title: "Understand volume discounts | Grafana Cloud documentation"
description: "Learn how Grafana Cloud volume discounts automatically lower your effective rate as your usage grows."
# Understand volume discounts
As of July 1, 2026, every Grafana Cloud Pro customer on the latest plan earns volume discounts based on how much you consume. As your usage grows, your effective rate decreases automatically.
Your monthly Grafana Cloud price includes a base amount of usage for each product. Usage beyond that base is billed per product at a rate based on the volume you consume. Volume discounts are applied as follows:
Expand table
| Tier   | Rate                   |
| Tier 1 | Standard rate          |
| Tier 2 | Discounted rate        |
| Tier 3 | Deeper discounted rate |
Volume discounts have the following characteristics:
- **Automatic:** Discounts apply as soon as your usage for a product crosses into Tier 2. There’s nothing to enable, sign, or renegotiate.
- **Per product:** Each product, such as metrics, logs, and traces, earns its own volume discounts independently.
- **Based on current usage:** Volume tiers reset each billing period, so your discount matches what you consume that month, whether your usage goes up or down.
Discounts typically begin at around $500 per month of spend per product and deepen from there. Your monthly included usage stays the same.
## Understand marginal tiers
Each band of usage is billed at its own rate. Crossing a threshold only changes the rate for the next band, not your whole bill. Your **effective rate** is the blended average across all of your usage. As your usage enters the higher tiers, that blended rate decreases.
For example, if the base rate is $6.50 per 1,000 series, with volume discounts, if you consume 500,000 active metric series in a month, your effective rate is $5.77 per 1,000 series.
> Note
> The following examples might not reflect the current rates. See the [pricing page](/pricing/#calculator) for the latest rates.
Expand table
| Usage band                | Marginal rate       | Cost                                |
| First 100,000 series      | $6.50 per 1,000     | $585 (first 10,000 series included) |
| Next 100,000 series       | $5.90 per 1,000     | $590                                |
| Next 300,000 series       | $5.50 per 1,000     | $1,650                              |
| **Total: 500,000 series** | **$5.77 per 1,000** | **$2,825**                          |
Without volume discounts, your effective rate is $6.50 per 1,000 series.
Expand table
| Usage          | Rate            | Cost      |
| 500,000 series | $6.50 per 1,000 | $3,250/mo |
Your effective rate drops from $6.50 to $5.77 per 1,000 series, an 11% savings. The same framework applies across every Grafana Cloud product.
## View your discounts
View your usage and any applied volume discounts in the Cost Management and Billing app in your Grafana Cloud stack.
To model your own numbers, use the [pricing calculator](/pricing/#calculator) to estimate savings at your usage level.
## Committed contract pricing
The published volume discounted rates are meant for our customers on basic usage plans. If your usage is scaling and you’re ready to commit, a committed contract agreement can offer even better unit economics. [Contact us](/contact/enterprise/?pg=pricing&plcmt=enterprise&value=volume%2Bbased%2Bpricing%2Binquiry&topic=volume-pricing) to explore committed pricing tailored to your growth.
