title: "Connectivity options | Grafana Cloud documentation"
description: "Learn how to use Grafana Fleet Management with private networks and on-premises observability setups"
# Connectivity options
Grafana Fleet Management enables you to remotely configure and monitor your fleet of telemetry collectors through Grafana Cloud.
Fleet Management provides connectivity options for both enterprise and self-managed setups, as well as support for observability setups that require tighter security or work with restricted networks.
- [AWS PrivateLink and Fleet Management](/docs/grafana-cloud/observe-and-act/send-data/fleet-management/set-up/connectivity-options/aws-privatelink/)
  Learn how to use Grafana Fleet Management with AWS PrivateLink
- [Azure Private Link and Fleet Management](/docs/grafana-cloud/observe-and-act/send-data/fleet-management/set-up/connectivity-options/azure-private-link/)
  Learn how to use Grafana Fleet Management with Azure Private Link
- [GCP Private Service Connect and Fleet Management](/docs/grafana-cloud/observe-and-act/send-data/fleet-management/set-up/connectivity-options/gcp-private-service-connect/)
  Learn how to use Grafana Fleet Management with Google Cloud Platform Private Service Connect
- [Self-managed setups and Fleet Management](/docs/grafana-cloud/observe-and-act/send-data/fleet-management/set-up/connectivity-options/self-managed/)
  Learn how to use Grafana Fleet Management with an on-premises observability setup
