest of the graph depends on them.
- **Start with a dry run.** Both `upsert` commands validate against your stack and show a diff before they change anything.
- **Keep queries cheap.** Entity and relationship queries run against your metrics on a regular cycle. Select on the metric name and group by only the labels you need.
- **Get editor autocomplete.** Run `gcx kg model-rules schema` or `gcx kg prom-rules schema` to get the JSON Schema for each file type.
## Related commands
Expand table
| To                                                       | Run        |
| Define entity types and relationships                    | `gcx kg model-rules upsert -f <file>`. Also `list`, `get`, `delete`, and `schema`. |
| Add alert rules for insights                             | `gcx kg prom-rules upsert -f <file>`. Also `list`, `get`, `delete`, and `schema`.  |
| Silence an insight                                       | `gcx kg suppressions upsert -f <file>`                                             |
| Route insights to notifications                          | `gcx kg notifications upsert -f <file>`                                            |
| View the rules that set `asserts_env` and `asserts_site` | `gcx kg relabel-rules get`                                                         |
For all flags, refer to the [gcx CLI reference](https://grafana.com/docs/grafana/latest/ai-tools/grafana-cli/gcx/cli-reference/).
