title: "Connect Synthetic Monitoring checks to the Knowledge graph | Grafana Cloud documentation"
description: "Link Synthetic Monitoring checks to the services they monitor in the Knowledge graph, so your checks appear alongside those services, their dependencies, and their health."
# Connect Synthetic Monitoring checks to the Knowledge graph
> Note
> Synthetic Monitoring Knowledge graph integration is currently in [public preview](/docs/release-life-cycle/). Grafana Labs offers limited support, and breaking changes might occur prior to the feature being made generally available.
A Synthetic Monitoring check tests a target from the outside and assesses its availability, performance, and correctness. Depending on the [check type](/docs/grafana-cloud/testing/synthetic-monitoring/create-checks/checks/), that ranges from a single DNS lookup or HTTP request to a k6 browser check driving a whole user journey. What a check doesn’t describe is the system behind the target. The [Knowledge graph](/docs/grafana-cloud/knowledge-graph/) does: it maps your services, their dependencies, and their health. Connecting the two puts a check’s outside view next to the inside view of the service it tests.
When the Knowledge graph is activated on your stack, every check appears in it automatically as a `SyntheticCheck` entity. You can then link a check to the service it monitors by setting two labels on the check, which connects the check to that service in the [Entity graph](/docs/grafana-cloud/knowledge-graph/troubleshoot-infra-apps/explore-entity-graph/).
After a check is linked, you can see the service it monitors, follow that service’s dependencies, and see the check’s health on the service and the service’s health on the check. In Synthetic Monitoring, both appear on the check’s dashboard. Viewing check results alongside service health and dependencies helps you narrow down where to investigate failures.
[The Insights menu shows an active check insight and three connected services.](/media/knowledge-graph-insights-edit.png)
## How the integration works
- **Checks become entities.** Every check appears in the Knowledge graph as a `SyntheticCheck` entity, automatically and with no configuration. The entity is named after the check’s job name and target, joined by a double underscore, for example `traceroute__grafana.com`.
- **Linking connects a check to a service.** When you set the `service_name` and `namespace` labels on a check, and their values match a service the Knowledge graph has already discovered, the Knowledge graph creates a `MONITORED_BY` relationship from that service to the check. The service and the check are then one hop apart in the Entity graph.
- **Check health comes from your Synthetic Monitoring alerts.** The [insights rings](/docs/grafana-cloud/knowledge-graph/reference/insights-categories/#insight-rings-and-severity) on a `SyntheticCheck` entity use the firing state of that check’s own [per-check alerts](/docs/grafana-cloud/testing/synthetic-monitoring/configure-alerts/configure-per-check-alerts/). Insights on a check also propagate to the service it monitors.
An unlinked check still appears in the Knowledge graph and still carries its own health. Linking is what places it next to the service it monitors.
## Before you begin
- Ensure the [Knowledge graph is activated](/docs/grafana-cloud/knowledge-graph/get-started/#activate-the-knowledge-graph) on your stack.
- The service you want to link to must already be discovered by the Knowledge graph, or be discovered later. Refer to [Manage dataset configurations](/docs/grafana-cloud/knowledge-graph/get-started/manage-datasets/).
- To link a check to a service, you need permission to edit checks in Synthetic Monitoring. Refer to [Manage users and teams for Synthetic Monitoring](/docs/grafana-cloud/testing/synthetic-monitoring/user-and-team-management/).
## Link a check to a service
The `service_name` and `namespace` label values are the identity of the service. They must match the name and namespace of a service in the Knowledge graph. They follow the OpenTelemetry conventions for `service.name` and `service.namespace`, and `namespace` also matches the Kubernetes namespace, so the same values work for both OpenTelemetry-instrumented and Kubernetes-discovered services.
> Note
> Setting the `service_name` label also associates the check with that service in [Service Center](/docs/grafana-cloud/observe-and-act/alert-and-measure-reliability/service-center/), so the same label links your check across both surfaces.
To link a check to a service:
1. Navigate to **Testing &amp; synthetics** &gt; **Synthetics** &gt; **Checks**.
2. Create a check, or select an existing check to edit it.
3. Go to the **Labels** step.
4. In the **Link to Knowledge Graph service** section, set a value for each label:
   1. For `service_name`, select or enter the name of the service the check monitors.
   2. For `namespace`, select or enter the namespace of that service.
   Both fields suggest values from the services the Knowledge graph has already discovered. You can also enter a value that doesn’t exist yet, for a service that hasn’t been discovered.
5. Complete the remaining steps, then click **Save**.
Allow a few minutes for the link to appear in the Knowledge graph.
You can also set these labels through the [Synthetic Monitoring API](/docs/grafana-cloud/testing/synthetic-monitoring/api-reference/) or the [Terraform provider](/docs/grafana-cloud/testing/synthetic-monitoring/set-up/provision-synthetic-monitoring-resources/), which is the fastest way to link many checks at once.
## View Knowledge graph data on a check dashboard
Open a check from **Testing &amp; synthetics** &gt; **Synthetics** &gt; **Checks**. Two Knowledge graph surfaces appear on the check’s dashboard.
### Insights
In the check dashboard header, click **Insights**, next to **Edit check**, to view the check’s Knowledge graph insights and connected entities.
### Connected services
The **Connected services** section shows the check’s neighborhood in the Entity graph. It includes:
- The check itself, highlighted and anchoring the top of the graph.
- The service linked to it through `MONITORED_BY`.
- That service’s immediate callers and dependencies, one `CALLS` hop in each direction.
Each node carries its own insights rings, so a service with active insights appears ringed next to your check. Hover over a node to preview its details, or click it to pin a card showing the entity’s type, environment and namespace, key performance indicators, and active insights.
[The Connected services graph shows a check’s linked service and neighboring services, with a service preview showing performance metrics.](/media/knowledge-graph-connected-services.png)
If the linked service exists in more than one environment, the graph shows a branch per environment and an **Env** filter appears above it. Select one or more environments to narrow the graph to the branches you’re interested in; the check always stays visible.
Click **Open in Knowledge Graph** to open the full Entity graph. If the check isn’t linked to a service yet, click **Add service link** to go straight to the **Labels** step of the check editor.
## View a check in the Knowledge graph
In the Knowledge graph, find your check in the [Entity catalog](/docs/grafana-cloud/knowledge-graph/troubleshoot-infra-apps/explore-entity-catalog/) or Entity graph by filtering on the `SyntheticCheck` entity type, or open it from any service it monitors. From the entity page you can add the check to the [root cause analysis (RCA) workbench](/docs/grafana-cloud/knowledge-graph/troubleshoot-infra-apps/workbench/) and [start an investigation](/docs/grafana-cloud/knowledge-graph/use-cases/investigate-incidents/) with the service and its dependencies.
Because the relationship is `Service` `MONITORED_BY` `SyntheticCheck`, insights on a check also count towards the health of the service it monitors. The check’s health is visible from the service, without having to look for the check.
## Understand check health in the Knowledge graph
A check’s insights reflect its own Synthetic Monitoring [per-check alerts](/docs/grafana-cloud/testing/synthetic-monitoring/configure-alerts/configure-per-check-alerts/). Nothing is recalculated in the Knowledge graph, so a check’s rings follow your own thresholds and evaluation windows, including any change you make to them.
Expand table
| Insight                                | Severity | Fires when        |
| `SyntheticCheckLatencyBreach`          | Critical | The check’s latency alert is firing. Latency alerts are available for HTTP, DNS, and Ping checks.                                |
| `SyntheticCheckFailedExecutionsBreach` | Critical | The check’s failed checks alert is firing.        |
| `SyntheticCheckTLSExpiryBreach`        | Warning  | The check’s TLS certificate expiration alert is firing. TLS certificate expiration alerts are available for HTTP and TCP checks. |
When several of these fire on the same check, they appear as separate insights that roll up into one ring.
A few consequences are worth knowing:
- A check with no per-check alerts configured never lights a ring, and looks the same as a healthy check. Configure per-check alerts on the checks whose health you want to see in the Knowledge graph.
- Only per-check alerts drive the rings. [Legacy sensitivity alerts](/docs/grafana-cloud/testing/synthetic-monitoring/configure-alerts/configure-default-alerts/) don’t.
### Read check health and service health together
Compare check results with service health to decide where to investigate. A service’s insights can come from its own telemetry or from a linked synthetic check.
- **Both unhealthy: a user-facing outage.** Both signals agree, and the linked service helps you identify where to investigate.
- **The check fails, but the service looks healthy: investigate the path to the service.** Either the path to it—DNS, TLS, a load balancer, routing—or the check itself, such as a wrong target or an over-strict assertion.
- **The check passes, but the service has insights: a possible coverage gap.** Users may be affected on a path the check doesn’t exercise, while the probed path stays clean. Consider broadening your checks to cover the failing path.
- **The service looks healthy, but a dependency is ringed.** Follow the service’s `CALLS` edges in the graph. The check’s failure can originate one hop further down.
Insights follow your per-check alert thresholds and evaluation windows, not individual probe results: a brief failure that doesn’t fire the alert shows in the check’s uptime without lighting a ring, and after recovery the service’s insights can take a few minutes longer than the check’s probes to settle.
## Considerations
- **A check links to every service with the same name and namespace.** If the same service runs in more than one environment or cluster under the same name and namespace, a check links to all of them. Scoping a link to a single environment isn’t supported; use the **Env** filter on the Connected services graph to narrow the view.
- **Checks don’t belong to an environment.** The Knowledge graph groups entities by environment, but a check has no environment of its own, so checks aren’t grouped that way.
