This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/platform/knowledge-graph/advanced-configuration/enable-prom-metrics-collection/insight-rules.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/platform/knowledge-graph/advanced-configuration/enable-prom-metrics-collection/insight-rules/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Base rules and framework-specific rules
The knowledge graph uses a curated library of rules to analyze incoming time-series data and generate important alerts called insights. These insights are then classified into Saturation, Amend, Anomaly, Failure, and Error. The implementation of the knowledge graph involves two sets of rules: base rules and framework-specific rules, which are responsible for raising these insights.
Base rules are for common request and resource metrics across platforms and frameworks. The table below summarizes base insights raised by base rules.
| Insight | Insight category | |
| Request | RequestRateAnomaly | Anomaly |
| LatencyAverageAnomaly | Anomaly | |
| LatencyAverageBreach | Error | |
| LatencyP99ErrorBuildup | Error | |
| ErrorRatioAnomaly | Anomaly | |
| InboundClientErrorAnomaly | Anomaly | |
| ErrorRatioBreach | Error | |
| Logging | LoggerRateAnomaly | Anomaly |
| ErrorLogRateBreach | Error | |
| Resource | Saturation | Saturation |
| ResourceRateAnomaly | Anomaly | |
| ResourceRateBreach | Error | |
| ResourceMayExhaust | Error |
Framework-specific rules raise a variety of insights, typically falling into the categories of Failure, Amend, and Saturation. For more information about insight categories, refer to Insights categories.
The following image shows a sample of frameworks and libraries for which built-in insights are available.
Was this page helpful?
