title: "Create and manage secrets for Agentic testing | Grafana Cloud documentation"
description: "Create and manage secrets for Agentic testing in Grafana Cloud so agentic tests can reference sensitive values at runtime without storing them in plain text."
# Create and manage secrets for Agentic testing
Use **Secrets management** in Agentic testing to store logins, API keys, tokens, and other sensitive values encrypted for your stack. Reference secrets as `${secret:SECRET_NAME}` in user journey steps so values are injected at runtime and never saved as plain text in the test.
Secrets you create in Agentic testing are shared with Performance testing. Anyone with secret-management permissions on the stack can read, edit, or delete them from either **Testing &amp; synthetics** &gt; **Agentic testing** &gt; **Settings** or **Testing &amp; synthetics** &gt; **Performance** &gt; **Settings**.
> Note
> Secrets management is currently in [public preview](/docs/release-life-cycle/). Grafana Labs offers limited support, and breaking changes might occur prior to the feature being made generally available.
For encryption details, limits, and role-based access control, refer to [Create and manage secrets](/docs/grafana-cloud/testing/k6/author-run/manage-secrets/) in Performance testing.
## Before you begin
To manage secrets for Agentic testing, you need:
- Access to **Testing &amp; synthetics** &gt; **Agentic testing** &gt; **Settings** in your stack
- Permission to create, edit, or delete secrets on the stack
Refer to [Role-based access control](/docs/grafana-cloud/testing/k6/author-run/manage-secrets/#role-based-access-control) in the Performance testing secrets documentation for role requirements.
Only text-based secrets are supported. Secret names and descriptions must be 253 characters or less, and secret values must be 24kB or less. Secrets can have a maximum of 10 labels, and label keys must be 63 characters or less.
## Open Secrets management
1. Sign in to your Grafana Cloud stack.
2. On the main menu, click **Testing &amp; synthetics** &gt; **Agentic testing** &gt; **Settings**.
3. Click **Secrets management**.
The **Secrets** page lists secrets available to your agentic tests. If you haven’t created any yet, the page shows an empty state with **+ Create secret**.
## Create a secret
To create a new secret:
1. On the **Secrets** page, click **+ Create secret**.
2. In the **Create secret** dialog box, fill in the following fields:
   - **Name**: A unique name used to reference the secret in journey steps, for example, `quickpizza-admin-password`. You can’t change the name after you save the secret.
   - **Description**: A short description of what the secret is for.
   - **Value**: The secret value returned when the secret is referenced at runtime.
   - **Labels** (optional): Key-value labels to organize secrets. Click **+ Add label** to add one.
3. Click **Save**.
## Use a secret in a browser test
After you create a secret, reference it in a user journey step with `${secret:SECRET_NAME}`, where `SECRET_NAME` matches the **Name** you entered when you created the secret.
For example, if you create a secret named `quickpizza-admin-password`, you can add a journey step such as `Fill password with ${secret:quickpizza-admin-password}`.
Refer to [Create browser tests from plain-language user journeys](../create-browser-tests-from-plain-language-user-journeys/) for the full workflow to create and run a test.
## Edit or delete a secret
To edit or delete a secret, open **Agentic testing** &gt; **Settings** &gt; **Secrets management**, find the secret in the list, and use **Edit** or **Delete**.
To update a secret **Value**, click **Reset** in the edit dialog box, enter the new value, and click **Save**.
> Warning
> Deleting a secret is permanent and can’t be undone. Agentic tests that reference a deleted secret fail until you update the journey steps or create a new secret with the same name.
## Next steps
- [Create browser tests from plain-language user journeys](../create-browser-tests-from-plain-language-user-journeys/)
- [Create and manage secrets](/docs/grafana-cloud/testing/k6/author-run/manage-secrets/) in Performance testing
