This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/platform/cost-management-and-billing/manage-invoices/understand-your-invoice/usage-limits.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/platform/cost-management-and-billing/manage-invoices/understand-your-invoice/usage-limits/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Understand Grafana Cloud usage limits
Grafana Cloud continuously provides your account limits in the following metrics:
grafanacloud_instance_metrics_limitsgrafanacloud_logs_instance_limitsgrafanacloud_traces_instance_limits
To find these limits in your Grafana Cloud instance:
- Click Explore (compass icon).
- Select
grafanacloud-usagefrom the drop-down menu. - In the Metrics browser query field, enter the metric, for example
grafanacloud_instance_metrics_limits. - Click Run query.
The label limit_name provides the specific limit. See below for a complete reference.
Metric usage limits
The following limits apply to Grafana Cloud Metrics.
Note
Usage time limits are recorded internally using the Go
time.Durationrepresentation, which is in nanoseconds. To get to something useful, like “days” you divide the limit in nanoseconds by 1 billion and then divide that by 86400 (seconds in a day).
Metric ingestion limits
| Limit name | Limit description | Default limit |
ingestion_rate | The maximum number of ingested samples per second for a series. | 10,000 |
ingestion_burst_size | The maximum allowed ingestion burst size in number of samples. | 200,000 |
max_global_series_per_user | The total maximum series for each user in an instance. | 150,000 |
max_global_exemplars_per_user | The total maximum exemplars for each user in an instance. | 100,000 |
max_aggregation_ingestion_rate | The maximum ingestion rate for aggregated metrics. | 250,000 |
max_aggregated_tenant_series | The maximum series for aggregated tenant metrics. | 3,000,000 |
max_global_metadata_per_user | The maximum number of different sets of help text and unit in an instance. | 30,000 |
max_global_metadata_per_metric | The maximum number of different sets of help text and unit per metric. | 10 |
out_of_order_time_window | The maximum allowed time window for out-of-order samples in nanoseconds. | 7,200,000,000,000 (2 hours) |
Metric Query limits
max_partial_query_length | The maximum time range for partial queries at the querier level (exported in seconds). | 2,764,800 seconds (32 days) |
max_fetched_chunks_per_query | The maximum number of chunks with compressed samples that each query can fetched from the storage. | 2,000,000 |
max_query_expression_size_bytes | The maximum length of a PromQL query expression after any variables have been replaced with their values. | 128KiB |
max_labels_query_length | The maximum time range for label names and values queries. If the requested time range is outside the allowed range, the request is manipulated to only query data within the allowed time range. | 2,764,800 seconds (32 days) |
Rules limits
ruler_max_rule_groups_per_tenant | The maximum number of rule groups for an instance. | 35 |
ruler_max_rules_per_rule_group | The maximum number of rules per rule group for an instance. | 20 |
About limit autoscaling
Grafana Cloud automatically scales some metric usage limits based on your consumption. Limits are continuously autoscaled.
The following limits are autoscaled:
ingestion_rateingestion_burst_sizemax_global_series_per_usermax_aggregation_ingestion_ratemax_global_metadata_per_usermax_aggregated_tenant_seriesruler_max_rule_groups_per_tenantruler_max_rules_per_rule_group
To adjust a limit that isn’t autoscaled, contact Grafana Support.
Logs usage limits
Log ingestion limits
ingestion_rate_mb | Per-user ingestion rate in MB. | 5 |
max_global_streams_per_user | The maximum number of active streams per user, across ingesters. | 5,000 |
retention_period | Compactor retention for storage, in nanoseconds. | 2,678,400,000,000,000 (31 days) |
max_line_size | The maximum size of a log line. This limit can’t be modified. | 256kb |
max_label_names_per_series | The maximum number of labels per stream. | 15 |
max_label_name_length | The maximum size label name. | 1024 |
max_label_value_length | The maximum size label value. | 2048 |
Log query limits
max_query_length | The maximum time range for partial queries at the querier level,in nanoseconds. | 2,595,600,000,000,000 (30 days + 1 hr) |
max_query_lookback | Querier limit on how far back data can be queried. | 0 (disabled) |
max_query_series | The maximum unique series that can be returned by a metric query. | 500 |
Traces usage limits
Use these metrics to help track your traces usage limits.
max_bytes_per_trace | The maximum size of a trace in bytes. | 3,000,000 |
ingestion_rate_limit_bytes | Per-tenant ingestion rate limit per second in bytes. | 500,000 |
ingestion_burst_size_bytes | Per ingestion burst size in bytes. | 500,000 |
block_retention | The duration to keep blocks/traces in nanoseconds. | 2,592,000,000,000,000 (30 days) |
Discarded Spans panel in the Billing dashboard
In the Billing dashboard, there is a panel that shows Discarded Spans and a color-coded legend with a reason why the spans were discarded. The table that follows defines each of those reasons.
| Reason for discarded span | Description |
internal error | A general error that should be further explained in the logs. |
live_traces_exceeded | Exceeded the max number of traces allowed in the ingester per tenant. |
rate limited | Exceeded the ingestion_rate_limit_bytes limit. |
trace_too_large | Exceeded the max_bytes_per_trace limit. |
trace_too_large_to_compact | Exceeded the max_bytes_per_trace limit during compaction. |
You can use grafanacloud_traces_instance_percentage_complete_traces_flushed metric.
This metric has a value between 0 and 1, indicating the percentage of traces without any orphaned spans when the trace is flushed to storage.
In addition, you can use the grafanacloud_traces_instance_discarded_spans_total:rate5m metric to review the number of discarded spans, including the reasons for discarding, in 5 minute periods.
When a trace is too large to be ingested, it is discarded. This can happen for a few reasons:
- Ingestion: Traces are refused with
trace_too_largeerror - Search: Oversized traces are skipped with
trace_too_largeerror - Compaction: Oversized traces are partially dropped with
trace_too_large_to_compacterror
The default limit for traces is 5MB, which, in Tempo, is configured by max_bytes_per_trace.
Let’s say that you want more information about traces that are discarded because they were too large.
You can query for the grafanacloud_traces_instance_discarded_spans_total:rate5m metric using the grafanacloud-usage data source.
To narrow the results down to the specific “trace too large” reason, modify the query to be grafanacloud_traces_instance_discarded_spans_total:rate5m{reason="trace_too_large"}.
While the grafanacloud_traces_instance_discarded_spans_total:rate5m metric shows the number of discarded spans, it doesn’t provide any information on where the large traces originate.
To identify which services are causing discards using TraceQL, and to learn how to reduce the discard rate, refer to Discarded traces.
Grafana Cloud usage
Grafana Cloud continuously provides your account usage in the following metrics:
grafanacloud_instance_metrics_*grafanacloud_logs_instance_*grafanacloud_traces_instance_*
For example, to monitor log stream count, you can use grafanacloud_logs_instance_active_streams.
Cloud Traces usage
If you need to have a limit raised, then contact Grafana Support for assistance.
| Metric | Description |
grafanacloud_traces_instance_bytes_received_per_second | Number of bytes received by each Grafana Cloud Traces stack for the organization. |
grafanacloud_traces_instance_created_date | Date (milliseconds since epoch) when the instance was created. |
grafanacloud_traces_instance_discarded_spans_total:rate5m | Number of discarded spans, including the reasons for discarding, in 5 minute periods. |
grafanacloud_traces_instance_percentage_complete_traces_flushed | A value between 0 and 1 indicating the percentage of traces without any orphaned spans when the trace is flushed to storage. |
grafanacloud_traces_instance_info | Information about the instance such as org ID and customer ID. |
grafanacloud_traces_instance_limits | Span volume limits for the organization, on a per-stack basis. |
grafanacloud_traces_instance_queries_per_second | Number of queries that are carried out on a per-second rate basis. |
grafanacloud_traces_instance_spans_received_total:rate5m | Per second rate of spans received by each Grafana Cloud Traces stack for the organization, over a 5 minute period. |
grafanacloud_traces_instance_usage | Billable trace usage over the last month for stacks in the organization. |
grafanacloud_traces_instance_metrics_generator_active_series | Number of active series being generated via ingested spans. |
grafanacloud_traces_instance_percentage_traces_with_root_spans_flushed | A value between 0 and 1 indicating the percentage of traces with root spans when the trace is flushed to storage. |
Other usage limits
The following limits apply to Grafana Cloud resources to protect platform stability and ensure a consistent experience for all customers. Reaching these limits does not affect your invoice. Paid customers can request higher limits at no additional cost by contacting Grafana Support.
Dashboard and folder limits
dashboard.grafana.app/dashboards | The maximum number of dashboards per stack. | 1,000 |
folder.grafana.app/folders | The maximum number of folders per stack. | 1,000 |
When a stack reaches approximately 80% of a limit, users see a warning in the Grafana UI. At the limit:
- New dashboards or folders cannot be created.
- Existing dashboards and folders are not removed.
- Saves that would exceed the limit are blocked.
Free tier stacks are hard-limited at the default. Paid customers can request a higher limit through Grafana Support.
Note
The existing dashboard size limit of 16 MB is not affected by these limits.
Was this page helpful?
