title: "Reduce Grafana Cloud Profiles costs | Grafana Cloud documentation"
description: "Reduce your Grafana Cloud Profiles costs."
# Reduce Grafana Cloud Profiles costs
Control your profiling costs by managing which services you profile, which profile types you collect, and how much label metadata you attach to your profiling data.
Grafana Cloud Profiles usage is measured in GB ingested per month. The main factors that affect your profiling costs are the number of services you profile, the number of profile types you enable per service, and the labels you attach to each profile. By reviewing these factors, you can reduce the volume of profiling data and lower your costs.
For more details about how profiles usage is calculated, refer to [Understand your Grafana Cloud Profiles invoice](/docs/grafana-cloud/cost-management-and-billing/understand-your-invoice/profiles-invoice/).
## Review your usage
You can review your profiles usage on the [Billing and Usage dashboard](/docs/grafana-cloud/cost-management-and-billing/understand-your-invoice/#billing-and-usage-dashboard). Configure [usage alerts](/docs/grafana-cloud/cost-management-and-billing/usage-cost-alerts/) to notify your team when activity exceeds expected levels.
## Reduce the number of services you profile
Profile only the services where profiling data provides actionable value. Services with stable, well-understood performance characteristics may not need continuous profiling.
Review the services sending profiling data and disable profiling for services that don’t require it. Focusing on critical or high-traffic services reduces data volume without losing visibility where it matters.
## Select only the profile types you need
Each profile type, such as CPU, memory, goroutine, `mutex`, or block, generates its own data stream. Collecting all profile types for every service increases data volume.
The available profile types depend on the SDK you use to instrument your application. Refer to [Profile types and instrumentation](/docs/pyroscope/next/configure-client/profile-types/) for the available profile types for each SDK.
Enable only the profile types relevant to the issues you’re investigating. For example, if you’re focused on CPU bottlenecks, you don’t need to collect memory or `mutex` profiles at the same time.
## Manage labels
Labels add metadata to your profiles and increase the size of your profiling data. Adding unnecessary labels increases ingestion volume and costs.
Minimize the number of external labels you attach to each profile. If you use Grafana Alloy, you can use the [`pyroscope.relabel`](/docs/alloy/next/reference/components/pyroscope/pyroscope.relabel/) component to filter profiles or standardize the external labels before profiles are forwarded to Grafana Cloud. The `pyroscope.relabel` component only rewrites external labels, such as labels inferred by `pyroscope.scrape` or provided through the `/ingest` query parameter. It doesn’t modify labels embedded inside profile payloads like pprof sample labels.
## Use Adaptive Profiles to reduce costs
You can use [Adaptive Profiles](/docs/grafana-cloud/adaptive-telemetry/adaptive-profiles/) to continuously profile every service in your stack at a reduced sample rate, with full-resolution boosts on demand.
> Note
> Adaptive Profiles is currently in [private preview](/docs/release-life-cycle/). Grafana Labs offers support on a best-effort basis, and breaking changes might occur prior to the feature being made generally available.
Each service is sampled at 10% by default, which keeps continuous profiling coverage on across the whole stack at a fraction of the cost. When you need full detail, boost a service manually for a chosen duration, or let Adaptive Profiles boost automatically when it detects a new version of a service.
Refer to the [Adaptive Profiles documentation](/docs/grafana-cloud/adaptive-telemetry/adaptive-profiles/) for more information.
