This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/platform/knowledge-graph/advanced-configuration/mapping-metrics-to-insights/resource-utilization-and-saturation.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/platform/knowledge-graph/advanced-configuration/mapping-metrics-to-insights/resource-utilization-and-saturation/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Resource utilization and saturation
Learn how the knowledge graph maps resource utilization and saturation metrics.
Resource Utilization
Some resources have a finite limit. For these resources, you can:
- Express their current level of utilization as a ratio against the limit.
- Observe their utilization, and get early warning of their saturation.
For these cases, record the asserts:resource metric.
For example, consider the number of clients for a Redis server. Redis has a configuration to limit the max number of clients. This limit as well as the current number of clients is available through metrics exposed by the Redis exporter.
| Metric | Details |
redis_connected_clients | Number of active client connections |
redis_config_maxclients | Maximum number of client connections allowed |
Considering that the number of clients is a finite resource, it’s useful to track the resource’s utilization, and receive an early warning before the resource actually saturates. To achieve this, record the asserts:resource metric.
- record: asserts:resource
expr: >
max by (asserts_env, asserts_site, namespace, service, job) (
redis_connected_clients / redis_config_maxclients
labels:
asserts_entity_type: Service
asserts_resource_type: client_connections
asserts_source: redis_exporterWith this, the client connections utilization is normalized to a scale of 0-1. We now need to define the warning and critical thresholds for Saturation.
- record: asserts:resource:threshold
expr: 0.8
labels:
asserts_severity: warning
expr: 0.9
labels:
asserts_severity: criticalThe thresholds can also be managed in the UI at Home -> Observability -> Rules -> Thresholds under the Resource tab.
Understand the knowledge graph meta labels and aggregation
asserts_env and asserts_site
The same Redis service may be deployed in multiple environments. In the knowledge graph, all services and other infrastructure components are grouped by environment and site. For example, asserts_env = prod and asserts_site = us-west-2. The metrics, alerts and the services discovered from these metrics are scoped by these labels.
namespace and service
There may be multiple deployments of Redis for different functionalities. For example, redis-payments, redis-orders etc. In K8s, these would be deployed as different stateful services. The knowledge graph uses the namespace and service label in the metric to uniquely identify each service in a given environment.
job
In non-k8s environment, the prometheus metric scrape configuration has a different value for the job label for each different deployment of Redis. The knowledge graph uses the job label in the metric to uniquely identify each service in a given environment.
Aggregation
So far we have identified the labels that uniquely identify the service in a multi-environment, multi-service setup. Redis may also be setup as a cluster with multiple instances. Since the connection count metric is available at the instance level, the utilization is computed at the instance level. But we want the alert to fire for the Redis service and not for a specific instance. So we track the highest utilization amongst all instances by using the max by(...) aggregation. We retain the asserts_env, asserts_site, namespace, service, job labels in the aggregation clause to help the knowledge graph associate the alert with the correct service entity.
asserts_entity_type
In the knowledge graph entity model, all infrastructure components are modeled as different types of entities. For example, Service, ServiceInstance, Pod, Node, and so on. Redis is a Service and the different instances of a clustered Redis are ServiceInstance. But as explained in the Aggregation section earlier, the knowledge graph associates the alert at the service level. This is achieved by the meta label specification asserts_entity_type: Service.
If you want to track the connection saturation at an individual instance, you can tweak the rule as follows:
expr: >
max by (asserts_env, asserts_site, namespace, service, job, instance) (
labels:
asserts_entity_type: ServiceInstance
asserts_source: redis_exporterThe expression now includes the instance label and the entity type is set to ServiceInstance.
Similarly, the knowledge graph models the various resources that it observes into different types. For example, cpu:usage , memory:usage, disk:usage etc are different types of resources. In this example, what is being observed is client_connections. You may set it to any value that best describes the resource and signal being observed.
asserts_source
Sometimes, the same or similar metrics may be available from multiple instrumentations. The asserts_source is a useful meta label to indicate what is the source exporter of the metric. This is helpful when investigating the alert.
We now have a recording rule to track utilization. We also understand the different parts of the recording rule. The knowledge graph now starts observing for utilization of client connections and raise alerts when the warning or critical threshold is exceeded. The knowledge graph has a default threshold for all resource utilization. The thresholds for Saturation of different resources can be configured here.
Was this page helpful?
